Old 06-11-2012, 11:51 AM   #22711
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
you need to email tech support for a RA#,fill out the service form and then send it in.
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 06-11-2012, 01:22 PM   #22712
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Originally Posted by Dusttt View Post
Thanks Randy just tried that too and nothing. I will send it in it. It should be under warranty. What is the process?
www.teamtekin.com/service.html
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 06-11-2012, 03:22 PM   #22713
mysupratoy94's Avatar
Trader Rating: 24 (100%+)
Send a message via Yahoo to mysupratoy94
What is a good heat range for a RS and Pro? Min to Max.
mysupratoy94 is offline   Reply With Quote
Old 06-17-2012, 03:15 AM   #22714
smilekt's Avatar
is there any new function for turbo on or activate by combination of RPM & Full throttle ?
Kuala Terengganu Rc Club Facebook
http://www.facebook.com/group.php?v=wall&gid=357083332025
smilekt is offline   Reply With Quote
Old 06-17-2012, 11:23 AM   #22715
Team Tekin
Randy_Pike's Avatar
Not at this time.
Old 06-17-2012, 12:38 PM   #22716
noline's Avatar
Anyone have a Thunder Power 10.5 or a 8.5 Boost setup for 1/10 touring on a Asphalt 150'X50' track and also gearing Im running a Xray T3 2012
noline is offline   Reply With Quote
Old 06-17-2012, 10:23 PM   #22717
smilekt's Avatar
Originally Posted by Randy_Pike View Post
Not at this time.
thanks for the info Randy hope will come out soon ...
Old 06-18-2012, 09:34 PM   #22718
Dan
Dan's Avatar
Trader Rating: 48 (100%+)
Having a weird problem...
Installed the RS into my car, went to hotwire to update the ESC. The Hotwire detected it fine, but when I went to click on update ESC, it was going thru the update, then it failed. After it failed, now when I plug in my Hotwire, it won't detect the ESC.
And when I plug it back into the car, I get power to the receiver and servo just fine. Everything operates but the ESC. The ESC is showing all lights on, but very, very dim.
Got a race this weekend too, urgh!!
Dan is offline   Reply With Quote
Old 06-18-2012, 09:52 PM   #22719
Randy, Im running a losi xxx-sct with a tekin 8.5 with a RS Pro ESC. Also a Associated SCT with a 8.5 LRP and RS ESC. What would be an ideal average heat i should try and stick too on both ESC's?
Old 06-18-2012, 11:33 PM   #22720
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
Have you tried a "factory reset"? From the manual:
"The RS series has a built-in factory reset mode that resets all user programable settings to the default values. To activate, turn the speed control on, then press/hold INC button and then press/hold MODE button simultaneously for 3 seconds. After 3 seconds the LEDs will ramp up in sets of three. NOTE: Activating the self-test mode also resets all the radio calibration settings to their default"
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 06-19-2012, 12:00 AM   #22721
Dan
Dan's Avatar
The RS is still not responding.
Old 06-19-2012, 12:59 AM   #22722
YoDog's Avatar
Trader Rating: 26 (100%+)
Dude, you can't accurately check the temp on the rs speedos via a temp gun. You need to look at the led lights and try to keep from lighting them all. Your main concern should be how hot your motor gets. This will be your best indicator as to how your setup is working. Your best bet is to read the manual and use the search function on the threads. You will likely find your answers faster than waiting for someone to chime in like me.
YoDog is offline   Reply With Quote
Old 06-19-2012, 01:33 AM   #22723
Tradin Paint's Avatar
Please tell me why you can't accurately check the temp of you ESC with a temp gun? Please let me know the temp difference in the LED monitoring method. I agree that it is probably better to check the temp of your motor, but monitoring your ESC is also a good idea
Happy with: Team Associated, Team Tekin, Airtronics, Avid, JConcepts, Fantom motors and Aero Model batteries.
Proud Supporter of Warehouse 3 RC Hobby Shop, that just happens to have an indoor track
"Because Size Does Matter"
Ryan H.
Tradin Paint is offline   Reply With Quote
Old 06-19-2012, 02:13 AM   #22724
YoDog's Avatar
In the tekin the FET's are on the bottom rather than the top like most speedos.
The connection posts are the only "heat sinks" on the rs so I suppose you could check temps there but they are a bit reflective and will be a little spotty with an ir temp gun.
That's why tekin incorporates an internal temp sensor. Typically the motor will show signs of over temp before the speedo unless you are seriously over timing the motor. I've actually seen the wires unsolder themselves.
Old 06-19-2012, 02:19 AM   #22725
YoDog's Avatar
Dan, I tried to search for an answer regarding a "force update" but no luck yet.
I should hope that some sort of back door has been built in for just this type of scenario.
Randy, can the rs be reflashed after a bad update? Luckily this hasn't happened to me so far but I worry about it every time I update my firmware. The Hotwire software hasn't been the most stable in my experience.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
