Old 05-18-2012, 09:09 AM   #22666
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Ok so you want a TC setup with what motor?
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 05-18-2012, 09:27 AM   #22667
I need a setup for RS PRO with a SP V3 4,5R .
What's the normal degrees for esc , i don't want to burn it ...
Akita is offline   Reply With Quote
Old 05-18-2012, 11:27 AM   #22668
YoDog's Avatar
Trader Rating: 26 (100%+)
Set it into blinky mode and you will have plenty of power.
No need to add timing.
YoDog is offline   Reply With Quote
Old 05-18-2012, 02:43 PM   #22669
No turbo or boost ?
Safe temp. ?
Old 05-18-2012, 03:14 PM   #22670
M3Armand's Avatar
Default Throttle Profile Curve Setup from ESC?
Will it be possible to access the 7 different throttle curves from the ESC eventually? I believe with the Hotwire, the "TP" becomes "Timing Profile" and the Throttle Profile is lost.
M3Armand is offline   Reply With Quote
Old 05-18-2012, 04:56 PM   #22671
YoDog's Avatar
No turbo or boost ?
Safe temp. ?
For motors below 6.5 turns, there is no need for boosting. you will just create more heat. Unless you are a pro driver with free electronics, you will want to play it safe. Believe me, 4.5 is plenty fast without boost. With some motors I prefer to run negative timing to keep temps down and get a little more torque out of slow corners.
When I tried running boost or turbo on my 4.5 motors in TC, the wires would sometimes unsolder themselves. Not good...lol!
Old 05-19-2012, 10:37 AM   #22672
hi, need some assistance on my setup - rs pro with 10.5 turbo, in 1/10 on road touring, current setup
FDR - 6.9
start rpm - 4XXX
end rpm - 10XXX
boost - 30
turbo - max
ramp - 2, lowest delay.
motor temp - 60 deg C after 6 min
i have kept throttle at linear. i have fan blowing on esc and motor so its quite cool.
very fast in field (i think i will increase end rpm to 12XXX to tame wheel spin) but on the straights, the turbo seems to take a long time to engage, was playing against an orca (also running same FDR and same touring car as me) and that esc turbo seems to kick in almost instantenously. checked my sensor cable all good. even recalibrated my radio and the esc. is there any thing i can do to get my turbo to kick in faster. we are both similar in field, its the long straights i am not able to keep up because his turbo engages faster. i tried to increase the end bell but it seems more in field power which i do not need. thanks.
rshair is offline   Reply With Quote
Old 05-19-2012, 01:40 PM   #22673
bukil's Avatar
Trader Rating: 39 (100%+)
FDR - 6.9 7.4
start rpm - 4XXX 8000
end rpm - 10XXX 22000
boost - 30 45
turbo - max 15
ramp - 2, lowest delay. Delay 0.2
It seems like your boost and turbo are coming in too soon.
Adjust the boost and turbo accordingly w your motor timing based on 60 total degree timing (Boost + turbo + motor timing).
Answers are in red. This is the setup I had when I used to run 10.5 boosted. Hope this helps.
☆ ActivRC ☆
bukil is offline   Reply With Quote
Old 05-19-2012, 02:22 PM   #22674
wingracer's Avatar
Trader Rating: 24 (100%+)
Yeah, rpm points are WAY too low. Bump them up to 8k or so to 25k or so and then you can run more boost to get the straightaway speed you are looking for. Also, don't run minimum delay. Your problem isn't that it's coming in slower, it's that it is on ALL THE TIME. With no delay and low rpm settings, you are basically at max timing all the way around the track. That's why you have so much rip in the infield. He beats you on the straight because he has more timing than you on the straight.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 05-20-2012, 03:28 AM   #22675
smilekt's Avatar
thanks for good explanation ..
Kuala Terengganu Rc Club Facebook
http://www.facebook.com/group.php?v=wall&gid=357083332025
smilekt is offline   Reply With Quote
Old 05-20-2012, 10:31 AM   #22676
thanks for the answers. i am looking for the turbo to kick in faster, so now i see your point, my gearing is tall (i was running what most others were running at this track, which is between 6-6.9), so the shorter gearing will assist the in field whilst keeping the boost and turbo for the straights, am i reading this right? sorry for many questions, even if i have had the tekin for a while, i am still poor at programming.
Old 05-20-2012, 10:59 AM   #22677
bukil's Avatar
Yes. One pattern I noticed with Tekin is when you have it setup to a narrow rpm range, somehow the motor likes it geared heavy (more teeth). With the wider range of rpm, it likes it geared lighter (less teeth). In addition to wider rpm range, somehow, you can get away with 0 turbo delay. This is all based on my personal testing. Some may disagree. I hope this helps you, and not confuse you.
Rule of thumb for me is:
Small tight tracks - narrow rpm range
Large flowy tracks - wide rpm range.
Again, this is just based purely on my personal testing. I'm sure Tekin drivers will chime in and help you out.
☆ ActivRC ☆
Old 05-20-2012, 11:49 PM   #22678
bukil, thanks for the explantion. where i am at, its a little of both. another question, is this applicable to only tekin motors with tekin rs pro or can i use the same setup on my tekin rs pro with another motor?
Old 05-21-2012, 12:43 AM   #22679
bukil's Avatar
For the most part, yes. You will most likely need to fine tune the settings depending on what motor (rpm vs torque motors). For example, you can get away with 50 boost on DUOs, but not on LRPs - lower turn motors. In addition, you would need to gear more on torque motors vs rpm ones depending on the track layout.
This is how I tune any motors with tekin speedos. Some racers use different methods. So, dont get stuck with just one. Find your "happy medium" way.
Hope this helps.
☆ ActivRC ☆
Old 05-21-2012, 12:52 AM   #22680
susanpower's Avatar
susanpower is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
