Old 05-09-2012, 10:18 AM   #22636
Regional Moderator
CarbonJoe's Avatar
Timing profile 1 is Blinky mode. The "locked" mode prevents changing out of blinky mode using factory reset or the buttons, and I believe also changes the current Timing Profile to 1 if it's not the current profile.
You can still change other settings like Neutral Width, Brake settings, Throttle Profile, etc.. Just no timing advance, boost, or turbo.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 05-10-2012, 04:35 PM   #22637
bvoltz's Avatar
Trader Rating: 44 (100%+)
Thanks... This is what I thought....
bvoltz is offline   Reply With Quote
Old 05-10-2012, 09:17 PM   #22638
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Originally Posted by MikeXray View Post
How do you get back out of blinky lockout mode? I had a racer ask me, and it didn't seem like we could from the hotwire interface.
You must uncheck the "spec lockout" box in the hotwire.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 05-10-2012, 09:17 PM   #22639
Team Tekin
Randy_Pike's Avatar
Originally Posted by bvoltz View Post
Many thanks for you reply, so I want to be clear about this, the box must be checked? As in no adjustments in the curve... I understand I can play with the Expo in the radio to achieve like results....
The reason, if you uncheck the box and run in C1 mode, and remove all the boost, timing, etc... you can change the curves.... Would that be legal "Blinky Mode"? That is the debt at the track, this is legal... That is why I'm asking here....
No, simply putting the esc boost settings to 0 and 0 won't turn the blinky function on.
Old 05-10-2012, 09:32 PM   #22640
bvoltz's Avatar
Thanks for the clarification....
Old 05-11-2012, 07:53 PM   #22641
silvalis's Avatar
Trader Rating: 29 (100%+)
For additional mid acceleration, should I?
a) increase boost
b) put a bigger pinion in
c) decrease top rpm no#
T3, 6.65FDR, Ion3 13.5, Boost 40 (5-26k), Turbo 10 (1 ramp 0.2 lag), Motor temps = low, maybe too cold
silvalis is offline   Reply With Quote
Old 05-11-2012, 11:25 PM   #22642
FDR depend of the track but i think 7.0 will be fine with 50 boost 5xxx/20xxx and turbo 10.
With the endbell timing set to the middle for start
Manson is offline   Reply With Quote
Old 05-13-2012, 02:39 AM   #22643
I have a tekin rs pro with a SP 5T and it's really slow in straight .
I have boost 20, turbo 8 and timing 80.
how can i improve top speed ?
I run a tamiya trf 417
esc temp ~65 C
Akita is offline   Reply With Quote
Old 05-14-2012, 07:24 AM   #22644
zerocool77's Avatar
Send a message via Yahoo to zerocool77
Hello all, i got problem with this tekin motor. Why its always problem with the rotor. Like need to changed the top bearing. I have 4 redline motor. All got same problem. Please help about this.
~ Team Putra Serpent, Kch ~
zerocool77 is offline   Reply With Quote
Old 05-14-2012, 07:39 AM   #22645
MikeXray's Avatar
Trader Rating: 73 (100%+)
I checked with my pc and it was an option, I'm not sure what was up with his, maybe he had someone else install 223 and he had an older version of hotwire on his pc?
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 05-14-2012, 09:22 AM   #22646
Team Tekin
Randy_Pike's Avatar
esc temp ~65 C
You should not have to boost up a 5T motor that much to get the right speed from it. I'd wager you're gearing is off.
Old 05-14-2012, 09:23 AM   #22647
Team Tekin
Randy_Pike's Avatar
What problem are you referring to? Bearings need to be serviced and or replaced from time to time.
Old 05-14-2012, 09:28 AM   #22648
Team Tekin
Randy_Pike's Avatar
Yup, very possible and likely.
Old 05-14-2012, 11:42 AM   #22649
Default intermittent reverse?
So I have a RS pro (v223 FW) that sometimes will not go into reverse. the ESC is set-up with the reverse delay, and the ESC lights will ramp up when trigger is pushed in reverse, but no action from the motor. It is intermittent, sometimes works, sometimes not. I've recalibrated with the same result. I tried the reverse with no delay, and it worked everytime, although I do not want to run it like that. Using airtronics tx/rx (FHSS3)
Any suggestions on what to look for/change?
TLR 22T and Yokomo YZ-2 and 4
www.corvictoria.com
brew99 is offline   Reply With Quote
Old 05-14-2012, 11:49 AM   #22650
Love my Tekin! What timing profile do you guys like best?
Boca Bearings, Leadfinger, M2C Racing, Radiopost, Reds Racing, Team C, Venom, Viper, VP-Pro
http://TallahasseeRC.com
http://vimeo.com/40046773
http://www.youtube.com/user/fsugolfandcards
FSULowLap is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
