Old 01-29-2009, 02:52 PM   #2251
Krio's Avatar
Trader Rating: 150 (99%+)
Originally Posted by M-Tune View Post
I have the Tekin RS Pro. I have adjusted the brakes to the max amount (I think. All the way to the right last led light). But it still will roll to a stop. I had the LRP TC and it brakes stopped instantly. Should the brakes be working better than a roll to a stop or is that normal with tekin?
The brakes in dual mode are relatively low...to get LRP TC like brakes you will need to switch to sensored only mode via the hotwire.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 01-29-2009, 03:05 PM   #2252
Trips's Avatar
Trader Rating: 16 (100%+)
Originally Posted by miller tyme View Post
TRIPS : Your idea sounds good but I'm not sure of the programming logistic or space available. Personally I would not use the info. If you trying to compare your motor to my motor for instance timing is only part, we'd also have to check rotor strength and inductance and driving style, otherwise timing comparison would only show a partial picture and for reasons of gearing not any more precise as a whole than the 3 degree variance.
Ken,
I agree it wouldn't be all that useful, and there are too many other variables as you mention to make any direct comparisons between motors based on timing alone.
For me, it's just a touch of obsessive/compulsive tendency that keeps me wanting to know. In my case, knowing the exact timing I'm getting would be good for better sleep at night... and probably little else.
D
MARSHAL!!
Trips is offline   Reply With Quote
Old 01-29-2009, 03:55 PM   #2253
miller tyme's Avatar
Originally Posted by Trips View Post
For me, it's just a touch of obsessive/compulsive tendency that keeps me wanting to know. In my case, knowing the exact timing I'm getting would be good for better sleep at night... and probably little else.D
I got to admit that sounds a lot like me. I'd like to know exactly what the timing is, and I tend to over analyze most things and ask why/why not. Usually, its useless info but I'd rather have info I don't need than not have info I do need.
Ken Miller
RCTarget - Capricorn - Pro Level RC - MAX Power - Maxima Fuel - EA Motorsorts - TQ Wire
LONG LIVE OPEN MODIFIED
miller tyme is offline   Reply With Quote
Old 01-29-2009, 04:38 PM   #2254
Originally Posted by Krio View Post
No, 12 degrees is what he sensors are actually at in many locked timing motors (eg novak) so you still have to add the ~15 of pre-read.
BTW the novaks have adustable timing. lossen thed screws on the back plate then the ring ( on a 13.5 is orange, 10.5 blue ect.) twists.
heres a pic of the ring out of the motor:
http://s243.photobucket.com/albums/f...andbearing.jpg
e-team hobby: www.eteamhobbyplex.com
Fort Collins Colorado
Gorilla Boy Racing
mxzhonkey is offline   Reply With Quote
Old 01-29-2009, 05:50 PM   #2255
There seem to be quite a few unused LEDs on the hotwire?
stocker is offline   Reply With Quote
Old 01-29-2009, 07:50 PM   #2256
mojoman's Avatar
Randy you have email.
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 01-29-2009, 07:57 PM   #2257
Krio's Avatar
I know you can adjust them, but it isn't really beneficial to if you have a tekin with boost. First, there are no marks to tell you what you are at. Second, you are twisting the whole endbell which flexes the internal motor wires unlike other adjustable motors that only spin the sensor harness.
www.kriostasis.com
Old 01-29-2009, 11:44 PM   #2258
Default RS Setup sheets
We have a new setup sheet for the RS and RS Pro available for download to help out keeping track of your settings when you don't have hotwire available. The PDF is setup to allow you to print 2 sheets side x side on one sheet of paper.
download pdf setup sheet
tekinben is offline   Reply With Quote
Old 01-30-2009, 02:44 AM   #2259
im not worried about flexing the wires, the way it was done. plus you can just calculate the timing like we did before for the lrps.
from what i understand boost is only at the top end anyway and it wont go as far as motor timing and software timing. i usually don't recommend more than 35 but there are instances where it can be needed
Gorilla Boy Racing
Old 01-30-2009, 04:24 AM   #2260
....BOOST IS SOFTWARE TIMING AND IS ADDED TO THE ENTIRE RPM RANGE OF THE MOTOR WHILE IN SENSORED ONLY MODE. Total additional timing is 0*-30* above and beyond what is achievable with the motor, and it is precisely adjustable in 1* increments.
If your running hybrid mode (you really only should be for winds under 10.5, the TIMING only comes into play when the unit switches from sensored to sensorless which is determined by rpm. NO I don't know what rpm.
Ken Miller
Old 01-30-2009, 05:42 AM   #2261
Send a message via MSN to Adim_X
Quick question. Is "push" in the hotwire only for brushed motors?
Adim_X is online now   Reply With Quote
Old 01-30-2009, 05:54 AM   #2262
Trader Rating: 17 (100%+)
Default Hotwire tethering
Is the Hotwire tethered to one speed control and one pc, or can I borrow someone else's and use on my pc and my speed controller and not mess up the other guys settings?
billb60 is offline   Reply With Quote
Old 01-30-2009, 05:59 AM   #2263
Default messed up settings
If you borrow a pals ESc and change the settings they would be your settings and not his.
His would be lost as settings are not stored either in Esc or PC
tellan is offline   Reply With Quote
Old 01-30-2009, 06:03 AM   #2264
I'm only borrowing the hotwire for my pc and esc.
Old 01-30-2009, 06:22 AM   #2265
As I understand it, "Push Control" is basicaly applying 'creep' in a brushed motor only during slowdown , to allow it to roll to a stop like a brushless rather than just have the magnets suck the armature to a stop
Ken Miller
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
