Tekin RS ESC sensored
Sure, touring car class which we are running in 8 minutes race and best lap currently on 13.5 sec.
thanks.
thanks.
track size
I need a good starting point for 13.5(duo1) indoor carpet track size 80x35.
Thanks in advance.
Thanks in advance.
Trader Rating: 27 (100%+)
does the rs have a motor limit when running 1s? Im moving from stock 1/12 to mod and i already have a 4.0 that I would like to utilize. will that be ok?
yes the same as 2s,you need the pro for the 4.0t
will the (TT3812 30mm Fan - Rx8 ESC)work on the rs?
thank you
thank you
The RS pro should be used with low turn mods. Guys have used the RS but you run the risk of thermalling.
Yes the fan can work if mounted on it's side.
How does one change the profile without hotwire? I have 212 software the setting i currently have are my 17.5 but i would like to run mod. people have told me i can store 3 profiles is this true? I have read instructions i see nothing about additional profiles THANKs
You need the hot-wire to update the firmware i.e. change from the 212 to 223 program or vice versa. There are 6 possible throttle profiles thats about it.
Can someone tell me what FDR I should be running with my redline 2.5t. This motor is mainly for bashing (just want the esc & motor to run safe).
2.5T
Are you nuts??
What car is that in?
If it is a TC then you need some serious spurgears
regards Roy
Are you nuts??
regards Roy
It's for a tc6.1 with Trakpower 6200 50c battery.
