Old 04-15-2012, 08:51 PM   #22516
Default B4.1 timing and gearing
I've been having to run in the 13.5 class at my track, because there aren't a lot of 17.5 guys. Right now I have my B4.1 geared at 33/72 (FDR 5.67) and am coming off the track under 150F, but can't really keep up with the boosted 13.5 guys. What gearing and timing is a good starting point?
It looks as though the default timing is around 16 degrees, is that normal?
I don't have the Hotwire interface. Is there a difference between advancing motor timing and timing in the ESC?
Equipment:
Tekin RS Pro (no updates)
Redline 17.5T brushless sensored motor
InfamousJon is offline   Reply With Quote
Old 04-15-2012, 09:31 PM   #22517
Regional Moderator
CarbonJoe's Avatar
Equipment:
First off, in order to use boost, you'll need to find someone with a Hotwire, since I'm pretty sure that the RS/RS Pro still ships with 1.89 firmware, which didn't have boost/turbo. The only way to update the firmware is with a Hotwire.
Timing in the motor is always there, since it is a physical moving of the sensor board. Timing in the ESC can be adjusted via start/end RPM, plus adding turbo/turbo ramp.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 04-15-2012, 10:34 PM   #22518
Default mod setting
I am thinking about going mod racing at leisure hours raceway, people are telling me i will not be able to go lower than a 10.5 any truth to this? I am running a t3 with an rs not pro. any suggestions for gear would be appreciated.
.http://www.youtube.com/watch?v=Bj9rh...5&feature=plcp
capt waffles
sobiski racer is offline   Reply With Quote
Old 04-15-2012, 10:36 PM   #22519
I know that the boosting on the ESC is electronic and Hotwire is needed to modify it and I also know that the motor timing is physical, but I'm curious as to how they compare. Maybe you answered the question I just don't know the difference between turbo and turbo/ramp.
Old 04-16-2012, 08:58 AM   #22520
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
You'd be surprised how fast a boosted 10.5 TC car can be.
Tough to say on gearing. Try Hara's 11.5 TITC setup: http://www.teamtekin.com/hotwire/ESC..._11.5_v212.pdf
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 04-16-2012, 11:03 AM   #22521
Regional Moderator
CarbonJoe's Avatar
Motor timing is always there, regardless of motor RPM, so if you have a lot of motor timing, the motor can feel like it is bogging (same if you add too much timing in the ESC too fast). When you add it in the ESC, you have some control of when it is added, and over what range it is ramped up. Timing is ramped linearly between the start and end RPM. After the motor has reached the end RPM, the amount of timing would be the same (given "zero" motor timing and the same amount of timing added in the ESC). It is how is it added that is the difference.
Then, "turbo" is added on top of that (also ramped up) after full throttle has been active for the specified amount of time, regardless of motor RPM.
All that timing does is affect when the each phase of the motor is energized in relation to the magnetic pole of the rotor, based on the signal from the sensor.
Clear as mud?
Old 04-16-2012, 12:34 PM   #22522
Clear as mud?
Clear as muddy water...
So if i am understanding you correctly, both high motor timing and ESC boost isn't a good thing. Bogging would cause slower acceleration and response, but allow for higher top speeds? Does that mean a mix of the two is best or should I turn my motor timing down to 0* and begin by bumping up the boost in the ESC?
And it sounds like 'turbo' adds punch (voltage? or current?) to the motor when max throttle is applied?
I'm taking a physics course, so I think I understand what you mean about energy and pole relationship. In essence the magnetism applied is being 'stretched' by changing when they alternate current? Stretch it too much and it has a weaker 'pull and push.'
Old 04-16-2012, 01:58 PM   #22523
Regional Moderator
CarbonJoe's Avatar
If the sum of motor timing and ESC timing is above a certain amount, the motor won't even run (or won't run right), since the phases will be fired so far out out of time compared to the magnet.
I believe that the amount of throttle is converted to pulse width modulation (PWM) and varies the amount of time each pole of the motor is energized, basically giving the rotor little pulses of magnetic field to force the rotor to move.
Since almost all motors have some built-in timing (you can't really get to zero), tuning the motor timing and the ESC timing really comes down trying to find the optimum mix for a given motor and gearing combo.
Old 04-16-2012, 07:53 PM   #22524
Trader Rating: 17 (100%+)
ok guys im very confused, i have an old tc3 that i was trying to run in the gt 10 class. its has a tekin 17.5 and an rs pro in it and i just got smoked. any way i have it on the hot wire now and it is showing 80 timing advance, is that ok? how do i get the turbo and boost to work? sorry for the long post im just confused
thanks ralph
ralph brunt is offline   Reply With Quote
Old 04-16-2012, 07:56 PM   #22525
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
you need to click sensor mode to get timing boost and turbo also have you looked at youtube for helpful videos
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 04-16-2012, 08:00 PM   #22526
thanks smoke i just clicked it and it came up. i will check the youtube thing any idea of a starting point for this turbo and boost?
ralph
Old 04-16-2012, 08:05 PM   #22527
Still Bill's Avatar
thanks ralph
Go to the Tekin website and refer to their reference manual for the RS. It will explain much of what you need to know. I printed out a copy for future reference.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 04-16-2012, 08:36 PM   #22528
20 SMOKE's Avatar
ralph
track size
Jamie W
Old 04-16-2012, 09:00 PM   #22529
just read the rules and i cant run turbo or boost so now im back to gearing
Old 04-17-2012, 07:28 AM   #22530
20 SMOKE's Avatar
so you have to be in blinky,run max motor timing and start to find some gear,play with the throttle setting with the hotwire so you don't loose to much punch
Jamie W
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
