Old 04-07-2012, 10:59 PM   #22441
EskimoGangsta's Avatar
Send a message via AIM to EskimoGangsta Send a message via MSN to EskimoGangsta Send a message via Skype™ to EskimoGangsta
Originally Posted by B.C.Ninja View Post
I may have been experiencing the same problem, I come through a medium speed corner on our track onto our main straight, hammer on the gas and I hit a dead spot, kinda weird only happens on occasions but it stutters, kinda of like a lean bog with a nitro, and it only happens on this one spot of the track. Anyone want to chime in?
I had the same problem "Entry to straight" on full power with wheels turned still. i ended up putting a cap on my receiver, studder no more. i think ut had to do more with the servo drawing to much power giving a delayed reading to the esc or the internal bec making the esc studder from the servo drawing to much. either or a simple 800uf 16v cap did the trick.
Live, Laugh, RC
EskimoGangsta is offline   Reply With Quote
Old 04-08-2012, 12:05 AM   #22442
Suspended
Chuss , are you running that 4t in sensored only mode??? What's your gearing???
bertrandsv87 is offline   Reply With Quote
Old 04-08-2012, 09:08 AM   #22443
Robby368's Avatar
Trader Rating: 14 (100%+)
Sorry for not reading through the 1,500 pages, but I've heard rumors of hotwire software available for smartphones??? That would be ridiculously awesome
Before you judge someone, walk a mile in their shoes. Then you'll be a mile away and have their shoes.
Robby368 is offline   Reply With Quote
Old 04-08-2012, 04:02 PM   #22444
Trader Rating: 21 (100%+)
no
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 04-08-2012, 08:02 PM   #22445
RacinJ's Avatar
Could this be a V223 issue?
I've experienced the issue, throttle brown out while accelerating from partial throttle to full and turning on to the straightaway. I first noticed it after upgrading to the latest firmware.
I'm running 1/12th scale, 17.5 blinky and am using a receiver pack wired into the switch harness.
Roche P12 '16 & '17; Team Scream 17.5 & 13.5
1/12th scale, just 1/12th scale.
I love to go like hell for 8 minutes.
RacinJ is offline   Reply With Quote
Old 04-09-2012, 05:44 AM   #22446
warnos's Avatar
Default spektrum
I had the same brown out issue back with 203 when I was running a spektrum.. nothing I could do would fix it.. changed to Sanwa/airtronics fixed it.. are u guys with the brown outs running spektrum?
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
Old 04-09-2012, 05:59 AM   #22447
Nuno Gancho's Avatar
hello do anyone have setting with the Tekin RS Pro for a lrp x12 9.5T, and a trinity 13.5, settings and final ratio, thanks.
Nuno Gancho is offline   Reply With Quote
Old 04-09-2012, 06:15 AM   #22448
Will I be disadvantaged if I run the RS instead of RS Pro in TC stock?
zzztech is offline   Reply With Quote
Old 04-09-2012, 06:23 AM   #22449
warnos's Avatar
no... save ur money if u are not going to use it for mod.. and its less grams in ur car..
Old 04-09-2012, 10:30 AM   #22450
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
If you're one of those guys that sets their epa's to pull tension on the steering as the "end" you can grab enough current to brown out the radio system. Use an Rx cap, if this fixes it you should be good.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 04-09-2012, 02:12 PM   #22451
+1. i always set my steering 1 notch down after the humming from the servo stops. and as for the studder, it's not a software issue, just savox/spectrum combo. i also ended up switching the spectrum receiver for a spare losi one i had laying around and that also helped it.
Live, Laugh, RC
Old 04-09-2012, 02:55 PM   #22452
Not since switching to the TQ booster in my 1/12th scale
Old 04-09-2012, 03:28 PM   #22453
Hello.I run in sensored only.No boost and no turbo.Gearing of 8.
chuss43 is offline   Reply With Quote
Old 04-09-2012, 05:16 PM   #22454
Suspended
Chuss the Rs pro was really designed to run mod 4.5t motors in dual mode only. If sensored mode is feasable, I don't know how much motor timing you need to run, but it should run nicely at stock 12 of timing...
Old 04-09-2012, 05:28 PM   #22455
Suspended
Also 8.0FDR is a little low in my opinion. 7.5fdr sounds better , but will make the motor work a little more and stop overrevving, which can overheat the ESC.....I run my 3.5t gtb at 8.409FDR, and no heat issues nowhere. I can even get away with 8.2FDR, but I would rather add a little timing on the top end(about 15) with my upcoming kinetic esc.....
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
