Old 03-13-2012, 11:50 PM   #22336
HighLife420's Avatar
Trader Rating: 49 (100%+)
Send a message via ICQ to HighLife420 Send a message via AIM to HighLife420 Send a message via MSN to HighLife420 Send a message via Yahoo to HighLife420 Send a message via Skype™ to HighLife420
Great service from Tekin, RMA in a few hours, going out tomorrow. Thanks Tekin.
Dominic "Dom" Chin
TLR 22 (Tekin RS Pro, LRP X12 7.5t, Savox 1258TG)
MIP Pro4mance SCTE (Tekin RX8, Tekin Pro4 4600kv, JR Z9100s)
Ko Propo Eurus (EX10) Limited Edition
HighLife420 is offline   Reply With Quote
Old 03-14-2012, 12:13 AM   #22337
Just picked up a Tekin RS Pro from someone off the forums. I'm in need of a hotwire though. Where can I pick one up from? The tekin website isn't very helpful
KelvinKarvin is offline   Reply With Quote
Old 03-14-2012, 12:29 AM   #22338
vabroom's Avatar
http://www.amainhobbies.com/product_...-USB-Interface
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 03-14-2012, 03:28 AM   #22339
jsr555's Avatar
Trader Rating: 17 (100%+)
As explained a couple of posts ago, mine is fine now, just had to apply the settings then get the current settings ffrom the speedie for the dashboard to update..
Originally Posted by EAMotorsports View Post
Are you talking about throttle curve's...the last box at the top of the window correct? If so this is something that mine does too and has been doing. Not sure why. When you go out to the main menu it always shows Profile 3 but if go back to the curve screen it shows its still where you set it.
Xray T4 & HPI/HB Pro 5 - Powered by Hobbywing
SQ: HPI RS Pro -HPI RS Pro 2 - HPI Pro 3 - HPI Pro ?? - HPI Pro 5
jsr555 is offline   Reply With Quote
Old 03-14-2012, 06:52 AM   #22340
mike_lim12's Avatar
can i know what kind of capacitor to upgrade on my rs speedo,my previous cap had been broken from the 2 tiny leg i cant find back the cap
im plannin to get an cap to replace.
TEAM MAX EP
SURIKARN 6500 70C.
SAKURA X1,XRAY T3 11
HOBBYWING zerun 2.1 120A,ORCA MK2
DUALSKY 10.5T,5.5T,ORCA 17.5T,YOKOMO SS 48T
mike_lim12 is offline   Reply With Quote
Old 03-14-2012, 06:00 PM   #22341
Default Help pls on RS error code
Hi I have been running an RS Pro for a couple of years. I have just bought a 2nd hand RS and fitted it to my sonís car.
When I switch on I get lights 3 & 5 flashing. They flash for 4 or 5 secs, go out, light 1 comes on momentarily, then it goes back to lights 3 &5.
I tried calibrating the RS and the transmitter, no go. I went to the transmitter and changed the reverse setting for the throttle and this time I was able to calibrate the transmitter. But I am still getting lights 3 &5 flashing.
Any ideas on what is wrong?
yellowshark is offline   Reply With Quote
Old 03-14-2012, 06:05 PM   #22342
HarryLeach's Avatar
Send a message via AIM to HarryLeach
Nothing wrong, it's running either 212 or 223 firmware version and it's in blinky mode.
http://www.teamtekin.com/hotwire.html
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 03-14-2012, 06:06 PM   #22343
I don't think anything is wrong. 3&5 flashng then 1 and then 3&5 again I believe means no radio signal. After you calibrated, only 3&5 flashing means you are in blinky mode. That's profle one.
DOTMAN is offline   Reply With Quote
Old 03-14-2012, 06:09 PM   #22344
HarryLeach's Avatar
No, the 1 flashing every so often is the onboard temp indicator.
Old 03-14-2012, 06:13 PM   #22345
turn on your esc without turning on your radio and it will do that. Turn on your radio and only 3&5 flash
Old 03-14-2012, 06:57 PM   #22346
HarryLeach's Avatar
Nope, just verified it again.
Radio on, neutral throttle position, 3 & 5 blink rapidly 4-5 times, onboard temp indication of 1 for half a second, back to 3& 5 rapid blink. Slowly apply throttle, blinking stops, LED's ramp from 1 to 7, all 7 LED's on and blinking at full throttle. When slowly applying brake, the LED's ramp from 7 to 1, all 7 LED's on and blinking at full brake.
Radio off for me is no different, as my failsafe is programmed for neutral throttle and straight steering.
Want a video?
Old 03-14-2012, 07:01 PM   #22347
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
that is blinky mode like harry is saying,to get out of blinky push the mode button 5 times led TP push INC once led 1 will be lit push it a second time led 2 is lit no more blinky
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 03-14-2012, 07:02 PM   #22348
Thanks guys To be fair I have never run blinky or investigated it - but I still feel kind of stupid
Old 03-14-2012, 07:03 PM   #22349
20 SMOKE's Avatar
you can use the 1000 uf 16v from radio shack until you get the stock tekin one
Jamie W
Old 03-14-2012, 07:04 PM   #22350
20 SMOKE's Avatar
thats ok,we will just say it because you live in the UK
Jamie W
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
