Old 01-27-2009, 03:29 PM   #2221
jdearhart's Avatar
Trader Rating: 15 (100%+)
Will Tekin swap an R1 for a RS Pro?
jdearhart is offline   Reply With Quote
Old 01-27-2009, 04:03 PM   #2222
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
For a price they will. Contact Tekin direct for a price.
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 01-27-2009, 06:12 PM   #2223
Trader Rating: 35 (100%+)
Originally Posted by Randy_Pike View Post
We didn't really have issues with single cell. It was a matter of getting setups on the esc. Some ran boosters, others receiver packs.
We are working on some new software but it's not being released. For now 189 is "current."
The team guys do have a new "interface" look right now.
Josh Keller is offline   Reply With Quote
Old 01-27-2009, 06:13 PM   #2224
CREWMAN's Avatar
Trader Rating: 19 (100%+)
Tekin will swap esc and discount the price of the one you want hmm if this is tru alot of doors may have opened for my esc situation
D&K HOBBIES!!!!
Losi 8ight-T 2.0 Race Roller/Losi 350/JR 9100 Servos/Spektrum DX3R
BMI Copperhead 12/Thunder Power Lipo/Futaba Servo/Express 17.5/Spektrum DX3R
CREWMAN is offline   Reply With Quote
Old 01-27-2009, 08:22 PM   #2225
xtrememadness's Avatar
Send a message via AIM to xtrememadness
hey randy, i got the 189 update from donny lia on both my speedos. but i need the software to put on my pc so that i can change the settings myself. i sent you an email but i think i gave you the wrond address. thanx
[email protected]
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 01-27-2009, 09:02 PM   #2226
Trips's Avatar
Trader Rating: 16 (100%+)
[email protected]
Craig,
I can take care of it, either via email or at 360... let me know.
David
MARSHAL!!
Trips is offline   Reply With Quote
Old 01-28-2009, 12:33 AM   #2227
LOSI123's Avatar
Trader Rating: 63 (100%+)
Can the Tekin RS Esc Add esc timing to Motor timing all the time in sensored mode?
Or is it only at boost / Take off/ Launch?
LOSI123 is offline   Reply With Quote
Old 01-28-2009, 01:46 AM   #2228
In sensored only mode the boost setting is added to the motor timing, all the time.
Ahmed Aman is offline   Reply With Quote
Old 01-28-2009, 07:53 AM   #2229
Originally Posted by Trips View Post
Craig,
David
sweet dave thanx i appreciate it. if you could email it to me that would be great. see ya at the track.
Old 01-28-2009, 07:56 AM   #2230
Trips's Avatar
Check your mail, Craig, I sent it last nite...
MARSHAL!!
Old 01-28-2009, 09:17 AM   #2231
Originally Posted by Josh Keller View Post
I remember reading a post from Jim, that a 1 cell Li-Po version was a possibility. Possibly slowing down the servo, so that a booster or receiver pack wouldn't be needed.
Any luck or truth to that version?
Myself being an oval racer and having the steering input and return speed at 45%, a slower servo would be acceptable.
Josh
Besides the speed you'll want to make shure that the servo still has the holding power that you need in the corners. Lower voltage will lower the torque along with the speed.
To be honest, a booster isn't a big deal and Novak will release one soon. If this single cell thing catches on maybe Tekin will make a booster also.
Fred_B is offline   Reply With Quote
Old 01-28-2009, 12:00 PM   #2232
DriftDreamer06's Avatar
Default rs timing
i am currently looking to change esc for my 17.5 1/12 car. i have narrowed it down between 2 esc. my rs questions are this.
1. how much timing does the esc add in just the different profiles?
2. i am assuming that timming boost is over the profile time? if so how what is the range of timing 0* to 50*???
3. i might be missing it but the screen shots i have seen does it list out the timing? i have been told 50* max so motor, esc, and boost need to be added?
4. can you save different proflies in the esc or computer for quick change or is it a reset each time?
thanks for your input and time
i am sure i will have more question.
Racin'4-fun -- na to win
DriftDreamer06 is offline   Reply With Quote
Old 01-28-2009, 12:13 PM   #2233
Trips's Avatar
The different profiles are for different throttle response curves. No changes in timing there, timing is independent of the profiles.
In sensor mode, you can add up to 30 degrees of timing advance above what you can get at the endbell of the motor. I mmight be mistaken about this part, but I believe that in sensorless mode you can also add up to 30 degrees of timiing, but you don't get anything from the endbell in that mode, sinice the RS ignores the motor sensors in that mode.
THe timing you add in sensor mode is listed in degrees, the timing you add in sensorless mode is listed as a percentage. You asdd the endbell and boost to get total timiing. There is some extra depending on how your particular motor reads the sensors. In other words, the "zero" mark on the can is usually going to be something other than zero. Dpends on the motor.
Not yet, that is a feature that is coming.
MARSHAL!!
Old 01-28-2009, 12:58 PM   #2234
thank you for that info.
next question is:
there is no timing advance in the profiles? exmple-motor 0* but is 12* plus esc 0* plus boost 0* then equals 12*
i was told but was wondering - that there is a progressive timing in some profiles. example 5* start and as rpm go up so does timing 30*(not exact #'s)
i look forward to more info.
Racin'4-fun
Old 01-28-2009, 01:09 PM   #2235
motor 0 boost 0 but timing is 15fromout the esc when i'm rihgt.
So boost on 30 and motor on 0 than you have 45 in total.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
