Tekin RS ESC sensored >
Old 03-10-2012, 10:06 AM
  #22291
Hi Randy
I have a bit more technical question for you.
I`ve searched but there does not seem to be much of information about the technical side of things.
What do boost and turbo actually do ?
To my understanding it seems that turbo changes the length of a timing window the coil is "fired" and the boost just moves the window- am i close?
Allso iŽd like to know from what are the value ranges in your software derived from?
Hope you can educate me
Thanks in advance
Marten
Marten is offline
Old 03-10-2012, 10:09 AM
  #22292
Have a read of:
http://www.teamtekin.com/hotwire_RS.html
or
http://www.carsrcracing.co.uk/?p=188
they should help explain what does what
chris_blakey is offline
Old 03-10-2012, 10:18 AM
  #22293
Thanks, but i`ve read those.
What i`m wondering is if the window of coil being powered in degrees changes when using boost/turbo compared to mechanical timing/no boost
Marten is offline
Old 03-10-2012, 12:16 PM
  #22294
touringdriver's Avatar
Trader Rating: 16 (100%+)
can someone help me out with an honest answer please?
is TP1 mode on a pro the same as being in (BLINKY) mode?
touringdriver is offline
Old 03-10-2012, 12:37 PM
  #22295
Trader Rating: 29 (100%+)
TP1 is Blinky mode.
Walkman is offline
Old 03-11-2012, 03:51 PM
  #22296
Team Tekin
Randy_Pike's Avatar
Originally Posted by Marten View Post
Hi Randy
Thanks in advance
Marten
Sorry but you're asking me/us to educate you on our secret sauce. Not gonna happen
Randy_Pike is offline
Old 03-11-2012, 04:42 PM
  #22297
jsr555's Avatar
Trader Rating: 17 (100%+)
Default Throttle profiles
Ok, what am I doing wrong?
I have just loaded 223 and in the timing window I can only access the boost and RPM adjustments when I select C1 and C2... When I am in TP2 to 5.. I can not adjust the Boost, turbo or RPM's... Infact I do not have the option, the controls are not even present.
Also, regardless of what throttle profile I select, the dashboard always says 3. Even when checking the spec mode box
jsr555 is offline
Old 03-11-2012, 04:51 PM
  #22298
Dog Bone's Avatar
Make sure the 'Sensored' check box is checked. Once you do that, you'll have access to turbo and boost.
Dog Bone is offline
  #22299
Still Bill's Avatar
Still Bill is offline
Old 03-11-2012, 05:20 PM
  #22300
jsr555's Avatar
Thanks, but it doesn't matter. In the timing window I have to go to C1 to get the sensored box option. I select it, then once I go to TP 5... all the timing and boost options disapear again.
jsr555 is offline
Old 03-11-2012, 05:25 PM
  #22301
Regional Moderator
CarbonJoe's Avatar
Aren't TP1 - TP5 all fixed, preset timing / boost profiles? C1 and C2 are the custom profiles, where you can change all of the settings.
CarbonJoe is offline
Old 03-11-2012, 05:30 PM
  #22302
Regional Moderator
CarbonJoe's Avatar
Yep, TP1 - TP5 are fixed. See the User Guide (scroll down about half way):
Old 03-12-2012, 02:19 AM
  #22303
jsr555's Avatar
Thanks. Makes sense now, (after reading the guide...)
But just so I do not think I am going crazy, tell me, with 212, when using say TP3. You could change boost, timing and RPM etc... Yes?
jsr555 is offline
Old 03-12-2012, 03:24 AM
  #22304
No. You may be thinking about throttle profile instead of timing profile. Timing profile 1-5 are presets (both in 212 and 223), and only C1 and C2 are customizable.
Nilks is offline
Old 03-12-2012, 03:51 AM
  #22305
That is what i was afraid you answer
Can you just give me just a simple answer- Is window width(deg) static or is it changing?
Marten is offline
