Old 03-08-2012, 03:18 PM   #22276
Team Tekin
TY@TEAMTEKIN's Avatar
Originally Posted by LOW ET View Post
with all this talk about making 222 and 223 smoother (for stock motors i assume), are there any benefits when using mod motors?
It benefits all of them, smoother throttle and brakes across the board.
Originally Posted by Matt W View Post
Hi,
Another quick question about the software, why is the neutral width set at 58 default, that is a massive deadband. On 212 everyone used to run at 10 or even 5? (Im running a 13.5 boosted touring car)
It's just a default setting, some drivers don't like to have the trigger react so quickly or twitchy. You are right that a lot run the NW at 15 or below for a fast trigger reaction.
Ty Campbell
TEKIN / TLR / SOR GRAPHICS / MIP / PROTEK / KALGARD / AVID
TY@TEAMTEKIN is offline   Reply With Quote
Old 03-08-2012, 09:40 PM   #22277
mike_lim12's Avatar
aww i cant download 223 even i dy press f5 what my problem...
TEAM MAX EP
SURIKARN 6500 70C.
SAKURA X1,XRAY T3 11
HOBBYWING zerun 2.1 120A,ORCA MK2
DUALSKY 10.5T,5.5T,ORCA 17.5T,YOKOMO SS 48T
mike_lim12 is offline   Reply With Quote
Old 03-08-2012, 10:14 PM   #22278
RA99GT's Avatar
http://download.teamtekin.com/TekinHotWire8_4_1.exe
-MurfDogg Racing- Race One or Chase One! -http://www.murfdogg.com/
My RC Racing Blog- http://ra99gt-rcracing.blogspot.com/
My YouTube Channel- http://www.youtube.com/user/ra99gt
RA99GT is offline   Reply With Quote
Old 03-08-2012, 11:56 PM   #22279
Dadaman's Avatar
Trader Rating: 20 (100%+)
I have put 223 onto my speedy. I have adjusted what I had to adjust and saved the settings. When I go to callebrate the speedy, it's fine in neutral and full forward, but it can't find brakes. I am using a Spektrum DX3r with a sr-3100 receiver.
Anyone else had the same problem and been able to fix it?
I went back to 212 but I still have the problem.
Xray XB4 '16
Yokomo Dogfighter YZ-10 870c
Xray T4 '14
Dadaman is offline   Reply With Quote
Old 03-09-2012, 02:00 AM   #22280
I am struggling a bit with the brakes on the 223 software. I am running 17.5T blinky with an LRP X12, geared at 3.9 and 4-dot timing.
Right now I am at 75% brakes on my transmitter and 100% in the speedo. It locks up the tires when at speed, but when in the low-speed corners, I don't really have enough brakes for my liking.
The brakes are really strong at speed, but quite weak at low speed. Is there anything I can do to help this?
Active Braking is Off currently.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 03-09-2012, 10:37 AM   #22281
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Make sure you're epa's(travel on spektrum) is at 100/100
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 03-09-2012, 10:41 AM   #22282
Team Tekin
Randy_Pike's Avatar
Turn active brakes on.
Old 03-09-2012, 11:46 AM   #22283
Thanks, I will try that next time at the track :-)
Niklas Hansen
Old 03-09-2012, 01:21 PM   #22284
LOW ET's Avatar
Trader Rating: 97 (100%+)
with my spektrum i had to set it up with throttle/brake at 90 on the end points, setup the esc, them put the spektrum back at 100/100. this should stop the radio drift. (IF that's your problem)
LOW ET is offline   Reply With Quote
Old 03-09-2012, 01:43 PM   #22285
Regional Moderator
CarbonJoe's Avatar
They're equally fast sitting on the shelf, regardless of motor.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 03-09-2012, 01:43 PM   #22286
rb-digi's Avatar
hello .. i have a tekin rs esc in my b4.1 ..i have ran this esc with a few diffrent motors (all 17.5) in both timing and non timing modes..when i ran it in timing i was having an issue with landing hard where the esc would quit powering the motor and it last for about 8 seconds.I figured i was loosing battery connection or a switch was the issue but..the steering never quits working and it takes it about 8 seconds for the motor to start goin again. if its ever from loosing a connection it only takes about 3 seconds for the esc to re-arm and go..I am always on the driver stand or in a race when it happens and i havent been able to see what exactly the esc is doing while the motor isnt getting power..i am wondering if you had any ideas as to what could be making it do that ..It seems to only be when i come short on a big jump or over jump and land a lil hard..im not bashing this is i only drive this on a clay indoor track.It seemed like it quit doin it while i was runnin non timing stick class with a team icon motor..i soldered a reedy sonic 17.5 and im still running non timing and now the problem is happening when i land hard..could it be the sensor port? would that take that long to "re-boot" or get thing goin again ,,i have tried different sensor wires also ..i was running spektrum when it first started happening but i have since mooved to a airtronic mt4 and its still acting the same way.thnks
Rory BROman
kyosho sc-r sp ,b4.1+8mm ft, reedy 17.5, tekin rs //t4.1 ft,SLASH 4x... never dialed * TEAM BALUT * OCRC raceway
rb-digi is offline   Reply With Quote
Old 03-09-2012, 01:55 PM   #22287
rb-digi's Avatar
oops..just noticed this is an onroad thread..hope it dosent anger anyone
Rory BROman
Old 03-09-2012, 02:04 PM   #22288
LOW ET's Avatar
just because i haven't been to the track doesn't mean i dont play
Old 03-09-2012, 08:54 PM   #22289
EskimoGangsta's Avatar
Send a message via AIM to EskimoGangsta Send a message via MSN to EskimoGangsta Send a message via Skype™ to EskimoGangsta
Just got to try 223 today. and my active brakes in tc boosted 17.5 are AWESOME! thank you Randy and everyone else from tekin with this new update. i actually had to turn my brakes down to like 70% and if i still hit full at anytime they just start locking up. the way i like them
Live, Laugh, RC
EskimoGangsta is offline   Reply With Quote
Old 03-10-2012, 04:30 AM   #22290
Send a message via AIM to Matt W
Default 223
Hi,
With the new 223 software, what are most people setting the throttle and brake minimum at? (Im running 13.5 boosted touring car)
Matt W is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
