Old 03-06-2012, 08:32 AM   #22246
Originally Posted by faifaisalfal View Post
Ok. But by not switching on the esc, it will only affect the cut off right? All other setting such as boost and etc will still be working?
By the way, how about the procedure? Should I plug in the lipo first then the life receiver pack, or the plug the receiver pack then the lipo?
It makes no difference but I have an in-line switch on the receiver pack so all is plugged in and then I throw the switch.
AreCee is offline   Reply With Quote
Old 03-06-2012, 10:50 AM   #22247
HenryC's Avatar
Originally Posted by [email protected] View Post
Unplug your ESC and let the HotWire portal come up, click on Help. What version does it say?
After starting the Hotwire software, if I unplug the ESC, the main screen closes and reverts back to just the small window indicating "Step 1 Hotwire to ESC, Step 2 Hotwire to USB". No other screen ever appears.
***** Update *******
Just read about the tekin.esc file that needs to be deleted when installing a new version. Did that and now all is OK. Seems like the install process should remove that file.
HenryC is offline   Reply With Quote
Old 03-06-2012, 11:58 AM   #22248
DaveW's Avatar
Originally Posted by Matt W View Post
Hi guys,
Could the 212 software go up on the tekin site as well as the 223 just incase people prefer that one or ever want to go back to that version?
Always save each version to a SD card for future use. I still have 208/212 saved.
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 03-06-2012, 01:11 PM   #22249
Send a message via AIM to Matt W
Default 212 software
I dont suppose you could email me a copy of the 212 software if I message you my email address?
Matt W is offline   Reply With Quote
Old 03-06-2012, 01:30 PM   #22250
durtbag's Avatar
you can revert to 212 even with the new software, it shows in other versions, just click on 212 and update the speed control.
AW HELL RICKEY, I WAS HIGH WHEN I SAID THAT!
durtbag is online now   Reply With Quote
Old 03-06-2012, 02:38 PM   #22251
Any team driver setups or just use same as before?
Michael Zufelt
It's not how you stand next to your car, it's how you race your car.
http://www.dynamichobbies.com
TheZoof is offline   Reply With Quote
Old 03-06-2012, 03:08 PM   #22252
Team Tekin
TY@TEAMTEKIN's Avatar
The portal is the Step 1 Step 2 graphic I was referring to, then you click Help.
Are you on Vista? Windows7 does not have the .esc file issue like Vista used to, that would be the virtual store and it was a pain.
Glad you got it working.
Ty Campbell
TEKIN / TLR / SOR GRAPHICS / MIP / PROTEK / KALGARD / AVID
TY@TEAMTEKIN is offline   Reply With Quote
Old 03-06-2012, 03:09 PM   #22253
Team Tekin
There are some differences in 212 and 223 settings, I'll have updated 223 setups for download on the site soon. Gotta build them all!
Ty Campbell
Old 03-06-2012, 06:45 PM   #22254
HenryC's Avatar
I am running Windows 7, 64bit. The portal did not have a Help option. To get it to work I did have to go to the VirtualStore directory and remove the .esc file.
Old 03-06-2012, 11:08 PM   #22255
Trader Rating: 22 (100%+)
Just trying to update 223 went into the speedy ok put in my settings ok.
I have no chimes when I try to recalibrate.
Speedy plugged back into hotwire shows 223 and all my settings are there, however the 2 outside led's flash.
What is this from?
bjspinner is offline   Reply With Quote
Old 03-06-2012, 11:31 PM   #22256
What is this from?
Done.
Sensor cable worked 5 minutes before I upgraded swapped out to new problem solved.
Old 03-07-2012, 12:29 AM   #22257
What is this from?
Mine is doing something similar, but isn't showing the 2 outside LEDs, just a solid center (it should be in blinky mode, it looks like a boosted mode indicator). The rightmost three dim lights move as they should from motor rotation, so I'd tend to believe the sensor cable isn't the problem. Steering also works correctly, so I'd be shocked if it was my radio.
After the update, if I push the mode button briefly it just goes dark. If I try to calibrate (push and hold the mode button), it blinks through the "starting calibration mode" sequence with the usual chimes, then goes dark and remains that way until I disconnect it from power for about 30-45 seconds, then when I plug it back in it'll do what I just described above again, but never actually calibrates. Reverting to 212 doesn't fix it, either. She was working fine just before I attempted the update.
My other cars that this version hasn't touched still work fine...
What am I doing wrong here?
EricJ is offline   Reply With Quote
Old 03-07-2012, 01:03 AM   #22258
Perfect <rubs hands together> just in time for some practice tomorrow night !
Jo90uk is offline   Reply With Quote
Old 03-07-2012, 05:49 AM   #22259
mike_lim12's Avatar
currently i cant download the 223 software any idea???
TEAM MAX EP
SURIKARN 6500 70C.
SAKURA X1,XRAY T3 11
HOBBYWING zerun 2.1 120A,ORCA MK2
DUALSKY 10.5T,5.5T,ORCA 17.5T,YOKOMO SS 48T
mike_lim12 is offline   Reply With Quote
Old 03-07-2012, 08:08 AM   #22260
they probably removed it again.....having the same issue
hellssephiroth is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
