Old 02-24-2012, 09:22 AM   #22186
the wheel's Avatar
Trader Rating: 29 (100%+)
Default k
Originally Posted by CarbonJoe View Post
Currently, only 212 is available via Tekin's web site. When the issue is fixed, and after ROAR approves it, and new version 223 will be posted on Tekin's web site.
ok thanks ,but why when downloaded it shows number 2 is that just on my computer to show i have 2 downloaded
the wheel is offline   Reply With Quote
Old 02-24-2012, 09:26 AM   #22187
Derry's Avatar
Trader Rating: 27 (100%+)
Originally Posted by wingracer View Post
Yes it would.
Spektrum and Savox seems to be the worst combo. Why people keep using Spektrum stuff is beyond me. Seriously people, there are MUCH better performing radios out there. Also, I have seen brown outs with the Spektrum/Savox combo on some other speedos too.
Weird I have not had an issue running DX3R with 3100 receiver and Savox 1257 Servo.
Associated B64D
Associated B6D
Derry is offline   Reply With Quote
Old 02-24-2012, 09:31 AM   #22188
EskimoGangsta's Avatar
Send a message via AIM to EskimoGangsta Send a message via MSN to EskimoGangsta Send a message via Skype™ to EskimoGangsta
I'm running that Exact combo. and i didn't have many issues. i just noticed the bind light and transponder light dim when i turned. i switched to a cheapy losi rtr 2.4 receiver and had no issues.
one of those things "i'll give this old thing a try before i buy something new and it worked." no more dimming
Live, Laugh, RC
EskimoGangsta is offline   Reply With Quote
Old 02-24-2012, 12:20 PM   #22189
macdude's Avatar
Yes, if you have not deleted the original download then the next time you down load it to the same folder it adds a number to the file name. The prevents you from accidentally overwriting things downloaded to the same folder that have the same name.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 02-24-2012, 01:07 PM   #22190
I have only had it happen with a 9.5T motor and the 1257 servo using the 3120 rx.
All my other set ups with Spektrum and Savox have never had a brown out.
AreCee is offline   Reply With Quote
Old 02-24-2012, 08:31 PM   #22191
j.d.roost's Avatar
Trader Rating: 28 (100%+)
Anyway to get 222?
I thought it was fantastic for 1s 1/12 but
had to re-format my laptop.
F1
Roche usa
R.I.P. Jon Williams
j.d.roost is offline   Reply With Quote
Old 02-25-2012, 12:42 AM   #22192
spammy's Avatar
can somebody help me? my tc comes to a complete stop and the corner Marshall get the car he wiggles the sensor wire and the car goes so i thought it was the sensor wire right.Change the wire to a new one right out the bag and i tap a wall and it does it again so wth
__________
Leighton Lederer
{R/C Plus Salem Oregon}
spammy is offline   Reply With Quote
Old 02-25-2012, 01:26 AM   #22193
I would say that was more than likely a problem with sensor board in the motor. Have you tried a different motor?
http://rcgtpancars.blogspot.com/
chris_blakey is offline   Reply With Quote
Old 02-25-2012, 06:18 AM   #22194
Regional Moderator
CarbonJoe's Avatar
It's either the sensor board in the motor, or the sensor connector on the ESC. As suggested, try another motor. If it still does it, it's the ESC. Unless, of course, you tapped the wall right on the motor, and you could have broken the new wire.
Are you running 222? With 212 and earlier, if the sensor wire breaks while running, the ESC will switch to sensorless mode and continue to run. With 222, it will just stop.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 02-25-2012, 09:29 AM   #22195
hi can anyone suggest a starting setup for my rs pro with a 10.5t, boosted. track size is 80x40. not sure what fdr to run yet, any suggestions? talked to a few racers - it was between 7-8.6.
torn between a tekin 10.5 and a D3 duo, this track has quite a bit of in field so a motor that can deliver the push would be good.
thanks.
rshair is offline   Reply With Quote
Old 02-25-2012, 10:01 AM   #22196
rdlkgliders's Avatar
Trader Rating: 21 (96%+)
__________
Leighton Lederer
It could be a brownout and the time it takes to lift up the car and shake the wire it comes back on, I thought my problem was a sensor wire at one point.
2 bad sensor wires? sensor board maybe, If it's under warranty you could send it in to Tekin they have great service. but a different motor may be the easy test like stated above, then you need to test the esc.
Just a thought.
Serpent, KO Propo, Viper, Savox, ProTek
Team Waldorf Racing
Your not lapping me, you just caught up to me again!!!
rdlkgliders is offline   Reply With Quote
Old 02-28-2012, 07:01 PM   #22197
Any news or update on the 223 software?
He who dies with the most toys wins, if it's a tie, then it's he with the best.
sjh28 is offline   Reply With Quote
Old 02-28-2012, 08:01 PM   #22198
R3VoLuTiOn's Avatar
we're all waiting patiently lol
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 02-28-2012, 10:09 PM   #22199
The brake issue with v222 seems to be very motor dependent.
I run 13.5 boost TC with 2s. I didn't have any brake issue running Team powers or speed passion motors. However, once I switched to LPR, brake while boosted while non-existent.
oh well.... need to wait for v223 to release i guess
Tamiya - TRF 417V5 - Smokem - Hobbywing V3 - Reedy Sonic 4.5 Mach2
Sanwa M12
iwkyb is offline   Reply With Quote
Old 02-28-2012, 10:17 PM   #22200
Ya, I'm running a 17.5 D3 with 0 mechanical timing. one track i go to the brakes are just strong enough. but then the other track with more grip and 30ft longer straight.. so glad tekin decided to help some of us out with this other then waiting for a "next update".
Live, Laugh, RC
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
