Tekin RS ESC sensored >
Old 02-22-2012, 12:00 PM
  #22156
R/C Tech Elite Member
Jamison R's Avatar
Trader Rating: 66 (100%+)
I have tried everything I can think of, as you can see over the past few pages
Jamison R is offline
Old 02-22-2012, 01:40 PM
  #22157
cheehtae's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Jamison R
No chime, all LEDs flashing
I had the same exact problem, I had sent it twice to tekin. Cut the long story short they had to replaced it according to them if your esc is about 2 or 3 years old the solder on the sensor board is getting weak.
cheehtae is offline
Old 02-22-2012, 04:54 PM
  #22158
Team Tekin
Randy_Pike's Avatar
Recently updated to the 222. I have tried going back to 212 with no luck.
Please contact either [email protected] or [email protected] to get an RMA#. Sounds like this one needs repair.
Randy_Pike is offline
Old 02-22-2012, 05:43 PM
  #22159
rdlkgliders's Avatar
Trader Rating: 21 (96%+)
Originally Posted by Randy_Pike
Hardly telling you to buy something else. We make products that produce fast and consistent lap times. I'd be willing to do it, if the lap times could show the results where there.
I'm still very confident that our boosted software is one of if not the best. Lap times don't lie however....
We make products that produce fast and consistent lap times, until they brown out at random times.
rdlkgliders is offline
Old 02-22-2012, 06:42 PM
  #22160
Team Tekin
Randy_Pike's Avatar
Right due to servos that draw excessive amounts of current....moving on.
No need to beat a dead horse.
Old 02-22-2012, 07:02 PM
  #22161
Randy I sent you a pm
Old 02-22-2012, 07:29 PM
  #22162
Team Tekin
Randy_Pike's Avatar
I've got no pending Pm's.
Old 02-22-2012, 10:40 PM
  #22163
RC_Dan's Avatar
Same issue here after attempting update. If I figure something out, I'll let you know.
RC_Dan is offline
Old 02-22-2012, 10:41 PM
  #22164
RC_Dan's Avatar
Randy, you have PM from me as well.
RC_Dan is offline
Old 02-22-2012, 11:49 PM
  #22165
Come on guys, stop the bitching. I for one have used an RS Pro for nearly 2 years now with no fault at all. Savox servo's are renound for dragging power, but I have used one in my touring car for over 1.5 years with no issue. then again I have heard of drivers who use HobbyWing, LRP all having that same issue due to power drag from the servo.
I personally have been sponsored in years gone by by Speedo manufacturers. What I see Randy diong every day isn't something I would see many other manufacturers doing to help those using their product. The fact being they noticed a glitch with brakes in the latest release and rather than coating over it they held up their hand and said they would get it sorted. that to me is EXCELLENT service from a manufacturer. they could have coated it and left this change for a later release, instead they are clearly pushing to get this sorted for the US guys and their nats championships coming up. this isn't just a 5 minute job to change.
Hardware can and will break at times, and this goes for ALL manufacturers. The guys suffering problems it is a shame, but rather than attack Randy get in touch with their support direct and organise sending the speedo off to them rather than sniping on here, it will get you nowhere fast and won't get your speedo working !
Keep the thread to being about setting up the speedo, help with setup and talk about the upgrade etc. It's been useful to me in setting up for different motors and tracks, but having to go through pages of whinging makes it difficult to find the info a racer needs.
Again, well done Randy for the hard work, and to Team Tekin. I will be sticking with you !
Jo90uk is offline
Old 02-23-2012, 03:30 AM
  #22166
Uga
Uga's Avatar
Agreed. I've been using RS Pro for 3 years and with 0 issues. I've updated 2 speedos to v222 with no problems at all. Running 2S 17.5T boosted WGT.
Uga is offline
Old 02-23-2012, 03:38 AM
  #22167
sagejyoung's Avatar
same - ran 1/12th and 17.5 TC and had no issues.
sagejyoung is offline
Old 02-23-2012, 09:38 AM
  #22168
i got my 222 update last week and reprogrammed my speedo i plan on giving it a try tuesday in my 10th scale pan car. i think tekin has a great program. keep up the good work guys.
wait a minute is offline
Old 02-23-2012, 01:58 PM
  #22169
nerdling's Avatar
... until they brown out at random times.
Hi Guys,
not interested in floging dead horses, I think Tekin are doing a great job providing this level of consultation and support to their users.
My question is this, can the brownout problem be resolved with the use of a cap connected to the reciver?
I ask, because, back in the brushed days, I would have laps missed when racing modified on carpet with foam. We eventually worked out that because the scoring loop was located on a corner exit where the car was accelerating, that the current draw from the motor was causing the transponder (and probably the Rx and servo) to lose power. I solved the problem by connecting a 4400uf cap to my reciver.
Mark
nerdling is offline
Old 02-23-2012, 02:06 PM
  #22170
I was having brownout issues using that well known bad pairing of Spektrum and Savox. Fitted a cap to my reciever and problem solved.
markrobinson is offline
