Old 02-15-2012, 12:40 AM   #21961
Originally Posted by Randy_Pike View Post
We have had requests for additional brake power in boosted spec TC classes, and we are going to give it to you. We are adding a new active brake setting that will feel more like V212 in super boosted setups at high rpms. So for those of you that feel that the 222 brakes are a bit weak at the end of the straight away this will give you the additional brake power you're looking for. In classes like 2wd offroad 212 brakes had room for improvement in feel and modulation. Now that spec racing is becoming more popular the team felt that the added driveability of the 222 brakes made for faster laptimes, something we're always looking to improve.
Thats really good Randy. I think this will be a very welcome addition to a good upgrade. It's also great to see Tekin taking a note of drivers and making amendments so quickly....othe rmanufacturers would probably say "ok, in the next revision" which would be months away.
Looking forward to the slight change !
Jo90uk is offline   Reply With Quote
Old 02-15-2012, 01:30 AM   #21962
Quick question about the wire posts on a standard: I'm running 12th scale 10.5/13.5 with and LRP X12. If I have the +'ve and -"ve battery posts covered with shrink wrap, is that going to cause overheating problems? I'll be running mild boost on an average sized track. The motor wire posts are not covered by shrink wrap. Thanks in advance!
adam lancia is offline   Reply With Quote
Old 02-15-2012, 04:24 AM   #21963
Con
You shouldn't cover any of the posts with shrink wrap. All 5 posts are used for cooling.
Con is offline   Reply With Quote
Old 02-15-2012, 04:29 AM   #21964
wollow86's Avatar
I cover mine slightly, have no issues what so ever with esc temps. I run boosted 17.5. I go maybe 5mm below the solder join onto the post with heat shrink, and its all 5 posts.
Supporting Aussie hobby shops:
- www.MRJRacing.com.au - - www.feralbatteries.com.au - - www.actionrc.com.au -
wollow86 is offline   Reply With Quote
Old 02-15-2012, 05:44 AM   #21965
I wouldnt, the design is done so that these posts are effectivelt heat sinks. Regardless of what motor, keep them open and also position your speedo so you know it will get airflow to the posts as well.
Old 02-15-2012, 07:04 AM   #21966
Maybe I should explain how I have it setup. The posts aren't completely covered, I've soldered male bullets onto the tops of the battery posts and I've got heat shrink on the female bullets coming from the battery. I'd say the top 1/4 of the posts are covered. I'll keep an eye on temps (whenever I get a chance to run it) and report back.
Old 02-15-2012, 08:12 AM   #21967
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Originally Posted by Still Bill View Post
Will any version of 222 be legal for the ROAR Carpet Nationals next month?
Thanks.
Bill
Maybe, that's up to ROAR. The next version will of course be submitted and likely approved in time for Carpet Nats.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 02-15-2012, 08:15 AM   #21968
Team Tekin
Randy_Pike's Avatar
Originally Posted by Potato View Post
What does the active brake do? Does it adjust throttle lift engine braking? Not off throttle but partial throttle braking?
I saw it appear in my v222 install then disappear.
I'm not going to go into great detail about "what" it's doing other than to say it's giving you more braking power in high boosted setups with motor like 17.5's,etc.
V212 brakes were very good in boosted TC, but not so good everywhere else in our opinion. V222 brakes are excellent everywhere except boosted spec TC. Now you have both.
Old 02-15-2012, 09:53 AM   #21969
rangerjkb's Avatar
Trader Rating: 40 (100%+)
Send a message via MSN to rangerjkb
Are the "Timming Tab" setting incraments (ie. Boost:50, Turbo:10. etc.) the same between v212 & v222 to produce same motor performance? When initially tried v222, felt much smoother but slower on top end than the v212 carry overy settings. Great job on the new programming and any feedback is greatly appreciated.
Jason Burks
Psycho Cells Racing~Hal's Hobby Warehouse~Murfdogg Products~Avid RC
rangerjkb is offline   Reply With Quote
Old 02-15-2012, 10:34 AM   #21970
nmdesertracer's Avatar
Trader Rating: 58 (100%+)
Thats what john thought to about the 222 im still running 212.
Trailer Park Boys Racing!
nmdesertracer is offline   Reply With Quote
Old 02-15-2012, 10:36 AM   #21971
racing_jason's Avatar
the timing tab section is the same. it may seem slower because you dont have nearly as much of a "jerky" powerband now.
Thanks Jason
Thank you to my sponsors-
Team Associated-Reedy-ProLine-B&B Hobbies Racing
racing_jason is offline   Reply With Quote
Old 02-15-2012, 11:36 AM   #21972
macdude's Avatar
Why not just give the option of adjusting the feel. Like others have brake frequency adjustment. Or is that what the "active braking" adjustment is?
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 02-15-2012, 12:17 PM   #21973
EskimoGangsta's Avatar
Send a message via AIM to EskimoGangsta Send a message via MSN to EskimoGangsta Send a message via Skype™ to EskimoGangsta
He said he wasn't going into details
Their fixing it to the way we want. i think we should leave it at that
Live, Laugh, RC
EskimoGangsta is offline   Reply With Quote
Old 02-15-2012, 12:37 PM   #21974
Team Tekin
Randy_Pike's Avatar
It's not that simple. I realize that might not be the answer you want but that's the answer I'm willing to give. Time and time again we've educated our competition, we've learned to keep the details quiet.
Old 02-15-2012, 12:40 PM   #21975
Buckaroo's Avatar
Fair enough.
Time line on release (pending ROAR approval)?
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
