Old 01-08-2012, 11:49 PM   #21661
Hello,
is a tekin RS (non pro) good for touring car racing in 13.5t blinky ?
no over heat ?
thanks
shiver750 is offline   Reply With Quote
Old 01-09-2012, 12:16 AM   #21662
WildManDriving's Avatar
Trader Rating: 29 (100%+)
Originally Posted by shiver750 View Post
Hello,
no over heat ?
thanks
Running Boosted 13.5 in touring car I've had no heat issues.
. . . - - - Now enjoying Proline tyres - - - . . .
Scale race models: RCHobbyzone, Mugen, Reds, Xpert, Contact, Neo+.
Toy cars: Xray T4'15, Hudy, Nosram/Muchmore, Protoform.
No longer defined as a Off or On-road racer, but simply a RC enthusiast.
WildManDriving is offline   Reply With Quote
Old 01-09-2012, 08:54 AM   #21663
Suteki's Avatar
Excuse my ignoance but i have been trying to find more information on boost and timing advance.
I have an rs pro + 17.5 redline (bought pro to grow into with lower turns at some point) but i cant find out too much about what boost actually does, or atleast how much to apply and how it relates to start and end rpm. I need something pretty laymen here as far as explanation as this is the first touring car i have built so i am still getting my head around the electronics.
Also what is 'blinky' mode peopleare referring to?
Suteki is offline   Reply With Quote
Old 01-09-2012, 08:58 AM   #21664
Team Tekin
TY@TEAMTEKIN's Avatar
Take a look at the software guide a wrote up for programming the RSPro and if you have more questions just ask. Check out the Timing Section at the bottom.
RS HotWire Guide
Blinky mode means no Timing or Boost is allowed in the ESC, it's basically a spec stock setting.
Ty Campbell
TEKIN / TLR / SOR GRAPHICS / MIP / PROTEK / KALGARD / AVID
TY@TEAMTEKIN is offline   Reply With Quote
Old 01-09-2012, 09:29 AM   #21665
HighLife420's Avatar
Trader Rating: 49 (100%+)
Send a message via ICQ to HighLife420 Send a message via AIM to HighLife420 Send a message via MSN to HighLife420 Send a message via Yahoo to HighLife420 Send a message via Skype™ to HighLife420
Been chatting back and forth with 20smoke on my stock 2wd short course setup. Maybe you guys can chime in.
Im having problems on a 120ft straight. Ive been gearing for bottem and boosting for top. However, this left me with a really hot motor. If i were to loose the turbo, i get burned on the straight.
Yesterday i switched from 24/75 to 28/75, seems better on the straight, but it lacked a bit of pull to make a quick run-up to a triple.
28/75
50 boost @ 5k-15k
6 turbo, 1 ramp.
12 end bell
Pulled off the track after 8mins at 165. Was too high for my liking and just lacked a tad bit of bottom end.
then i tried...
27/75
Max boost @ 5k-15k
6 turbo, 1 ramp
10 end bell
Bottom end is pretty much good, however my top end is still not quite there. I stop pulling on the straight about 20-25ft before the end of it, in that time people pass me about 1-2 car lengths.
What you guys think?
Dominic "Dom" Chin
TLR 22 (Tekin RS Pro, LRP X12 7.5t, Savox 1258TG)
MIP Pro4mance SCTE (Tekin RX8, Tekin Pro4 4600kv, JR Z9100s)
Ko Propo Eurus (EX10) Limited Edition
HighLife420 is offline   Reply With Quote
Old 01-09-2012, 09:37 AM   #21666
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
28/75
50 boost @ 5k-15k
6 turbo, 1 ramp.
12 end bell
then i tried...
27/75
Max boost @ 5k-15k
6 turbo, 1 ramp
10 end bell
Go from max boost to 50, turbo to 12. ramp rate 2.0.
165 is fine for motor temps, any lower and I'd say you're not pushing.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 01-09-2012, 09:37 AM   #21667
Krio's Avatar
Trader Rating: 150 (99%+)
28/75
50 boost @ 5k-15k
6 turbo, 1 ramp.
12 end bell
then i tried...
27/75
Max boost @ 5k-15k
6 turbo, 1 ramp
10 end bell
Try extending your rpm range from 15k up to 20k. Keep full timing boost and drop back down to a 25 or 26 tooth. I literally just helped someone this weekend who had their motor coming off the track over 180 degrees and their timing ramp was 3k start and 15k end. Moving to 3k start and 20k end dropped 20+ degrees off the motor and he said it felt even stronger.
www.kriostasis.com
Krio is online now   Reply With Quote
Old 01-09-2012, 09:44 AM   #21668
with the 27/75 setup or 28/75 setup? What end bell timing? What turbo delay?
BTW, running a 13mm rotor.
thanks for the advice guys, will try this again and see...
Could i go to a 27/78 to get the same FDR as 26/75? Just curious....would it end up the same overall performance or does it make a difference gaining in the spur?
Dominic "Dom" Chin
Old 01-09-2012, 10:13 AM   #21669
The end fdr is the same really, doesn't matter which way you do to get to it.
There is a weight distribution problem if you use a big heavy pinion.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 01-09-2012, 10:14 AM   #21670
Team Tekin
Randy_Pike's Avatar
Yeah the gearing is too close to matter. I was posting based off the 2nd setup.
Old 01-09-2012, 10:28 AM   #21671
Thanks, will give it a try and see.
How about the turbo delay? I was bringing it in at .5s...however, if i set it to zero, i still have .1s till the first ramp kicks in correct?
Any thoughts at making the turbo delay in .1 increments?
Dominic "Dom" Chin
Old 01-09-2012, 12:50 PM   #21672
M-Technic's Avatar
Trader Rating: 15 (100%+)
The increments are 0.05/s for the turbo delay. I would think in offroad you would run a 0.2-0.3s turbo delay, but I am not sure.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 01-09-2012, 01:12 PM   #21673
Bah, sorry i mistyped that...
i meant in 0.01s increments.
Im just thinking about it, and i could have it set so low that it kicks in before i hit top rpm, prob would cause me to heat up quick.
Dominic "Dom" Chin
Old 01-12-2012, 08:49 AM   #21674
Hi, I need suggestion for my 1/10 TC 11.5t setup. Running Orion vst pro stock motor with tekin RS pro. I ran Hara's 11.5 setup with 5.9 FDR and stock timing on the motor can, but it seems I need to push it more. Motor temps is only below 150F after 8 min runs. What change should I make?
This is the track I'm running on, the size is about 35x20 meter
Wilson Picaldy is offline   Reply With Quote
Old 01-12-2012, 11:30 AM   #21675
Team Tekin
Randy_Pike's Avatar
How are your laptimes? If it's fast and cool leave it.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
