Old 12-21-2011, 11:22 PM   #21601
wollow86's Avatar
Originally Posted by wollow86 View Post
I'm sure I read somewhere in a rule book that ESC settings cant be changed wirelessly or where the car is on the track. I don't remember what rule set it was (either ROAR or AARCMCC), but I'm sure I remember something about that...
Originally Posted by syndr0me View Post
I don't think the ESC has a radio in it. The radio is in the connecting device, and exposes it via BT or WiFi.
No it doesn't, its an optional adapter. I found it, its in the AARCMCC rules (I couldn't find any mention in ROAR but maybe i'm not looking in the right place)
Its point 9.4.5, Basically says that you cant make adjustments to the esc while the car is on the track.
I look forward to seeing what tekin brings out in 2012.. I see a new ESC in my future so my current RS can be a "backup". As for feature suggestions, how about making them easier to sell to wives?
Supporting Aussie hobby shops:
- www.MRJRacing.com.au - - www.feralbatteries.com.au - - www.actionrc.com.au -
wollow86 is offline   Reply With Quote
Old 12-21-2011, 11:33 PM   #21602
Drillit's Avatar
Location: Oreganastan Pacific Wonderland home to Indoor Farming
Originally Posted by ByteStream View Post
But I'd bet it will run mod competitively.
Hmm .. typical fanboy response of "if Tekin didn't make it, it's crap". The speedo is not even released yet .. so hold your judgement. Tekin customers have been asking for a different programming method sans laptop for a while .. and if someone else does it, it's a gimmick?
oops, sorry, didn't see you on the first sp page, or follow-up to where I 'had' to 'change' speedo to remain in-the-hunt in 12th boosted classes. Yes, times are a changin'. Good Luck to all.
Mark Tilley
Got T-Bar ? ......... Oregons No ZigZag rule sucks
Bias the weight to the end you want to hit the wall with first!
Searchin fer answers in the Fog.......that's what I found
Drillit is offline   Reply With Quote
Old 12-22-2011, 03:33 AM   #21603
Drillit's Avatar
I Know what Adam and Shawn can get us for Christmas! How 'bout a esc with "built in" cell link, so they can "BEAM" us up the next profile anywhere, anytime?
I finally cleared space in the pit bag, you know , the space and weight of a third charger, discharger/conditioner, brushes, comm lathe........only to find a safe space for a 'netbook'.........
quoting myself from 12-24-2009 sp thread, Really?, 2 years? I do apologize to Randy and Tekin for this thread jacking, I'm still the goofball from 2010 paved nats with the sp stickers on my rs pro in the 12th t-bar car with the Jacked up 1cell across the t-bar. Randy thought it funny at the time.
Mark Tilley
Old 12-22-2011, 05:51 AM   #21604
I have a issue with my1 month old rs pro, I have used it for 1 race days and two practices and I have issues with it not beeing able to connect to the radio, I get the leds flasshing saying weak radio signal, I run a 4PKS and have swaped resiver after the first time and now it happened a second time, any ideas?
Or do I have to go back to my SP that i used for 2 years without a radio issue?
chovden is offline   Reply With Quote
Old 12-22-2011, 06:52 AM   #21605
ByteStream's Avatar
Originally Posted by Randy_Pike View Post
Byte your avatar shows where you stand I suppose.
Regardless gimmick are features in some peoples eyes.
Our customers requests and opinions don't ever fall on a deaf ear. 2012 will be another great year for Team Tekin.
Randy, my avatar is all in good fun, I was going to make a T-shirt out of it, I'll send you one if I do ..
I honestly hope Tekin does have a great 2012 if that means that we will see some new products from Tekin that address customers requests. Send me a pm when that 1S w/built in booster is ready to hit the market and I'll pre-order one and I promise I won't call it 'gimmicky' until I have tested it out and evaluated it first-hand.
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 12-22-2011, 07:45 AM   #21606
Originally Posted by dark_luna View Post
I like some help with my esc setup if its possible to tweek it futher?
No problem with motor heat after 5min race.
This is what Im racing
Car: Kyosho TF-5 Shin
Tire: Rubber Slick Sorex 28
Gear ratio: 5.99:1 - 6.59:1
Battery: 2S 45C Lipo
Motor: Novak Ballistic 17.5T (Stock timing)
ESC: Tekin RS Pro
Track: Carpet indoor medium grip medium size
Current Version: 212
Brushless Forward Only with Brake
Voltage Cutoff: 2S
Drive Mode: Sensored Only
Motor Direction: Normal
Throttle Profile: 5
Current Limit: 90
Throttle Min: 5
Drag Break: Off
Brake Strength: 65
Reverse Speed: Off
Neutral Width: 3
Push Control: Off
Brake Min: 0
Timing Advance: 80
Boost: 50
Start/End RPM: 4084/9002
Turbo: Max
Turbo Ramp: 3
Turbo Delay: 0.02
No one?
dark_luna is offline   Reply With Quote
Old 12-22-2011, 07:59 AM   #21607
ESC: Tekin RS Pro
Voltage Cutoff: 2S
Throttle Profile: 5
Current Limit: 90
Throttle Min: 5
Drag Break: Off
Brake Strength: 65
Reverse Speed: Off
Neutral Width: 3
Push Control: Off
Brake Min: 0
Timing Advance: 80
Boost: 50
Turbo: Max
Turbo Ramp: 3
Turbo Delay: 0.02
I haven't used a Novak Ballistic, and it has been some time since I've run Tekin, but this is what I would do:
Current limit: 100 / Off (No need to lower this for 17.5T)
Start RPM: 3k-5k
End RPM: 12k-15k
Boost: 50-55
Turbo: 10-15
Turbo delay: 0.15-0.2
Timing Advance: 100
I will much rather have more boost than more turbo. When you let off the throttle coming from full throttle, with high turbo it will feel like your car has a lot of drag brake. And in the in-field, if you hit full throttle, you can easily miss the apex.
With the timing on the boost instead, it should be a lot more smooth. And with the bigger range, it will be even smoother. And remember: Smooth is fast!
The turbo is mainly for the straight, so IMO no need for it to kick in as soon as you hit full throttle. Let the motor use it torque a little, and then use the turbo. So delay of 0.2 is fine on most tracks (IMO).
Timing advance should only kick in when the sensors are gone, but I have heard some people feeling a difference even when the sensors are functional. I have always used 100 though.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 12-22-2011, 08:07 AM   #21608
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
http://www.teamtekin.com/rs_troubleshoot.html
what one are you getting low or high signal
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 12-22-2011, 08:49 AM   #21609
M-Technic's Avatar
Trader Rating: 15 (100%+)
So that means you leave the wifi/bluetooth adapter off the ESC when you are on the track. Maybe they will tech it to make sure the adapter isn't attached. That rule doesn't make the ESC illegal.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 12-22-2011, 08:51 AM   #21610
Low signal
Old 12-22-2011, 09:38 AM   #21611
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Make sure your transmitter is fully charged. Futaba radio systems will not fully turn on without it.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 12-22-2011, 09:48 AM   #21612
So the steering servo is working and resiver showing a steady green light, this should be good enogh, as of now I don`t fully trust it as I lost a qualifier first time it happened and it took me a while before I knew what happened, last time now it was the first battery of the day si did not matter to much but I worry next tima is befor a important qualifier of final and I might loose a race due to this
Old 12-22-2011, 01:13 PM   #21613
Team Tekin
Randy_Pike's Avatar
Booster or RX Pack?
Old 12-22-2011, 02:14 PM   #21614
Booster or RX Pack?
2 cell TC boosted stock, always fully charged when it happens
Old 12-22-2011, 11:15 PM   #21615
Skitee's Avatar
Have you checked the ESC signal wires and plug which plug into the receiver ?
A while back I had a issue with an intermittent glitch and the car just stopping on track, I found the problem when I had the car back on the bench and moved the ESC wires and the ESC would show the low signal LED's. It was the white wire which had snapped but the plastic didn't break, everything has been fine since i wired on a new plug.
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
