Old 12-18-2011, 02:46 PM   #21571
Yeah I hear Apple makes a mean product. I for one am a Linux guy and if I could get Hotwire to work in Wine I would. However, it needs .Net 2.0 and Windows installer 3.1. Both of which are total junk and will not run in Wine. Oh well I guess it looks like I will be going with Speed Passion when the new one comes out.
Mr Granone is offline   Reply With Quote
Old 12-19-2011, 01:24 PM   #21572
Hi guys,
I have recently picked up a Speed Passion 1 Cell 10.5 motor.
I am going to be running it boosted in a 1 Cell WGT car with a tekin RS pro.
Can you guys recommend a rollout and any setting for the Tekin?
Cheers
Chris
http://rcgtpancars.blogspot.com/
chris_blakey is offline   Reply With Quote
Old 12-19-2011, 05:24 PM   #21573
ShadowAu's Avatar
Yup... Linux is just so well written that some distributions can't even mange to change the system time and date without resorting to half a page of terminal commands...
Don't see what you are trying to gain by coming on here and trying to blame your PERSONAL computing choices and your next product purchase on Tekin
I am quite content with doing what I do
Don't mistake not being happy for unhappiness - its not the same thing
ShadowAu is offline   Reply With Quote
Old 12-19-2011, 07:55 PM   #21574
Trader Rating: 19 (100%+)
Hey Guys, I blew up one of my RS esc's and was wandering how much it costs to send it back and have it fixed and also could i upgrade it to an RS PRO for an added cost. Thanks!
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 12-19-2011, 08:07 PM   #21575
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
yes you can upgrade its all on the service form,fill it out and GET A RA# before sending it in,contact randy or the tekin for one.http://www.teamtekin.com/Forms/6-10-...EST%20FORM.pdf
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 12-19-2011, 08:32 PM   #21576
thanks! and will it allow me to pay using paypal?
★Randy Banks★
Old 12-19-2011, 10:42 PM   #21577
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Sorry No paypal...
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 12-20-2011, 04:36 AM   #21578
wollow86's Avatar
Originally Posted by wollow86 View Post
I'm ordering a epic d3 to run in 17.5 boosted TC, just wondering if anyone can tell me what my setup will be like compared to my current tekin redline? More or less gear/boost/turbo/delay? Or will my profile for the redline work the same on the d3?
No tips?
Supporting Aussie hobby shops:
- www.MRJRacing.com.au - - www.feralbatteries.com.au - - www.actionrc.com.au -
wollow86 is offline   Reply With Quote
Old 12-20-2011, 05:13 AM   #21579
Trader Rating: 20 (100%+)
No tips?
when I had my redline I was at 5.5fdr with less bost and turbo. With the D3 I ran more boost and more turbo with a 6.2fdr with almost the same temps as the Redine . 6.0 - 6.5 should be a good range for the D3 17.5
goots is offline   Reply With Quote
Old 12-20-2011, 05:13 AM   #21580
20 SMOKE's Avatar
No tips?
try one of the setups on tekins site
Jamie W
Old 12-20-2011, 05:42 AM   #21581
wollow86's Avatar
To be honest on the main track I run they haven't been much help. To give you an idea I'm currently running 40 boost and 20 turbo with an FDR of 5.18... Which from what I understand is pretty argessive settings. Depending on air temp the redline comes off the track at about 85c after 6mins.
The info above helps me more that a d3 likes a higher fdr then a redline. Is that to do with a higher internal timing or something in the d3?
The biggest problem I have with my current setup is the second I get off the power (while in turbo) the car feels like I've used an off switch, not a throttle trigger, hoping the new software helps that when it comes out .
Thanks guys.
Old 12-20-2011, 06:09 AM   #21582
Skitee's Avatar
@wollow86
I've tried running similar timing setups to what you have with lowish boost and really high turbo and to me it just never felt comfortable or easy to drive, I'd say that the amount of turbo you're running is driving up the motor temp and is the main reason for the switch like feel when you're coming out of full throttle.
Why not try something like this and see what it feels like.
Boost : 52
Turbo : 15
Start : 5k
End : 17k
Delay : 0.1
FDR : 5.68
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 12-20-2011, 07:06 AM   #21583
M-Technic's Avatar
Trader Rating: 15 (100%+)
Thanks guys.
That's because turbo is on a time-delay, and when you lift, it disappears completely (unlike timing boost). Try 50 boost and 10 turbo, which is the same amount of timing overall, but it won't feel like a switch when you lift. If it still feels like a switch, stretch out your RPM range for the boost timing (i.e. raise your end RPM).
I doubt the new software would have any affect on that, as it is more of a setup issue than an ESC issue.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 12-20-2011, 11:49 AM   #21584
Team Tekin
Randy_Pike's Avatar
Thanks guys.
Your high amount of turbo is causing this. You should not need 20 turbo. Raise boost to 50, lower turbo to 10. The car will be just as fast if not faster and temps will come down.
Old 12-20-2011, 01:38 PM   #21585
wollow86's Avatar
Thanks guys, I'll give that a try. I'll be doing testing early in the new year, I'll let you know how it goes.
One question though. The above suggestion of 52/15 5.6 fdr, gives a total of 67* of boost. I thought that there was a limit of 65 before you went over to the next phase of the motor?
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
