Tekin RS ESC sensored
I don't see why people have such an issue with taking a laptop to the track. I've got so much info saved on mine I want to take it. I've got all my manuals in PDF.
I'd like to see the Hotwire software be capable of saving setups so I can just load a file from my laptop, or save it to my laptop before I make changes so that I can easily go back to my standard settings.
Leave it as a "hotwire" interface where something has to be plugged into the ESC. That way if people are cheating, you'll see the hotwire plugged into their car.
Cheaters will find a way to cheat with bluetooth or not.
profile c1
boost 50
turbo 10
start 5000
end 20000
ramp 3
delay 0.3
neutral 10
drag 20
etc. Then you could manually have copies of settings and easily cut/paste into a simple text document. Human readable, able to be posted on web pages, etc.
Not being able to save, import, and export settings has always been a pet peeve of mine with the Hotwire software. That and the interface. Why can't I import someone's settings? Writing down esc settings on a PDF seems so antiquated; you could easily export it to a text file, call it .tek and we would all be uploading and sharing our ESC Setups much easier.
As for cheating and Bluetooth, etc, easiest thing is if there is going to be a non-boost blinky class it should only allow non-updatable speed controls. All "blinky mode" has done is now given people the suspicion that the guy that just out motored them has "hacked" the software.
I've stopped running Tekin in my spec cars for this very reason.
Or if not the ability to save setups, the ability to read a simple text file that contains various settings, something like:
profile c1
boost 50
turbo 10
start 5000
end 20000
ramp 3
delay 0.3
neutral 10
drag 20
profile c1
boost 50
turbo 10
start 5000
end 20000
ramp 3
delay 0.3
neutral 10
drag 20
I know everyone will be pleased with the version after it is released
esc
It would be nice if tekin had a way to plug in the hotwire without having to unplug the wire from the receiver. In offroad and some onroad cars its a real pain in the neck tp access the receiver in a box when the ESC is setting in the open. I remember at 1 time Novak had a place to tune the ESC with a micro usb. Any thoughts?
Pleased to see we are moving back "on topic".
Peter
Peter
Team EAM
EA
You still have to unplug it from the extension which puts wear and tear on the plug and increases the likelyhood that a pin will not plug back in good...not to mention it is messy. I too would rather have a port on the ESC (or on the switch like the Viper) to plug the Hotwire into instead of the servo lead.
It's amazing how much adding a simple 3" servo entension relieves any trouble from accessing the RX to program the ESC.
Edit:Beaten to the punch!
Worried about wear and tear on the connector? Really? Do you program the ESC that often? For most normal humans, it's installed in the car, played with somewhat early on to get things close, and only fiddled with once in a while after that.
If anything does go bad, you you can open the case and solder in a new wire harness very easily. In fact, it's a common mod to upgrade the harness to larger wires and to open the hole in the case to prevent crimping of the wires that causes wire breakage.
By your logic, one more port is one MORE connector to worry about failing.
+1
the plastic will easily hold up, its the wire i would be worried about.
With the extention, you can grab it by the plastic and not by the wire, lasts much longer.
