Tekin RS ESC sensored >
Old 12-02-2011, 09:27 PM
  #21391
Team Tekin
Randy_Pike's Avatar
Originally Posted by Bobinmt View Post
My RS has the first two and last two lights flashing and the motor wont go unless I give it a little help by turning the wheels. It ran fine the first two races and then wouldn't run for the third? According to the Tekin website this error code could mean that I have the wrong motor selected but when I checked it with my hot wire it is set for brushless. I've tried a new booster, receiver, sensor wire and a known good motor with no avail? Any ideas or help would be greatly appreciated..
Bob
Also if I turn the switch for the speed control on first the lights flash correctly on the speed control. If I turn the booster on first it flashes with the error code I noted above, but either way it wont run!
If you get this issue grab a 2s and power the esc up with it. IF the issue goes away your rx booster or rx pack isn't supplying enough voltage.
Randy_Pike is offline
  #21392
Team Tekin
Randy_Pike's Avatar
Originally Posted by freakyfreakyflo View Post
hello
i recently find a tekin rs and want to start it in my f104. i am new to boost and timing feature so could someone share a good startup setup for pancar. our surface is low/medium grip.
many thanks
What motor?
Old 12-02-2011, 09:44 PM
  #21393
Originally Posted by Randy_Pike View Post
What motor?
sorry,forgot to mention that. murfdog 21.5. thanks
freakyfreakyflo is offline
Old 12-02-2011, 11:00 PM
  #21394
Josh-n-ya's Avatar
Trader Rating: 78 (100%+)
Just want to Thank You Tekin! I just installed the Hotwire with no problems. Now Im ready to learn and play. I now need some good set ups for WGT and 12th mod. thanks!
Josh-n-ya is offline
Old 12-03-2011, 01:01 AM
  #21395
ROBORAT's Avatar
Answers huh? Well what I am willing to admit is that our current hardware is nearing 4 years old. We at Tekin believe it's time for some new products. That's all I'm willing to share at this time.
Tekin fan here .... if and when the new hardware comes out, if you keep it to the same size/footprint, develop a program box to eliminate the need for a laptop, and keep to the performance standards tekin provides, you'll surely blow the competition away!
... Eagerly awaiting!
ROBORAT is offline
Old 12-03-2011, 12:23 PM
  #21396
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
What size wire should I use for Blinky 17.5 TC?
dr_hfuhuhurr is offline
Old 12-03-2011, 01:20 PM
  #21397
Team Tekin
Randy_Pike's Avatar
12 to 14 awg wire should be fine
Old 12-03-2011, 05:56 PM
  #21398
VexVegaz's Avatar
OT: hey Randy, congrats on that KO propo sponsorship. im a sanwa type of guy, but KO makes some of the greatest control systems in the industry.
VexVegaz is offline
Old 12-06-2011, 11:42 PM
  #21399
hello
many thanks
does anyone have any tips? thanks
Old 12-07-2011, 03:36 AM
  #21400
tc3team's Avatar
I don't run F1, but what size track are you racing at? (this might help someone else give you a starting point).
Also if you are using foams, obviously gearing will play into the setup too, as they wear down.
The cars are quite light so you might need to use less boost than other classes but again it really depends on track size and the length of the straight and so on....
As for delay. I would possibly try 0.3 as a starting point, ramp 2 and go from there but it is a guess. Watching motor temperatures is also a key point.
tc3team is offline
Old 12-07-2011, 09:01 PM
  #21401
Default Up in smoke
Mixed up my battery leads and smoked my tekin I heard some one say that all you need to do is replace the Capacitor and your golden. thanks.
Associatedkid is offline
Old 12-07-2011, 11:10 PM
  #21402
Team Tekin
Randy_Pike's Avatar
IT's possible but don't hold your breath. Replace the cap and power it up, if it works consider yourself lucky, you dodged a bullet.
Old 12-08-2011, 02:43 AM
  #21403
our track is old car park so low grip with lot of corner and small straight. i use rubber tire with weight at 1100 gram
Old 12-08-2011, 07:31 AM
  #21404
jasons56's Avatar
This is also not true, at least with Tekin. All of our drivers know up front that they will share their setups with the public after the event is over. Part of being on our team. Believe it or not..your call.
I believe it. We occasionally get some national event winning drivers at our track and sometimes I even get to race against them. When I've stuck to the posted setups I've never felt like these guys had any power advantage on me. The dirty secret, sometimes they DETUNE the cars for less power at the smaller events when the traction is not up to par.
Now blinky class - don't get me started.
jasons56 is offline
Old 12-10-2011, 05:36 PM
  #21405
alcyon's Avatar
Default specs
my damn hobbywing just blew on me. you buy cheap you buy twice is so true. i am seriously considering a tekin RS pro, but whats puts me off all ESCs nowadays is the information on the website, they dont list everything i want to know. like on the tekin website, there is only 1 page showing the RS and RSpro together, with basic specs. i wished they would have one complete page for the RS, and another for the RS pro, with ALL the info on them, like info about boost and turbo also. What is the weight of the RS pro without wires ?
alcyon is offline
