Old 11-23-2011, 02:04 PM   #21346
Jsaves's Avatar
Sorry,
You do need that info
17.5 blinky
Proud member of Magic City RC Racers
Magic City R/C (Facebook)
CRC GT-R
CRC WTF-1
Jsaves is offline   Reply With Quote
Old 11-23-2011, 02:20 PM   #21347
YoDog's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Jsaves View Post
Hey Guys,
Is using TQ 16 gauge wire for the connection from the battery to the esc good enough or should I go bigger?
Thanks and God Bless
A good rule of thumb would be to run at least 2 gauges bigger wire for the battery as you would use for the motor because the battery carries all of the motor load and the motor wires share the load across the 3 phase wires. The current is pulsating per the phase output of the speedo thus the duration at which the wires carry the current is approximately 1/3rd than that of the battery wires which carry the sum of all 3 phase pulses. Since you are running blinky mode, you will want to deliver as much current as is demanded by the motor as efficiently as possible. Smaller gauge wire will have an effect on "punch".
YoDog is offline   Reply With Quote
Old 11-26-2011, 11:16 PM   #21348
Trader Rating: 19 (100%+)
Originally Posted by 303slowdown View Post
COLD AS ICE. If you find out what the problem is please post cause I'm having the same issue. It started with a 5.5 so I put a 13.5 in and same problem so I put thicker wires on and same problem all with no timing so I'm out of ideas.
Found it! I was experimenting today and wednesday and tried changing the motor, no help, changed the plugs to the batt. no help, used a bigger C pack, no help, went to a 12 gauge wire from a 14...... FIXED!! I also turned the timing down about 4 degrees and the turbo down 2 and turned my start rpm up to the next one on the list from what i was already running.
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 11-27-2011, 01:03 PM   #21349
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
so had my 12th scale out last night with tekin rs and lrpx12 17.5 turn. confused about what rs settings to use for it as i just couldnt get it to work like my tekin 17.5 motor.
im running the 4 dot insert which is recommended by most, but is that in fact the 27.5adv that some people say, or less? i tried running 20boost, 10 turbo ramp 2 but the car just didnt rev well at all. the onjly settings that seemed to work at all was 15ish boost and max turbo. but wouldnt that go over into the next phase?
wish i could just run the motor at zero advance. put my tekin back in for now. was running 48 boost 12 turbo on that and my only complaint was lack of punch coming out of corners. was as fast as anyone in the straight.
if anyone has advice on setting up both motors, would be great. dispite the lower top end, the lrp seemed a lto more responsive where my tekin had smoother power delivery.
valk is offline   Reply With Quote
Old 11-27-2011, 05:09 PM   #21350
M-Technic's Avatar
Trader Rating: 15 (100%+)
I don't run 12th scale but you need to be running ~50 boost always in 17.5!
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 11-27-2011, 07:23 PM   #21351
OZDC's Avatar
Trader Rating: 16 (100%+)
Default MinimumTurbo Delay
I can't find it now but i recollect a post saying that below a certain point the turbo delay is equivalent to 0. I think the figure was .3. So that if you set your delay below that e.g .2 then it is actually zero.
Can anyone please confirm this and the value?
thanks
Dave
OZDC is offline   Reply With Quote
Old 11-28-2011, 01:55 AM   #21352
WildManDriving's Avatar
Trader Rating: 29 (100%+)
Hello,
I'm in need of two starting points for a SP13.5 v3 in a TC. The weekly track is a short, tight course and the monthly track is medium length, mostly open corners. Both tracks are low to medium grip.
Thanks in advance.
Michael.
. . . - - - Now enjoying Proline tyres - - - . . .
Scale race models: RCHobbyzone, Mugen, Reds, Xpert, Contact, Neo+.
Toy cars: Xray T4'15, Hudy, Nosram/Muchmore, Protoform.
No longer defined as a Off or On-road racer, but simply a RC enthusiast.
WildManDriving is offline   Reply With Quote
Old 11-28-2011, 05:20 AM   #21353
hi guys,
anyone recommend a setup for a Trinity D3 10.5 in a boosted WGT?
Cheers
Chris
http://rcgtpancars.blogspot.com/
chris_blakey is offline   Reply With Quote
Old 11-28-2011, 12:00 PM   #21354
Originally Posted by WildManDriving View Post
Hello,
Thanks in advance.
Michael.
What track in melbourne are raceing at.I have settings for most of them useing 13.5 v3
mcb-jet is offline   Reply With Quote
Old 11-28-2011, 12:15 PM   #21355
artwork's Avatar
Trader Rating: 62 (100%+)
Randy or team tekin-
Any idea when the software the team was running at IIC will be available to the public?
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 11-28-2011, 12:31 PM   #21356
Racing Boronia every Wednesday and Templestowe every chance I get.
Old 11-28-2011, 12:45 PM   #21357
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
nothing has been said on anything,far as i know no one has anything but 212
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 11-29-2011, 02:58 PM   #21358
Default ROLLOUT
I am looking for a starting point for rollout for 13.5 blinky and timing WGT 36'x70' tight-technical track. I am using a revtech 13.5 I would guess blinky timing @ full+ and for boosted 1-2 notches over the 0 mark would you use 6-8k and the lowest or next to lowest rpm in the esc? Any other recommendations would be appreciated.
slsspark is offline   Reply With Quote
Old 11-29-2011, 03:00 PM   #21359
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
To be clear nobody at the IIC had software available to them. I was changing throttle profiles in the background. I also only did this for guys NOT running a spec class of any kind.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 11-29-2011, 03:01 PM   #21360
I.T.Guy's Avatar
no one but teamdrivers?
I.T.Guy is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
