Old 11-19-2011, 12:46 PM   #21316
Originally Posted by Buckaroo View Post
Don't forget that most of oval has gone completely 1S!
No oval in Europe and not sure if it is raced in Asia or Australia, so still a smallish market I guess.
And yes to inspegadgt, 1/12th is a long running category that has been going up and down over many years (my first car was 1981) , I would love to be able to race 1/12 again, but no club near me.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 11-19-2011, 05:32 PM   #21317
ByteStream's Avatar
WGT is 1S as well.
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 11-19-2011, 06:12 PM   #21318
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
So has tekin came out with any new stuff or just profile info for the 4 pole motors?
I know it only goin for SC 1/8th so far but I see it comin to 1/10 also
Any info guys?
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 11-19-2011, 06:33 PM   #21319
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
no new software yet
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 11-20-2011, 12:38 AM   #21320
Pro10noob's Avatar
Depends in what country you are running it
We have 2 classes.
1 with 1S 10.5/13.5(not sure) and 1 with 2S and 17.5 motors.
They also run with the "big" boys 235MM and then it is 2S 10.5.
Last class isn't slower then the 235MM and on a tech track they have a advantage because they are narrower
regards Roy
Originally Posted by ByteStream View Post
WGT is 1S as well.
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 11-20-2011, 06:15 PM   #21321
Trader Rating: 19 (100%+)
hey guys, I have been having a problem and wanted to know if anybody had any ideas, I have been running a 6.5 with boost in 12th scale for about a week now and the positive battery lead keeps coming undone from the bullet plug. The confusion for me is this, the speed control itself isnt getting very hot, 3 LED's at the most i have gotten so far, today i switched the car back to 13.5 boosted and the battery stopped coming undone, but the speedo is getting unusually hot for a 13.5, like 4 LED's after a 6 minute run using Mike Dumas's setup from 2011 snowbirds. any help would be appreciated! Thanks!
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 11-20-2011, 07:00 PM   #21322
hanulec's Avatar
Trader Rating: 27 (100%+)
The problem is probably with your wire gauge or resistance. you NEED to run thick wires for modified.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 11-20-2011, 07:14 PM   #21323
like 12 gauge thick? Im running TQ 13 gauge now for my battery leads. Thanks!
★Randy Banks★
Old 11-20-2011, 07:35 PM   #21324
1M
1M's Avatar
Trader Rating: 35 (100%+)
the connector also can be warn out causing resistance. I have seen wires unsolder from esc because of the battery or ESC connector worn out.
1M is offline   Reply With Quote
Old 11-20-2011, 07:53 PM   #21325
Trader Rating: 21 (100%+)
TQ wire is the only wire I've ever run since they came out with no problems. Checking your soldering job.
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 11-20-2011, 07:59 PM   #21326
I have replaced the connector already and also resoldered both the esc and connector, the next thing im going to try is thicker wire as Mike H. said. Thanks for the help guys!
★Randy Banks★
Old 11-20-2011, 09:17 PM   #21327
Still Bill's Avatar
Truly, I have very high regard for TQ wire. Use it all the time.
But, just today, I witnessed a single 13 gauge motor wire on a pan car go up in smoke.
Motor wire that flexes between an ESC and motor in the rear pod can be more susceptable to being damaged. Especially, when solder makes a portion of the wire stiff so the flexing is localized to a specify section of the wire.
Sooooo...Consider changing out BOTH of your 13 gauge motor wires.
Otherwise, I was initially guessing that your cap could be bad; but, the wiring still seems more likely.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 11-20-2011, 09:28 PM   #21328
Bill
Thanks Bill, I now have a couple things im going to try if the bigger wire does not work. Glad I have spare caps. Thanks again guys!
★Randy Banks★
Old 11-21-2011, 05:21 PM   #21329
Andy w's Avatar
I have a problem with my RS and want to see if there is anything I can do. I was racing oval 13.5 1s on Saturday and bumped a wall. Now when I say bump I mean a slight bump nothing to bad. Right after the him my car shut down. After taking it over to the pit and playing around with it this is what I found.
When I turn it on the ESC lights up as should but there is no chime that all is good. I get no motor response at all but the lights are showing that all is well and ramp up on throttle and so solid with brake, but nothing happens. The servo works and volt booster shows that it is working. I also changed the motor and rx and still nothing. I am guessing my RS is gone but am hoping someone might know how to revive it.
BTW, I also tried to rebind and recalibrate my esc with no result.
Andy w is offline   Reply With Quote
Old 11-21-2011, 06:16 PM   #21330
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
No chime can be caused by a few things. The chime is made by the motor actually. Try using a 2s pack. This eliminates most of the issues that could cause this problem externally.
If this still occurs, unplug the sensor harness from the esc side, power up. Chime or no chime?
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
