Tekin RS ESC sensored
In 1s racing, has anyone experienced the turbo not coming on after two or three minutes into the run? I run on a small track about 65 by 35 or so. We dont use the delay for the turbo because the straight is so short and the size of the track. Here's my set-up:
CRC Wgt car
Tekin 13.5 motor w/12 degree's mechanical timing
Tekin RS
boost start 750
boost end around 3800 (if I remember correctly)
turbo delay is 0
boost is about 40
Revtech 5600 1s 60c battery
We are running 6 minutes, and I don't experience any problems until 3 minutes into the run. The motor comes of between 115 and 12o degrees. So if the motor isn't hot, I wouldn't the speedo would be either. Any ideas on this?
CRC Wgt car
Tekin RS
boost start 750
turbo delay is 0
boost is about 40
Dead RS ESC
Does anyone know how to repair a dead RS that has been plugged in reversed polarity ?
little help with boost setup
Hey guys. Just trying to get my head around a few thing with the esc. Mainly RPM ranges.
How do you figure out what end RPM you should set? I've figured out that the end rpm and boost amount dictates what start RPM options are available, and that the lower the end rpm (and closer to the start rpm) the faster the boost comes in.
What effect does the speed the boost comes in at have on heat? Is a longer period better for lowering heat? What is too much rpm to set as an endpoint?
Here's my current setup:
Tekin RS / Tekin Redline 17.5 / Boosted Stock TC
Motor: 0
Boost: 45
Turbo: 10
Turbo Delay: 0.3
Turbo ramp: 2
Start Rpm: 5000(ish)
End Rpm: 12000
FDR: 5.73
Temp after 5min race: 78*C
I'm going for a little more top speed here, and sacrificing some punch. Smooth through the infield and big top speed for the massive straight is what works at our track.
Thanks for the help
Motor: 0
Boost: 45
Turbo: 10
Turbo Delay: 0.3
Turbo ramp: 2
End Rpm: 12000
FDR: 5.73
Thanks for the help
Motor: 0
Boost: 45
Turbo: 10
Turbo Delay: 0.3
Turbo ramp: 2
End Rpm: 12000
FDR: 5.73
Thanks for the help
Motor: 0
Boost: 45
Turbo: 10
Turbo Delay: 0.3
Turbo ramp: 2
End Rpm: 12000
FDR: 5.73
Thanks for the help
Track is 52m x 37m. designed for up to 1/5 scale cars. I was still lacking some speed down the straight, maybe another 10* turbo would have done it, or another tooth on the pinion, but i ran out of motor temp to play with.
I was hoping increasing the rpm end might help bring the temp down so I could add a little more.
Motor: 0
Boost: 45
Turbo: 10
Turbo Delay: 0.3
Turbo ramp: 2
End Rpm: 12000
FDR: 5.73
Thanks for the help
Motor: 0
Boost: 45
Turbo: 10
Turbo Delay: 0.3
Turbo ramp: 2
End Rpm: 12000
FDR: 5.73
Thanks for the help
boost 35
turbo 15
I feel that more turbo and less boost works great on big tracks
Steven
Hi,
Could someone give me a good start with a Tekin RS Pro and A 10.5T motor, for a small track to run my TRF417. I need boost.
Thanks !
Thanks !
Hope this help to start with.
Amuse toi bien et surtout verifie la temperature et met un ventilo si il fait chaud sur le moteur.
A+
Wollow86 setup above is good as a base, just run max rpm at around 20000 and min 5000 fdr at 7.50ish for a 10.5t, HT PRT might be better for a shorter track but not a necessity, you can set it via the speedo.
A+
A+
J'ai deja un HT, mais je vais essayer le HS
I have an issue about half-way into the race where my power just drops significantly(losing about half a sec a lap in avg). It's not that "I lost my turbo issue" because the turbo is still there. Just losing punch in the entire power band. My SP MMM motor is temping at 140F, and the esc is about 110F. I was suggested my batt might suck, but I noticed this with my TP 40C, gensace 40C, and the new orion 90C (all 5000mah). There are guys running similar setups with little loss in power. What could be happening
Jason
