Old 09-10-2011, 06:45 AM   #21061
onekiwi's Avatar
Originally Posted by idbdoug View Post
Try this better version of the original::::
http://search.digikey.com/scripts/Dk...231-nd&x=0&y=0
idbdoug
thanks but I have a losi lying around, could I use it? I actually have 2 originals on the way just keen to get it up and running
And the shop in the link wants $30 to ship a $3 item
onekiwi is offline   Reply With Quote
Old 09-10-2011, 07:12 AM   #21062
idbdoug's Avatar
Trader Rating: 33 (100%+)
[QUOTE=onekiwi;9639367]thanks but I have a losi lying around, could I use it? I actually have 2 originals on the way just keen to get it up and running
AAhh,didn't notice Sweden as the location
idbdoug is offline   Reply With Quote
Old 09-10-2011, 07:19 AM   #21063
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
thats a 10v needs to be a 16v
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 09-10-2011, 07:26 AM   #21064
idbdoug's Avatar
Do you need 16v for a 7.4v battery???
idbdoug
Old 09-10-2011, 07:50 AM   #21065
onekiwi's Avatar
how do you know the specs I can't find them anywhere
Old 09-10-2011, 08:42 AM   #21066
idbdoug's Avatar
Here is the original cap specs:
http://search.digikey.com/scripts/Dk...me=565-3233-ND
Here is a 16v Cap with slightly better specs:
http://search.digikey.com/scripts/Dk...me=565-3234-ND
After further thought,,stick with original caps. We have been experimenting with different caps for better performance, but i won't recommend putting one on your tekin just in case something goes wrong
Old 09-10-2011, 10:41 AM   #21067
SteveP's Avatar
Originally Posted by EAMotorsports View Post
Well hopefully that's true. But a few emails Ive seen say otherwise. Guess we shall see in a few months.
EA
Eric, cmon, I thought we put this stuff behind. You're not getting emails from anyone with any knowledge of what's happening, because if they were "in the know," they would know that a vote hasn't taken place, and a lot of discussions are still ongoing.
SteveP is offline   Reply With Quote
Old 09-10-2011, 10:57 AM   #21068
What would grown men racing RC cars be without drama...
adam lancia is offline   Reply With Quote
Old 09-10-2011, 11:02 AM   #21069
Infinite 12th's Avatar
Relaxing and bringing racing to higher level
12th scale - The Jedi class...
Infinite 12th is offline   Reply With Quote
Old 09-12-2011, 11:26 PM   #21070
BoneCrusher's Avatar
Just getting back into the indoor season soon. Havenít played around with a tekin in over 6 months. I donít remember but can you use the Hotwire to change settings in the software to say compensate for physical timing on the motor?
Thank you for your time,
Ivan
ARC R10, 12R5.1, Tamiya Mini, MTS FFv2 Pro, Exotek F1
carcar.ca
BoneCrusher is offline   Reply With Quote
Old 09-13-2011, 03:58 AM   #21071
tc3team's Avatar
If there was no drama on the track, we would all be drinking caffiene drinks to stay awake... lol.
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 09-13-2011, 03:06 PM   #21072
Need some help please ppl, i've just re cal'd my rs when i finished i just run it up not flat out but it sounded very flat and noticed all the lights flash then go off and led's 6 7 are on all the time any ideas?? cheers
Schumacher mi4lp Tekin RS
Rob long is offline   Reply With Quote
Old 09-13-2011, 03:16 PM   #21073
HarryLeach's Avatar
Send a message via AIM to HarryLeach
Ivan
Not real sure what you're asking.
If you're running boosted, there's no real "compensation" for physical motor timing, it's just another adjustment.
Physical Motor Timing = In effect at all times
Boost = In effect during the designated RPM Range, applied linearly during that range, with max boost kept beyond the END RPM
Turbo = In effect at full throttle, after the delay time [in seconds], applied exponentially based on the ramp setting used.
Obviously, if you're running Blinky, Physical Motor Timing is the only timing adjustment you have.
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 09-13-2011, 04:56 PM   #21074
Trader Rating: 15 (100%+)
Default esc
I was trying to program my RS Pro, I reset the radio and still no dice.
When I push the mode button, the esc beeps after a few seconds, I pull the trigger and it never beeps again. I let go of the trigger and it will beep in a few seconds. Then the ESc is operational.
Why wont it let me set the reverse/brake?
Everything is turned to 100%.
mdhyams is offline   Reply With Quote
Old 09-13-2011, 05:12 PM   #21075
HarryLeach's Avatar
Which radio are you using?
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
