Old 09-04-2011, 05:25 PM   #21031
Originally Posted by HarryLeach View Post
I haven't run a lot of boosted 13.5 TC, and I have little to no experience with an X12, but I think a decent starting point would be:
FDR: 6.5-7 [not 100% on this, test carefully]
End RPM: 22,000
Start RPM: 9,000
Boost: 40
Turbo: Max 10 [the car will be easier to drive and just as fast without Turbo if the lead-in to the straight isn't real fast, or the straight isn't real long, so only use in small increments, with lots of temp checks]
Turbo Ramp: 2
Turbo Delay: .4
Don't take this profile and run with it, you'll need to do quite a bit of testing and temperature checking. Start low on the Boost, and increase in increments of 10 if the temps are good and you need more speed. The X12 has a lot of torque, and likes to run warm, so if you reach a point where the temp is getting too high with the boost, you may want to gear up [lower FDR], a touch and try another test run.
If the acceleration is too smooth/slow, start reducing your END RPM in 1,000 RPM increments. Don't get greedy, there's only so much to gain from a tight RPM range. My lower limit would be 16,000 RPM, so there's a pretty good range to work with.
If the car is too snappy on corner exit, bring the START RPM down one choice on the list, should be 800-1,000 RPM spread between choices.
If you're trying to get more corner exit acceleration, reduce motor timing and/or raise the START RPM one choice on the list.
Again, check the motor temp frequently, make one change between runs, and slowly work towards the power band you want. Hopefully, it only takes a few test runs with the profile I would start with to get up to the 40 Boost [no turbo, set turbo LAST, after all other tweaks are to your liking], to get a decent motor temp after a 6min. run, and you can start adjusting from there.
Harry is not a million miles away but with an X12 I suspect you will want to try the FDR 7 to 7.5 - and personally I would start with the 4 dot or 3 dot timing insert.
Harry interestingly I found that I got more rip out of the corner with my 10.5 by lowering my start rpm. I had it around 12-13K and ended up lowering it to 8.5k
yellowshark is offline   Reply With Quote
Old 09-04-2011, 06:13 PM   #21032
HarryLeach's Avatar
Send a message via AIM to HarryLeach
Thanks for your input. I don't run the X12 since I'm not a fan of how warm they seem to need to be run to really rip. They're fast, I just prefer the Trinity/Epic motors more.
With a higher kV motor, such as a 10.5, you can probably get away with a lower end RPM, Start RPM, and a tighter range, simply because it's going to want to accelerate faster even without boost, than a lower kV wind.
When I've run a boosted 10.5 TC, the hard part for me wasn't finding speed, it was smoothing the power band enough that I wouldn't spin tires on corner exit every time I accidentally fat-fingered the throttle.
That said, I've seen quite a few guys under gear their motors with high boost and turbo levels to the point of causing more heat than if they geared up on the same profile.
The nice thing about custom profiles is everyone can tune to suit, I've just found that a very tight, early RPM range for boost makes the car very difficult to handle consistently.
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 09-05-2011, 01:16 AM   #21033
silvalis's Avatar
Trader Rating: 29 (100%+)
I'm having problems downloading Hotwire - giving me a Service Unavailable message.
silvalis is offline   Reply With Quote
Old 09-05-2011, 10:38 AM   #21034
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
It appears our server is down for maintenance.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 09-06-2011, 06:43 AM   #21035
Hi guys
I need a set up for a Thunder power 13.5 motor with my Tekin for a small carpet track , i was looking for Jason Schreffler's set up from the snowbirds but cannot find it ;(
Can anyone help ???
Thanks in advance Phil
sidecarphil1 is offline   Reply With Quote
Old 09-06-2011, 07:38 AM   #21036
mazmo's Avatar
Originally Posted by sidecarphil1 View Post
Hi guys
Can anyone help ???
Here is his 2010 snowbirds set up for 10.5, should be fine with 13.5
10.5 Speed Passion
Endbell timing: N/A
Gearing 7.71
Drag Brake 30
brake strength 100
Limiter Off
Neutral width 10
Voltage cut off 2
Motor Type 1
Throttle Profile 5
Timing Boost 55
Turbo Boost 10
Turbo Delay 0
Start RPM 5300
End RPM 22,500
Ramp Rate 3.0
Team TOP Australia www.topracing.net.au
TOP Photon EX 17.5 + TOP Photon EX 21.5 + TOP Rebel F1 21.5
ORCA | Tekin RS Pro | Tekin Gen 2 RPM | Ko Pro-Po | EPIC Trinity
mazmo is offline   Reply With Quote
Old 09-06-2011, 07:40 AM   #21037
10.5 Speed Passion
Endbell timing: N/A
Gearing 7.71
Drag Brake 30
brake strength 100
Limiter Off
Neutral width 10
Voltage cut off 2
Motor Type 1
Throttle Profile 5
Timing Boost 55
Turbo Boost 10
Turbo Delay 0
Start RPM 5300
End RPM 22,500
Ramp Rate 3.0
ok cool thanks , thought he was running Thunderpower motors ???
Old 09-06-2011, 08:43 AM   #21038
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Hi guys
Can anyone help ???
what size is the track
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 09-06-2011, 09:27 AM   #21039
dont know yet haha race is next week
it is a small technical carpet track is all i know
Old 09-06-2011, 05:03 PM   #21040
20 SMOKE's Avatar
how small is small,if you find some info on it lmk
Jamie W
Old 09-06-2011, 07:04 PM   #21041
Suspended
Did you ask your girlfriend that question?
Pimp Formally Known as OG
PFKAOG is offline   Reply With Quote
Old 09-06-2011, 07:07 PM   #21042
Trader Rating: 15 (100%+)
Default 17.5 boosted
mdhyams is offline   Reply With Quote
Old 09-06-2011, 07:11 PM   #21043
20 SMOKE's Avatar
grow up
Jamie W
Old 09-07-2011, 02:25 AM   #21044
tc3team's Avatar
I race on a 10x15m carpet track, but with a redline 13.5.
If you want my setup let me know
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 09-08-2011, 01:41 AM   #21045
thanks i will find some more info out
does no one use the Thunder power motors ??
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
