Old 08-27-2011, 09:29 AM   #21001
HarryLeach's Avatar
Send a message via AIM to HarryLeach
Originally Posted by shoei View Post
Thank you Harry, you are a champ.
No Problem, good luck, and if you think there's room to improve your profile, but you're not sure what to adjust, post up your setup [gearing, profile, motor temps, and where you'd like to improve], and I'll see what I can do.
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 08-29-2011, 04:44 PM   #21002
Default Drag Brake problem
Ever since the whiners won and got boosted classes eliminated from racing, I've had to run non boosted. Problem is, when I go to blinky mode, I get NO drag brake. I've tried it on 4 different tekin speedos and it's the same on all. Is anyone else having this problem?
DOTMAN is offline   Reply With Quote
Old 08-29-2011, 04:53 PM   #21003
HarryLeach's Avatar
From what I remember, the gearing required to run non-boosted really puts a hurting on brake power.
How much motor timing are you running? More motor timing seems to hurt brake power as well.
Glad there's still boosted racing at my local track.
Old 08-29-2011, 05:03 PM   #21004
running a duo 1 with middle timing. I think it's 10 degrees. I mean, I get NO drag brake. I have it set at 40 and...nothing. Car doesn't slow even a little. regular brakes are fine. It's just drag brake
Old 08-29-2011, 05:38 PM   #21005
HarryLeach's Avatar
That's kinda the nature of blinky when the pinion and spur are so close in size.
Maybe someone else has some idea, but most guys I know don't use drag brake.
How high have you tried running the drag brake setting?
Old 08-29-2011, 05:41 PM   #21006
I've taken it up to 40. I'll crank it up to 70 and see if I feel a change
Old 08-29-2011, 06:19 PM   #21007
Skiddins's Avatar
I'm trying to remember if the timing settings in the hotwire setup directly refer to the degree's of timing or not.
i.e. is setting the the main timing to 50 with 10 turbo, giving 50 degrees of timing with another 10 added in turbo?
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 08-29-2011, 06:31 PM   #21008
HarryLeach's Avatar
Skiddins
That's my understanding for a sensored profile, yes.
For sensorless timing advance, it's a percentage. How many degrees 100% is, I don't know.
Old 08-30-2011, 12:10 AM   #21009
StevenOlsen's Avatar
if I remember correktly 100% is 30 degrees. but cant find it anywhere :-S
Steven Olsen
CAR: Awsomatix A700L.
Nosram 7000 Batteries.
Nosram Comet HD ESC.
Nosram Pure 2 evolution Motor.
StevenOlsen is offline   Reply With Quote
Old 08-30-2011, 04:54 AM   #21010
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
timing advance is 30* max
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 09-01-2011, 04:53 PM   #21011
Bubblehead's Avatar
What's the best way to determine if the sensor wire is bad?
Bubblehead is offline   Reply With Quote
Old 09-01-2011, 05:02 PM   #21012
Does it smoke, have tattoos and use foul langauge?
Old 09-01-2011, 05:18 PM   #21013
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Well if you have an RS or RS Pro you can use the sensor tester:
+ YouTube Video
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 09-01-2011, 05:30 PM   #21014
Bubblehead's Avatar
Randy thanks, and I was told the only way to tell was to replace the senor wire with a new one.
Old 09-01-2011, 05:30 PM   #21015
Suspended
Does this method also apply to the Rx8 ???
bertrandsv87 is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
