Old 01-15-2009, 09:28 PM   #2086
Trader Rating: 14 (100%+)
So does anyone run this thing off road. Seems like everyone is running either 1/12 or Oval. Hopefully i will have mine by the end of the month.
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875, Sanwa M12S
DG Designs is offline   Reply With Quote
Old 01-15-2009, 09:32 PM   #2087
Originally Posted by cujo View Post
ok i need some help, starting to get very confused. I run a rs pro 13.5 foam sedan. current settings are: db 65, brake 90, deadband 5, tp 5, timing/boost at 75, no current limit. software version 1.80. trinity pulse timed at 5.
main question is with this boost/timing. I went back and tried it at 10, 12, 15 with all sorts of different rollouts. car went from slow and motor 120 to slow and motor at 155 to ok and motor at 185. increased the boost/timing to 75 and car was quick, wouldn't say fast and a liveable 165 but started getting soft in the last 2 min. i had a novak 13.5 in before the trinity and wasn't blown away either. my car was faster when i was running my lrp tc. not saying that the lrp is better, i think the tekin is as good if not better just need some help getting it there. also forgot to metion that i'm running it sensored only now as the above posts state that it is better for the 13.5's. sorry for the book but starting to get frustrated. thanks.
Hey Greg,
Hit up Kenny next time for the boost update, or I don't know if it's email-able shoot him a message. Until then if you want a decent setting for the older software try this for rubber and the same but with 45 drag for foam.
http://www.rctech.net/forum/4898353-post1190.html
JoelV is offline   Reply With Quote
Old 01-15-2009, 09:38 PM   #2088
Cujo, in order for the timing(75) to be used you have to be in sensor only mode, otherwise you were just going off the physical timing of the motor. since you're running 180 I would turn you timing all the way up on the esc, and keep the temp in the 150-160 range. also see if you find someone whos has the new software and get a copy.
shaggy1 is offline   Reply With Quote
Old 01-15-2009, 10:04 PM   #2089
Krio's Avatar
Trader Rating: 150 (99%+)
I run mine offroad. Fits under buggy bodies like nobody's business
www.kriostasis.com
Krio is offline   Reply With Quote
Old 01-15-2009, 10:37 PM   #2090
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
I just picked up a RS and I don't see in the manual where it indicates how to disable reverse or increase braking power. Can somebody help me? Thanks
IIGQ4U is offline   Reply With Quote
Old 01-16-2009, 05:24 AM   #2091
TRF415boy's Avatar
Quite incorrect.
180 has no timing boost in sensored mode, so if you run sensored only you are on the motor's timing only. For the applied timing (75) to be used he needs to be in dual mode (sensored box unchecked).
Cujo I suggest you run your speedo in sensored only mode given that you run 13.5, and turn the timing on the motor to the max. Then try and get hold of the 189 from a team driver in your area, randy can hook you up for that.
TRF415boy is offline   Reply With Quote
Old 01-16-2009, 06:50 AM   #2092
TimNJ's Avatar
Trader Rating: 50 (100%+)
Hey guys,
I'm a roadcourse racer and decided to give oval a shot. I bought the KSG Gen 3 and the Tekin RS & Redline 17.5. Up til now, I've been running all Novak & Trinity stuff, so the Tekin stuff is new to me. I'll be running the car for the first time tomorrow on a mid sized oval (Marshall's in Honesdale, PA) in the 17.5 4-cell class and I just wanted to verify with the Tekin guys that my setup on the RS sounds close to being right.
Settings:
Software 1.89
Sensored Only
Neutral Width: 5
B/L Fwd/Brake
Throttle Profile 4
Boost: 15
Motor Timing: 12
Drag Brake: 0
Brake: 80
In full race trim, with Team-Grade EP4600 cells, the car weighs in at 2.587 lbs. (1173.4g) I'm rolling out at 3.69" (93.7mm) for starters. From what I know, the Novak & LRP guys at that track roll out anywhere from 3.9" - 4" (99mm - 101mm)
Also, approximately where should my motor temp be after a 4 minute oval run? In roadcourse racing, I run my Novak and Trinity motors in the 140*-150* range and just wanted to see if the range on the Redline motors is about the same.
Thanks!
Tim
Trinity - Caster Racing USA - Panther Racing
Race Videos: http://www.youtube.com/TrackMasterTim
TimNJ is offline   Reply With Quote
Old 01-16-2009, 07:50 AM   #2093
Grenade10's Avatar
Trader Rating: 37 (100%+)
Originally Posted by TimNJ View Post
Settings:
Software 1.89, Sensored Only, Neutral Width: 5, B/L Fwd/Brake, Throttle Profile 4, Boost: 15' Motor Timing: 12, Drag Brake: 0, Brake: 80
Thanks!
Tim
Tim, I run On road and oval both and have 4 RS/RS Pro's in my cars. You'll like the Tekin motor and the tuning of the ESC (I'm not a sponsored racer or employee either) in your pan cars. For our oval track with a 126' line, I run a roll out at 3.55 - 3.75 12 degree's in the can and 20 on the boost. I like the linear profile #3 for me and some drag brake but 40 on the break. I also use 10-15 for the neutral. You can mount the ESC in some pretty interesting spots on an oval car. With the lipo, I run it behind the lipo and in front of the rear tire on my Darkside Tornado. You would not believ how short the wires can be, even the sensor wire. I put the post towards the tire, to keep air moving around the post as that is the heat sink. The motor works well if your up in the 150 - 160 range, so as recomended many times gear down with the boost and then gear back to get the speed and temp.
Hope this helps a little.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 01-16-2009, 07:58 AM   #2094
Trader Rating: 76 (100%+)
Do you have any issues with it as far as getting dirty or wet? Just curious, thought of maybe running offroad in the future.
MUDVAYNE is offline   Reply With Quote
Old 01-16-2009, 08:04 AM   #2095
TimNJ's Avatar
Thanks for that, Grenade.
Old 01-16-2009, 10:37 AM   #2096
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Cujo: If you're running 75 on the timing bar you're in dual mode just like TRF said.
He's also correct with his recomended settings: Sensored only mode, full motor timing.
If ANYONE wants 189, you can email me for it. All I ask is that you tell me where you live/race so I can point you to any team drivers in your area.
[email protected]
I run mostly offroad so anyone looking for offroad setup help can post in the Offorad electric section here on tech.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 01-16-2009, 02:13 PM   #2097
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
On the sheet of paper that comes with the RS you will see instructions for setting up motor type, profile, cutoff etc. Follow those directions on page 2. If you lost yours, here is a link RS Instructions Basically it says to do 6 then 1.
ChristopherKee is offline   Reply With Quote
Old 01-16-2009, 02:37 PM   #2098
Krio's Avatar
No problems at all.
www.kriostasis.com
Old 01-16-2009, 09:52 PM   #2099
cujo's Avatar
thanks for the advice. i'll leave it sensored only and play with motor timing until i can get the new software from kenny.
cujo is offline   Reply With Quote
Old 01-17-2009, 10:40 PM   #2100
racing_jason's Avatar
Hey guys i got some more true race testing in today at the NWIC race,
the finnal out come was this
Track is flowing with about 100' strait with sweepers at both ends.
13.5 Tekin Redline
Tekin RS Pro
Can Timing: 24
Esc Boost: 25
Linear Profile
Min Dead band
100% break and 60% drag break (drag break doesnt have any real stoping power most likely going to take it out)
Geared: 41/100 (1.7 Internal Ratio) with 55.5mm tires
Hope this gives some ppl more ideas on how to get a handle.
Jason Hunt
Thank you to my sponsors-
Team Associated-Reedy-ProLine-B&B Hobbies Racing
racing_jason is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
