Old 08-06-2011, 08:33 PM   #20956
auzzy_mate's Avatar
Default Transmitter reset
Do I need to reset my transmitter (Fw/ Neut / Rev) each time I change a setting in the ESC with the software?
Ben
auzzy_mate is offline   Reply With Quote
Old 08-06-2011, 08:41 PM   #20957
CCristo's Avatar
Trader Rating: 55 (100%+)
ShadowAu, You may get by, but it will depend on the car (2wd/4wd), traction and how heavy your throttle finger is. You'll definitely be pushing it.
auzzy_mate, you only have to recalibrate after you change neutral width or upgrade the firmware.
Chris Cristo
Pro-Line RacingHobbywingMIPBOOMrcFutabaPT RC Racing Oils
CCristo is offline   Reply With Quote
Old 08-07-2011, 03:47 AM   #20958
ShadowAu's Avatar
I suspected I could be trying to push it a bit hard... maybe an 8.5?
it will be a 4WD tourer... probably reasonably high grip and I am not the smoothest nor the heaviest throttle finger...
I am quite content with doing what I do
Don't mistake not being happy for unhappiness - its not the same thing
ShadowAu is offline   Reply With Quote
Old 08-07-2011, 08:28 AM   #20959
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Ben
No, only when you update firmware rev.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 08-07-2011, 02:54 PM   #20960
M-Technic's Avatar
Trader Rating: 15 (100%+)
Originally Posted by ShadowAu View Post
Could I push an RS to 6.5 with some boost?... if I add a fan to blow across the post?
It's possible but you are riding a thin line. I usually run a boosted 7.5 in mod touring with a non-pro RS. The ESC doesn't get very hot (usually 4 lights) but the motor is usually pushing 190*F. One wrong setting and the motor and/or the speedo would go poof.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 08-07-2011, 03:38 PM   #20961
Well you will be safer with an 8.5t surely.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 08-08-2011, 01:44 AM   #20962
tc3team's Avatar
Originally Posted by ira View Post
Thanks for the help.
No problem
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 08-08-2011, 06:42 AM   #20963
rai
Default Intro
Hi there all,
I just bought a Tekin RS Pro and new to this esc. Could anyone direct me (if any) to the page number on this thread for settings of RS Pro with X12 10.5T Stock spec motor?
Many thanks..
rai is offline   Reply With Quote
Old 08-08-2011, 07:15 AM   #20964
I can send you my setup if you wish, this is what I use.
But what is the size of your track first and how fast/twisty it is?
Old 08-08-2011, 02:58 PM   #20965
rai
Size of the track is 50 m by 30 m. Outdoor track with those 45 m as a long straight with sweepers at both ends. Infield is technical. Hope this descriptions help.
Old 08-08-2011, 04:03 PM   #20966
You have a MP
Old 08-09-2011, 02:13 PM   #20967
Fjeld's Avatar
Hi
Can you pls send that setup to me also?
I need somthing to work from
|| Yokomo BD7 2015 || XRAY T4'15 ||
|| Muchmore Fleta POWER :D ||
Fjeld is offline   Reply With Quote
Old 08-15-2011, 03:46 AM   #20968
Hey guys,
I hope someone can help with some setup. Start and end rpm range what does having a small gap do and having a larger gap what do the different settings do? How does it affect the power curve?
Any help would be appreciated
Cheers
Jason
ARC R10 2013
Wylie27 is offline   Reply With Quote
Old 08-15-2011, 04:48 AM   #20969
mazmo's Avatar
Originally Posted by Wylie27 View Post
Hey guys,
Cheers
Jason
Jason,
Try this link to Tekin software guide ... lots of good info here, will explain the functions and settings.
http://www.teamtekin.com/hotwire_RS.html
Re: start & end RPM ... this controls how quickly your timing 'boost' kicks in.
Small gap, timing will kick in faster / harder... more aggressive acceleration. Too much timimg too soon can overheat motor / speedy.
Larger gap, acceleration less aggresive but throttle will feel smoother ... due to wider RPM range.
Cheers
Alan
Team TOP Australia www.topracing.net.au
TOP Photon EX 17.5 + TOP Photon EX 21.5 + TOP Rebel F1 21.5
ORCA | Tekin RS Pro | Tekin Gen 2 RPM | Ko Pro-Po | EPIC Trinity
mazmo is offline   Reply With Quote
Old 08-17-2011, 06:52 PM   #20970
Brokin Racing's Avatar
Trader Rating: 68 (100%+)
Hi Guys,
Could anyone suggest a set up for 6.5 boosted (X12 Octa/Tekin) & a suitable rollout (large track)
Many Thanks in Advance..
Xray Since 2006 - LRP - PF - Futaba -
"Retired from Racing"
Brokin Racing is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
