Old 08-04-2011, 07:05 AM   #20941
ira
ira's Avatar
Trader Rating: 18 (100%+)
Originally Posted by tnrccar View Post
Your speedo will run a little cooler with more caps --
Thanks for the help.
ira is offline   Reply With Quote
Old 08-04-2011, 07:06 AM   #20942
ira
ira's Avatar
Originally Posted by tc3team View Post
Correct.
It smooths out the voltage to prevent any spikes, as said, 2 caps are needed for lower turn motors.
Old 08-04-2011, 09:49 AM   #20943
noline's Avatar
Any one have a 1/12th 13.5 1c blinky gearing with a 13.5 D3 motor on a 100'x45' carpet track what rotor would be good the 1c or the one that comes with it?
noline is offline   Reply With Quote
Old 08-04-2011, 10:23 AM   #20944
Trader Rating: 19 (100%+)
I run the stock rotor in mine, I run an 86mm rollout and my temps have never gotten above 135. I run a 100 by 38 foot track so it should be close, you may be able to go up a tooth or two on your pinion though.
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 08-04-2011, 11:53 AM   #20945
mysupratoy94's Avatar
Trader Rating: 24 (100%+)
Send a message via Yahoo to mysupratoy94
Correct.
lower turn motor as in a 4.5, 5.5? I have a 8.5 brushless, is that in the lower turn motor list category?
mysupratoy94 is offline   Reply With Quote
Old 08-04-2011, 01:47 PM   #20946
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
no,is it the pro
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 08-04-2011, 02:24 PM   #20947
Originally Posted by 20 SMOKE View Post
no,is it the pro
No its the RS model.
Old 08-06-2011, 05:54 AM   #20948
UK.hardcore's Avatar
Is it ok to connect the cap with some wire?
I want it a little further away because it would be a cleaner install.
A racecar is only as good as the mechanic who build it.
UK.hardcore is offline   Reply With Quote
Old 08-06-2011, 06:59 AM   #20949
20 SMOKE's Avatar
8.5 and rs is fine no need for a second
Jamie W
Old 08-06-2011, 07:00 AM   #20950
20 SMOKE's Avatar
you want it as close as you can to the post,put some black shrink wrap on it
Jamie W
Old 08-06-2011, 07:01 AM   #20951
Yes I cannot see a reason why not, mine has 4 caps on a wired unit, make sure to get the proper wire, that's all
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 08-06-2011, 02:04 PM   #20952
Hey i have the rs speed control and just bought the hotwire interface for it. I just have a quick question how do i put the speed control in blinky mode. Please help new to this stuff
sczrface85 is offline   Reply With Quote
Old 08-06-2011, 02:34 PM   #20953
you have to load 212 software in the speedo.
the computer will basicly tell you how.
then, it will be TP 1 for blinky in the speedo.
it's all on the Tekin site too.
Old 08-06-2011, 03:55 PM   #20954
thanks i got it know so easy to follow off the website
Old 08-06-2011, 07:37 PM   #20955
ShadowAu's Avatar
Could I push an RS to 6.5 with some boost?... if I add a fan to blow across the post?
I am quite content with doing what I do
Don't mistake not being happy for unhappiness - its not the same thing
ShadowAu is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
