Old 07-13-2011, 07:23 AM   #20851
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
it just helps with exit off the corner to much motor timing causes to much heat to little it feels flat,6-10 motor is just a guide line
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 07-13-2011, 07:24 AM   #20852
20 SMOKE's Avatar
Originally Posted by tr1kstanc3 View Post
I ended up using the following configuration.
8 degrees motor timing
35 timing boost
12 turbo
delay .2
ramp 2
start 5k
end 20k
fdr 7.5
temps were around 140f.
Thanks for the help! Car is running well.
good
Jamie W
Old 07-13-2011, 07:36 AM   #20853
Sorry for not understanding what you mean, but if you tell me that too much motor timing causes more heat and you run at 8 and I run at 0 I cannot see how it is better.
I compensate the motor timing with the esc.
I am not trying to say that mine is better etc...but try to understand what you are doing. Other racers will read this and we do not want to give them bad advices.
What motor are you using anyway, I don't recal you mentionned it in previous post (could be wrong they are plenty on this thread) and on what chassis too?
Regards
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 07-13-2011, 08:21 AM   #20854
20 SMOKE's Avatar
not in the essence of 0-8 but in the 15 20 or 30* of motor timing
Jamie W
Old 07-13-2011, 11:09 AM   #20855
Monkeys punk's Avatar
Need to use my RS with a 27 turn non rebuildable brushed motor. Now I know this is overkill but I have wired it through A pos and C neg to get rev delay. I and calibrated before conecting motor but will 212 be ok or should I go back to an early version ?
Top Racing Sabre mini
Tamiya m05
Sakura zero
Monkeys punk is offline   Reply With Quote
Old 07-13-2011, 11:13 AM   #20856
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
There should be no reason to back in software when using a brushed motor with the RS.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 07-14-2011, 06:59 AM   #20857
M-Technic's Avatar
Trader Rating: 15 (100%+)
Regards
I like to use a little motor timing even if it means reducing the timing or the turbo on the speed control. It has a better feel in my opinion. I use Trinity motors.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 07-14-2011, 10:33 AM   #20858
mine's are LRP X12 10.5t which heats up quite a lot, I would like to try the Trinity, but they are not popular here in France and impossible to buy locally it seems...
Old 07-14-2011, 10:46 AM   #20859
Default minimum throtle changing
Is it normal if I change setup using push button on my RS Pro the minimum throtle also change to Max or 30.
If I only need a quick setup of dragbrake from the esc it change, I must connect to laptop to lower it again (5-10 min.throtle), so much trouble. The ver.212.
Does it happens to u also? What's wrong?
QDriver is offline   Reply With Quote
Old 07-14-2011, 11:38 AM   #20860
you can use position C1 or C2 to have pre installed set up.
Old 07-15-2011, 07:18 AM   #20861
Default throtle minimum
Profile C1 and 2 only store timing+turbo advance, minimum throtle only available from the hotwire. But then if I change any setup with the pushbutton on RS the min.throtle change to MAX: 30'
Something is wrong, tekin: please help!
Old 07-15-2011, 09:27 AM   #20862
hairy's Avatar
Pick up the phone and call them if you are here in the U.S.A.,they are easy to talk to.
MERLIN RACING
"He once ran a marathon because it was on his way"
Logic is a lost art!
You are defined in life by how you respond to defeat!
hairy is offline   Reply With Quote
Old 07-15-2011, 10:43 AM   #20863
Team Tekin
Randy_Pike's Avatar
No not normal. So please tell me specifically what you're doing and in the exact order you're doing them.
Old 07-15-2011, 04:00 PM   #20864
Randy,
What is the max timing of the tekin rs pro ?
I saw some hara setup sheet with 64 , and some with 65
Manson is offline   Reply With Quote
Old 07-16-2011, 05:48 AM   #20865
Originally Posted by Manson View Post
Randy,
55 boost + 20 turbo
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
