Old 07-10-2011, 03:49 AM   #20836
To the best of my knowledge it does not exist yet.
In developpement maybe??
The advantage of this speedo is that you can set 2 different setup before getting to the track if you do not have a laptop, and switch as necessary between C1 and C2 just using the push button on speedo.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 07-10-2011, 04:46 AM   #20837
elery's Avatar
Default tekin rs
I thought it was out already to hear that it doesn't even exist. wow lol.
elery is offline   Reply With Quote
Old 07-10-2011, 06:16 AM   #20838
Buckaroo's Avatar
Originally Posted by elery View Post
how and where can i get the team taking hotwire for iphone?
There are apparently too many issues integrating the different smartphone/tablet operating systems with the hotwire.
Windows 8, which is supposed to integrate desktops/laptops/tablets/smartphones is what currently holds promise.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 07-10-2011, 01:53 PM   #20839
photobrat's Avatar
Trader Rating: 33 (100%+)
Send a message via Skype™ to photobrat
Pulled a stupid reverse polarity for a split second spark the other night at practice. Running an RS Pro with a Redline 10.5.
After realizing the bonehead move I quickly regained composure and plugged everything in properly, all worked fine for the rest of the night. The following night for race night, went to turn on same system and it wouldn't ring out. All led's were lighting up as if it was getting the throttle/break from the rx. Swapped out to a redline 13.5 and all worked again.
Is it possible to burn up a motor and not the ESC with a reverse polarity charge? What would burn up and is it user serviceable?
www.brandonsullivan.com
So many classes, so little time.
photobrat is offline   Reply With Quote
Old 07-10-2011, 04:32 PM   #20840
I guess your sensor board, but it is strange that you manage to use it that evening, then again it could be totally not connected and your motor was going to give up either way.
Old 07-11-2011, 10:37 AM   #20841
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
It's not likely. However it could have taken out the motor sensor board. From the sounds of it this may be the case.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 07-11-2011, 05:28 PM   #20842
touringdriver's Avatar
Trader Rating: 15 (100%+)
Default tekin rs pro 13.5 Touring sedan setup help
hello fellow racers, i'm racing asphalt on road with a xray t3 11 sedan, i'm using the tekins rs pro 13.5 system and in need of speedo set up help. the track is 120' x 60' good traction, and i'm geared at 6.94 right now. wanting to get the most as possible with the programming.
Proudly Sponsored by: Mr. Crash Racing, RickyRacer lidz & Ebay..
Rock Chalk Jayhawks
2014 Subway Cup & Dee and Mees On-road Race Schedule:
http://www.rctech.net/forum/kansas-m...l#post11891510
touringdriver is offline   Reply With Quote
Old 07-12-2011, 06:07 AM   #20843
Originally Posted by olly986 View Post
What is your final ratio?
I run in 10.5t class, my final ratio is 7.57 on a TC6 with a LRP X12 0 timing
Here is my set up:
drag brakes: 0
limiter: 30
neutral width: 25
profile: 3
throttle min: 10
brake min: 15
timing advance: 100
push control: 25
boost: 40
turbo: 20
ramp: 3
turbo delay: 0
start rpm: 8000ish can change to 5000ish depending on track
end rpm: 20000ish
You need to remember that your batteries are a big part of your speed, I run 60/65C in my class.
also your motor will be hotter, it is hot here at present 25/30 degrees and my motor is around 70/80 with fan on of course, battery at 40ish and speedo 35/40ish.
Hope this works for you, you should have plenty power with this.
Hi,
With this set up what is 0 timing on your X12 - 4 dot, 3dot ?
Also why do you run current limit so low and your neutral width so wide ?
I run a very similar set up but with 4 dot timing insert, curent limit 85 and neutral width 10, My FDR is just over 8 - It is quick but am always trying to find improvements.
Thanks in advance
JamieV is offline   Reply With Quote
Old 07-12-2011, 08:25 AM   #20844
Hi Jamie
We have one of our top racer in the club who knows the Tekin very well through extensive tries.
2 dots straight is 0 timing on X12
Neutral width: lower values make the throttle dead band more sensitive, we find that with a higher value, we can run a smoother speed all the way in bends and turns.
limit: Adjust throttle response during acceleration, again we get a smoother acceleration coming out of turns and we can accelerate sooner.I run between 30 and 40 depending on tracks.
What car are you running for a fdr of 8?
Why don't you try my setup to see if you can feel a difference, I run on asphalt purpose tracks with medium/high grips.
Regards
Old 07-12-2011, 10:39 AM   #20845
Default Hotwire smart phone app - Android first, Apple later ?
I am under the impression that the Hotwire app will be available first for phones based on the Android platform. Is this true? (This is good for me)
Is this something that will be available soon, like in 2 months, or when?
Rufus2010 is offline   Reply With Quote
Old 07-12-2011, 12:00 PM   #20846
M-Technic's Avatar
To the best of my knowledge, they haven't officially acknowledged development of an app for either platform.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 07-12-2011, 01:46 PM   #20847
Hi Jamie
Regards
I will try it this weekend. (I run a MI4CX)
One thing everyone always criticises is how on / off the tekin feels so maybe changing to these settings will smooth it out.
My only concern is that using 0 timing on the motor will cause too much heat so will definitely use a heatsink / fan.
Looking forward to testing !!
Old 07-12-2011, 02:15 PM   #20848
Hi Jamie
Of course, I always run a fan but no need for heatsink on speedo.
The motor gets quite hot (70/75) make sure you check the temp after a couple of minutes, just in case your ratio is a little off in comparison of AE
TC6.
Hope you will find a difference.
Old 07-12-2011, 08:52 PM   #20849
tr1kstanc3's Avatar
Trader Rating: 18 (100%+)
Originally Posted by 20 SMOKE View Post
around 8 motor timing
35 timing boost
12-15 turbo(you play with it)
delay .3-.5(you play with it)
ramp 1
start 4k
end 20k
fdr 7-7.5
check temps around 2-3 min
I ended up using the following configuration.
8 degrees motor timing
35 timing boost
12 turbo
delay .2
ramp 2
start 5k
end 20k
fdr 7.5
temps were around 140f.
Thanks for the help! Car is running well.
tr1kstanc3 is offline   Reply With Quote
Old 07-13-2011, 02:07 AM   #20850
35 timing boost
12 turbo
delay .2
ramp 2
start 5k
end 20k
fdr 7.5
Why using such high timing on motor? the total of boost+turbo+timing should be at 60, why not reducing the timing on motor and increase the rest.
Exemple: 4 motor timing + 40 boost+ 16 turbo or 0 motor+ 40 boost+ 20 turbo.
Try this and tell us your throughts, I am not a fan to push the timing on motor too much.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
