Old 07-05-2011, 09:17 AM   #20821
bkspeedo's Avatar
I've never ran MOD before but will be attempting it this week.
What FDR would be a good starting point for a TC with 6.0 mtr on a 95x42' track with slow infield?
I'm using a R1 Pro of all things. Bought it when Tekin first released this ESC and the trade in program was weak for an RS so i kept it.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 07-06-2011, 07:11 PM   #20822
elery's Avatar
Default tekin rs
Originally Posted by mok View Post
welcome to the sport!
-mark
Thanks man. I'm hoping to become an elliot harper some day lol.
elery is offline   Reply With Quote
Old 07-07-2011, 12:41 AM   #20823
TrevCoult's Avatar
You really want that hair style? (I actually do know him so I can get away with comments like that.)
Trev
Schumacher Atom GT12
Schumacher Eclipse 12th
www.carsrcracing.co.uk
CARSrcracing.co.uk Webmaster
Schumacher Racing
TrevCoult is offline   Reply With Quote
Old 07-07-2011, 07:43 PM   #20824
tr1kstanc3's Avatar
Trader Rating: 18 (100%+)
Default Tekin RS w/Epic D3 10.5 boosted
Looking for an initial starting template for running TC on a 120x60ft track with a long sweeping straight. Car is a TRF416x with Tekin RS and Epic D3 10.5 running boosted mod. FDR is ~7.2 currently.
First time running mod and boost so would like a baseline to start from. Thanks in advance.
tr1kstanc3 is offline   Reply With Quote
Old 07-07-2011, 07:51 PM   #20825
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
around 8 motor timing
35 timing boost
12-15 turbo(you play with it)
delay .3-.5(you play with it)
ramp 1
start 4k
end 20k
fdr 7-7.5
check temps around 2-3 min
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 07-07-2011, 07:51 PM   #20826
elery's Avatar
Trev
lol i dont mean like that. I want to become a good rc driver like him. He is like the same age as me.
Old 07-08-2011, 12:53 AM   #20827
TrevCoult's Avatar
Yes, I know what you mean. I've known Elliott a few years now and he's absolutely awesome to watch, especially in 12th scale modified.
Trev
Schumacher Racing
Old 07-09-2011, 12:03 PM   #20828
Default 10.5T & RS Pro Setup
Hello all
I'm racing with 4WD 2cell Touring car on an asphalt 120x60 feet track (lap times around 12s) and I'm lack of bottom end power, everybody is faster than me in the start and i the exit of slow corners.
I've got a Novak Ballistic 10.5T motor and the 2.12 software.
My setup is:
6.5FDR
End bell: N+5°
50°Boost 4400-12500
10 Turbo 0.16 Del. Ramp 3.0
5 Throttle Profile
BL-FW
3.2V Voltage cutoff
No Current Limit
100 Brake
0 Drag Brake
Min Throttle/Brake 10
NW 10
No Push Control
Motor is 60°C(140°F) after 5min with cooling fan.
I don't Know it's over- or under-timed but it's slow when I accelerate from low speed corners. Could somebody help with my setup?
Thanks in advance
Zsolt
KZsolt36 is offline   Reply With Quote
Old 07-09-2011, 03:59 PM   #20829
Originally Posted by KZsolt36 View Post
Hello all
My setup is:
6.5FDR
End bell: N+5°
50°Boost 4400-12500
5 Throttle Profile
BL-FW
3.2V Voltage cutoff
No Current Limit
100 Brake
0 Drag Brake
NW 10
No Push Control
Thanks in advance
Zsolt
What is your final ratio?
I run in 10.5t class, my final ratio is 7.57 on a TC6 with a LRP X12 0 timing
Here is my set up:
drag brakes: 0
limiter: 30
neutral width: 25
profile: 3
throttle min: 10
brake min: 15
timing advance: 100
push control: 25
boost: 40
turbo: 20
ramp: 3
turbo delay: 0
start rpm: 8000ish can change to 5000ish depending on track
end rpm: 20000ish
You need to remember that your batteries are a big part of your speed, I run 60/65C in my class.
also your motor will be hotter, it is hot here at present 25/30 degrees and my motor is around 70/80 with fan on of course, battery at 40ish and speedo 35/40ish.
Hope this works for you, you should have plenty power with this.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 07-09-2011, 04:08 PM   #20830
bvoltz's Avatar
Trader Rating: 44 (100%+)
Hello all
My setup is:
6.5FDR
End bell: N+5°
50°Boost 4400-12500
5 Throttle Profile
BL-FW
3.2V Voltage cutoff
No Current Limit
100 Brake
0 Drag Brake
NW 10
No Push Control
Thanks in advance
Zsolt
Olly covered the rest, but I did not see what you have the throttle min set to. this will give you more punch out of the corner. I run 17.5 and run 6.8 to 7.0 with a Duo 3, you may want to push up your FDR by dropping 2 teeth. On the throttle min, start with 10, I run 13, depending on the track, but we seem to about the same size... 140 is safe to give your motor a little more.
bvoltz is offline   Reply With Quote
Old 07-09-2011, 04:12 PM   #20831
Here is my set up:
drag brakes: 0
limiter: 30
neutral width: 25
profile: 3
throttle min: 10
brake min: 15
timing advance: 100
push control: 25
boost: 40
turbo: 20
ramp: 3
turbo delay: 0
end rpm: 20000ish
Thank you for the fast reply.
I run 6.5FDR. I will try 7ish and try a wider and higher rmp range.
When do you use lower start rpm, when the track is more technical?
I run 3 month old IP 5800 60C so I think that can't be the problem.
You run current limit, Does it reduces temps a lot?
Old 07-09-2011, 04:15 PM   #20832
I run both throttle and brake min at 10. I will try a ~7 FDR.
Old 07-09-2011, 04:31 PM   #20833
yes depending on lengh of straight or if the track is fast or twisty.
We run sometime 5 minimum throttle too, this will give you more punch quicker on throttle.
Old 07-09-2011, 09:14 PM   #20834
elery's Avatar
Default hotwire for iphone
how and where can i get the team taking hotwire for iphone?
Old 07-10-2011, 03:42 AM   #20835
You can't.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
