Old 07-04-2011, 05:07 AM   #20806
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
it helps to reduce wheel spin
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 07-04-2011, 08:44 AM   #20807
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by mok View Post
has anyone got any info regarding how the current limiter works on the rs pro?
with a mod motor and a low current limit set, does this reduce overall power available?
alternatively, does it allow normal amperage up until the current limit then essentially "flat line" the current while more amps are being pulled than the limit?
i ask because i was playing with an X12 4.5T (non-octa) yesterday and had the curent limit set at 80 and i noticed that the motor sounded a little "flat" when i was powering out of a tight corner which leads onto the main straight..
also, will one of the effects of lowering the current limit be to increase runtime?
should i see cooler temps on the esc and motor?
thanks in advance!
-Mark
You are running 80% current limit, 100% being max limit, so yes it will feel very flat.
Might want to try lowering the limit to 20 or 30.
Maybe Randy can explain exactly how it works, but in terms of feel and raw speed, lower limit is faster than higher limiter.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 07-04-2011, 09:00 AM   #20808
pakk's Avatar
Trader Rating: 79 (100%+)
thanks in advance!
-Mark
Current limiter does exactly that. It limits the current through your speedo. Current is highest at lower speeds when the throttle full. If you lower it too much, you will loose rip out of the corners. Your top speed shouldn't be affected.
This should decrease motor temps. I would guess that it would increase your run time, but I haven't tested.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 07-04-2011, 04:01 PM   #20809
elery's Avatar
Default Manual
Does any have a manual for the tekin rs explaining what motor timiming,fdr,turbo boost and the other tuning options are?
elery is offline   Reply With Quote
Old 07-04-2011, 04:07 PM   #20810
20 SMOKE's Avatar
http://www.carsrcracing.co.uk/?p=244
Jamie W
Old 07-04-2011, 04:14 PM   #20811
hanulec's Avatar
Trader Rating: 27 (100%+)
the official guides are here:
http://teamtekin.com/hotwire_RS.html
http://teamtekin.com/hotwirehelp.html
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 07-04-2011, 05:53 PM   #20812
elery's Avatar
Thumbs up tekin rs
Thanks guys I've read all the settings and i understand what all of them. I also learned that some options can work with one another when it comes to certain track conditions. Thanks a lot 20 smoke for giving a basic setup for my tekin and the manual and also to hanulec.
Old 07-04-2011, 06:06 PM   #20813
hanulec's Avatar
is there a specific class + motor combo you are looking to race in? if so - post informatinon about:
- type of class - 1/10th 4wd touring; 1/12th; etc..
- type of surface
- size of track
- specific motor manufacture/model
- specific motor class (blinky or boosted/open)
and i suspect someone here can give you some pointers
Old 07-04-2011, 07:09 PM   #20814
elery's Avatar
Default tekin rs
well, 20 smoke gave me a setting for a 13.5 turn boosted class. the traction level is veeeery low. Its in a carpark and its very slightly diagonal. The straight is about 20-30 meters with a left hand sweep and the rest of corners are fairly fast.
Old 07-04-2011, 07:29 PM   #20815
20 SMOKE's Avatar
i did,how is it working.i get so many ? i loose track
Jamie W
Old 07-04-2011, 07:45 PM   #20816
elery's Avatar
Default tekin rs
Well i haven't gotten use it because my tc5r is having a over steering problem because i bought the car used and the previous owner used it for drifting. the problem is so bad that even though the esc is on tp1 without any timing or boost, when it the throttle, the car wheel spins and when i hit the brakes, it does a full 180 degrees to the left. I promise when i get finish rebuild the the car and put the factory settings on it I'll tell you how its working. This is actually my first time racing. I'm only 17.
Old 07-04-2011, 08:48 PM   #20817
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
welcome to the sport!
-mark
XRAY T3'2011 / TEKIN RS PRO / LRP X12 / HYPERION SWIFT G3 RACE PACKS / FUTABA S9551 / SPEKTRUM DX3R
www.epracer.com - www.precc.org.au - www.westcoastmodelrallyclub.asn.au - www.onroadrccarclubbunbury.org.au
mok is offline   Reply With Quote
Old 07-05-2011, 07:11 AM   #20818
jgraham37128's Avatar
Trader Rating: 24 (100%+)
Default Tekin RS
Has anyone ran a Mod 5.0 with a Tekin RS?
I plan on racing TC mod this weekend and have a 5.0 Thunder Power. It shows the limit is 5.0 turn for the RS but I wanted to see if anyone has actually ran one with it.
jgraham37128 is online now   Reply With Quote
Old 07-05-2011, 08:54 AM   #20819
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Do not run the regular RS with a 5.0t motor. It will thermal. 4wd TC is meant for an RS pro.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 07-05-2011, 09:01 AM   #20820
Default Tekin
Randy, your killing me......
JG
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
