Old 06-29-2011, 12:53 PM   #20776
Originally Posted by Randy_Pike View Post
Thanks for advice -
I checked out his set up on the tekin forum before I posted.
Boost 50 and Turbo 15 FDR 7.00
I currently use a 10.5 with my RS Pro on with same settings on FDR 8.2 (Have settled on this after months of testing and it is quick)
If I used those settings with a 6.5 I would expect a melt down !!
I was expecting more conservative settings but if thats the only advice I get I will do some testing of my own.
JamieV is offline   Reply With Quote
Old 06-29-2011, 02:19 PM   #20777
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by ira View Post
I'm going to be racing 1/12th this winter, what is the best way to use the RS PRO ESC for 1 cell LiPo? With a receiver battery back or with a voltage booster?
Thanks for the help.
With a Tekin RS, TQ Booster, and a 4.5 mod, had no issues.
Tekin is not my 1st choice for 1s mod, but it is solid.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 06-29-2011, 05:48 PM   #20778
L@gger's Avatar
Ok what motor is this wind wise? your setup is very mild unless you're using a 7.5 or faster motor.
Your gearing is kinda out of whack though since none of us use a 90T spur on the CR. Also with the combined 35 motor and 20 boost you're at 55 degrees of timing...
Wheelies are a part of offroad. Use current limiter to tame them down. Try 80 right out of the gate.
Thank you for answer.
Oh yes... I forgot to add that it is 7.5T. I used 90T spur to 22T pinion but now I put 78 to 21 to my new tlr22 but have not tried it more decent.
And the timing is thing that I am confused. As many people are having absolutely different settings. And I am most confused about the static timing redline to ballistic. If there is some really good guide that goes to depth of this I would like to read it. IMHO not only word but dyno graphs of some different settings would say much.
Yes I know that wheelies are part of offroad but sometimes I had the feeling it was not equal to throttle applied.
L@gger is offline   Reply With Quote
Old 06-29-2011, 08:00 PM   #20779
Team Pink's Avatar
Trader Rating: 20 (100%+)
Originally Posted by JamieV View Post
Thanks for advice -
This setup is solid. I spent since April working on it and sent to Randy late May. I spent almost 2 months working on this setup to make sure it was solid and kept cool. The temps stay right were you want them on the speedo, and I consistantly pull my motor off at 165 degrees. At the RROC I was motoring 4.5 by 10 feet on the back straight and even some 3.5s. I highly reccomend you try it. It is smooth, fast, and really efficient. The efficiency is one of the first things I noticed compared to running a 4.5. I consistantly put in 2600 back into 5600 pack every run. The setup I sent Randy was ran at Norcal which is about 120-130 feet back straight. I have also been using at Ripon RC Speedway which about 85 feet with no turbo at all.
Derek Stephansen
Team Losi Racing/ Spektrum/ Horizon Hobby/ JConcepts/ Hobby Star/ Schelle Racing
Team Pink is offline   Reply With Quote
Old 06-30-2011, 03:34 AM   #20780
Derek Stephansen
Thanks for the detailed response.
I guess the big thing is that the LRP X12's have a lot more built in timing than the Tekin Motor so I will be a little conservative to start.
Do you use a fan to blow on the speedo and or / motor to help keep the temps down?
Old 06-30-2011, 07:38 AM   #20781
Team Pink's Avatar
I am currently running no fan on the speedo or the motor, mainly becuase I felt the temps that I was pulling both the speedo and motor off were fine. I am running two caps on the speedo though.
Old 06-30-2011, 10:30 AM   #20782
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Try any of the 7.5 setups from our team guys by simply putting your N motor to 0 degrees of timing.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 06-30-2011, 03:33 PM   #20783
L@gger's Avatar
Most are with really high boost 30+ what would be up to 60+ . So the inbuilt motor timing of ballistic in N is similar to redline at 10?
Old 06-30-2011, 04:13 PM   #20784
nashrcracer's Avatar
R/C Tech Charter Subscriber
Anybody with a good RO and settings for trinity Duo 2 13.5 1S 12th scale on a 150'x75' pavement open road course. I searched the thread and couldn't find what I was looking for. And I'm going out of town to this track and just trying to find a couple of combos to try out in qualifers when I'm there. hard to get clean open practice with nitro cars.
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 06-30-2011, 05:42 PM   #20785
Buckaroo's Avatar
Slightly off topic, but what's the difference between a "Torque" rotor and a "Standard" rotor with the Tekin redline motors? I'm guessing there's a difference in gauss, but which direction vs. "Standard"? Also, does a larger diameter rotor run hotter or cooler vs. a smaller one?
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 07-01-2011, 08:48 AM   #20786
Team Tekin
Randy_Pike's Avatar
In general a larger rotor will have more torque, less rpm, and run cooler when geared properly.
Our HT rotors can both be larger in OD but also smaller in ID. The gauss can be as much as 35% stronger when switching to a HT Rotor...
Old 07-02-2011, 05:50 AM   #20787
ddesros2's Avatar
I have a RS with 1S oval setup (with 220life rx pack). 17.5 motor. Hot wire setup as brushless fwd/brake. RS accepted set points from 4pk, but lights 1/2 and 6/7 blink. Per the manual it's incorrect motor selected. Could this be a back sensor wire? Bad motor? Thanks
ddesros2 is offline   Reply With Quote
Old 07-02-2011, 06:42 AM   #20788
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
it can also show this when the rx doesn't get enough voltage,plug a 2s in the esc to see if it 12,67 come back
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 07-02-2011, 07:53 AM   #20789
ddesros2's Avatar
Tried with 2S and all works fine. Thanks
Old 07-02-2011, 08:40 AM   #20790
It would be hepful if you could post a screen cap of the Dashboard settings.
Tekin can run without sensor wire.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
