Tekin RS ESC sensored >
Old 06-22-2011, 09:55 PM
  #20746
mok
mok's Avatar
Hi Randy,
I've just noticed an interesting characteristic of dual mode and was wondering if this is considered normal.
it was noticed when I free revved a motor (yes i know i should not do this) to try and understand the way the ramping was working..
i have the esc configured as follows..
vegas 212
dual mode
timing - 100
start rpm - 10000
end rpm - 32000
the motor is an LRP X12 4.5T (non-octa) with the -10 timing insert.
when the esc ramps up, its very smooth/linear..
however, when it reaches full throttle/rpm motor stops climbing rpm and then almost appears to kick back to a a lower rpm (or maybe timing?) and is held there..
i did not notice this when running < 100 timing on the esc..
but i guess its possible that it was there, but not as noticeable due to the less timing..
is this considered normal?
maybe some sort of protection routines in the esc?
..or worse, could this be a fault with the ESC itself?
having never used dual mode before i'm unsure as to whether or not this should be happening..
you comments would be appreciated!
thanks,
Mark
ps. the tekin capacitors.. any reason why you chose 16V 330uF ?
i've got an LRP capacitor bank attached (in addition to the tekin cap) which has 3 x nichicon lg 10V 820uF caps..
mok is offline
Old 06-23-2011, 07:06 AM
  #20747
ATLASCOPCO's Avatar
Originally Posted by JR007
Yep, that's how reverse is engaged.
You can change the settings to remove reverse, and have brake only.
What setting dose this is it reverse speed
ATLASCOPCO is offline
Old 06-23-2011, 09:07 AM
  #20748
Bob~H's Avatar
The setting is motor type.
Bob~H is offline
Old 06-23-2011, 09:14 AM
  #20749
mok
mok's Avatar
not trying to be offensive, but this does explain it all..
http://www.teamtekin.com/hotwire_RS.html
mok is offline
Old 06-23-2011, 11:12 AM
  #20750
mok
mok's Avatar
Originally Posted by mok
Hi Randy,
*SNIP*
your comments would be appreciated!
thanks,
Mark
i think i just answered my own question but would like this verified..
the change in rpm i am seeing when free revving to max rpm appears to be when the esc drops from sensored mode to sensoreless mode..
when i set the same boost/timing setting as i had in dual mode (ie. 30 degrees, 0 turbo) the motor stays at the peak rpm and does not drop down a little as it does in dual mode..
-Mark
mok is offline
Old 06-24-2011, 04:38 AM
  #20751
ATLASCOPCO's Avatar
Thank you,
all done and working fine
Old 06-24-2011, 05:05 AM
  #20752
Originally Posted by sandsurfer
Anyone have any ideas? Running 2s if that matters.
It sounds like your speedo is gone into brushed mode.
Maybe you should also reset your radio trims, then reset the speedo.
Try also servo reverse on radio.
Check all you receiver connection, if you have a second one try it also.
These are a few ideas to try before looking to send the unit for repair
See ya
olly986 is offline
Old 06-25-2011, 03:21 PM
  #20753
Exclamation Cap size for rs pro
Hello sorry to butt in but I noticed you were talking about cap size.I've bought a second hand rs pro.The cap size is 16v. 2200uF is this correct or not.I don't know how to work out what size should be used.Need advise please.
Autotek1st is offline
Old 06-25-2011, 03:38 PM
  #20754
M-Technic's Avatar
Trader Rating: 15 (100%+)
The cap is supposed to be 16v 330uf.
M-Technic is offline
Old 06-25-2011, 09:26 PM
  #20755
Yazid_TA05-IFS's Avatar
what will happen if putting more that? Will it damaging the ESC?
Yazid_TA05-IFS is offline
Old 06-25-2011, 10:10 PM
  #20756
Trader Rating: 32 (100%+)
Default Strange problem
Ok sorry not trying to change any topic but have a quick question. I had what I thought a motor go bad I change it and then everythig was fine and then change it again to test 13.5 motor & it acts like a bad sensor wire & cuts on on low end on a murffdog & thunder power but fine on the Orion & tekin all 13.5 or 10.5 motors. All test with same & new sensor wires Someone at track mentioned the bec board might be bad or....?
arnie84 is offline
Old 06-28-2011, 07:53 AM
  #20757
poochy's Avatar
Default turbo loss
hi, i am losing turbo after a few minutes of mod sedan racing. everything had been working fine for about 3 months until the track changed, it now has two 150 ft. straights instead of one.
motor temps are always under 170.
what have others done to fix this? ive read the recalibrating the throttle end points fixes it for some but not for others. hard to believe its the sensor cable since it always works at the beginning of the race. please help!!!
poochy is offline
Old 06-28-2011, 08:40 AM
  #20758
Team Tekin
Randy_Pike's Avatar
Radio calibration can be a part of this. Some radios "wander" more than others. Over shooting your calibrated epa point can correct this. Calibrate the RS/RS Pro with epa's set to 100. Then bump your high or throttle EPA to 110.
Randy_Pike is offline
Old 06-28-2011, 08:59 AM
  #20759
L@gger's Avatar
Can anyone help me with my problem?
I am having ballistic 7.5 and tekin RS on my 2wd buggy. Ballistic has 35 deg endbelt timing and on tekin I have 5000-20000 RPM 20 boost. My problem is that it is irregularly pushing to much in low rpm.
I found tekin setups mostly with 12 deg timing on redline motor. I thought that novak / tekin has probably the same standart and I did the same and added a high boost of 35 deg. I thought that it will be running more consistent but it doesnt and it is braking when trigger is in neutral. So I was forced to put it back to 35 and as I heard its useless to put higher timing than 55. But what is the difference with inbuild timing between redline and ballistic motors please? So what way to go to get my drive more consistent please? Thank you
L@gger is offline
Old 06-28-2011, 09:37 AM
  #20760
Team Tekin
Randy_Pike's Avatar
What do you mean it's "pushing?"
