Old 01-12-2009, 10:41 AM   #2056
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Foodie, if led's 1,2 and 6,7 are lit it showing wrong motor type selected.
For 13.5 in 2wd here's my setup in my XXX CR:
NW 10
BS 80
TP 3
Motor timing at 20
Boost at 10
Geared 78/26-27 depending on layout.
The Tekin RS is easliy one of the most adjustable esc's out today. I know it can be overwhelming at times but anyone looking for setup help can email me for assistance: [email protected]
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 01-12-2009, 11:39 AM   #2057
racing_jason's Avatar
Hey guys i have a 13.5 in my T2 i was just wondering what you guys are gearing for a flowing tack?
Thanks Jason
Thank you to my sponsors-
Team Associated-Reedy-ProLine-B&B Hobbies Racing
racing_jason is offline   Reply With Quote
Old 01-12-2009, 03:20 PM   #2058
shadow102's Avatar
Trader Rating: 21 (96%+)
Thanks Jason
In my rubber tire cyclone I am running 4.8fdr with about 18boost one a speed passion motor at stock timing
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 01-12-2009, 06:29 PM   #2059
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Originally Posted by g12314 View Post
Kraig,
Curious to hear what gearing / boost setup you ended up with. Down at The Track, I was gearing 2 teeth lower and had the boost at 8. Wasnt giving anything up on the straight, and out of a corner I could pull most cars due to my FDR advantage.
Jimmy
I will let you know about the boost once I get everything unpacked. Right now it is in a neat pile...in the entry way. I did crank the timing up on the motors though. Dropped about 4 teeth on the 13.5 with boost of 23. Looks like I got some work to do.
I never ran a 17.5 until this past weekend so I have nothing to compare it with.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-13-2009, 09:53 AM   #2060
DMH
Default Boost
Can someone explain what boost is and what it does for the gearing setup. Thanks
DMH is offline   Reply With Quote
Old 01-13-2009, 09:56 AM   #2061
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Boost = Timing. The more timing you have the more RPMs. Also the more timing you have the higher FDR you will need to run.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 01-13-2009, 10:37 AM   #2062
I will try to explain to you what boot is.. I think I've just started to get a grip on these terms... so if I'm wrong someone will chime in to correct me
I'm assuming here that you use a sensored motor.
Pre 189 software works in Hybrid mode. In those mode you start in sensored mode. Here you will use the physical timing advance in the motor if any. At one point in time the esc will switch to sensorless mode and it will apply the timing advance configured in the esc by the hotwire. If you switch to sensored only mode... the timing advance configured will be ignored and only the physical timing advance in the motor will be used.
in 189 software, you still have the ability to use hybrid mode as per above. but when you switch to sensored only you have the option to add boost which is timing advance that works when in you are in sensored mode... this works over and above the physical timing advance that you have in the motor.
gortan is offline   Reply With Quote
Old 01-13-2009, 11:40 AM   #2063
Team Tekin
Randy_Pike's Avatar
Gortan is pretty much correct.
In Dual mode, we use the sensors to start. Once we are rolling we're using sensorless operation with the Timing the user has set in the esc.
In Sensored only mode we use the sensors entirely. This is where the motor timing and timing boost when added together give you your timing.
Old 01-13-2009, 01:28 PM   #2064
fatbear's Avatar
Send a message via Yahoo to fatbear
Randy, did I read somewhere that in Dual mode the motor is more efficient?
If so would this then be a better choice than sensored only for Modified Touring where run time can be an issue?
Darren
Team Associated www.teamassociated.com
Team Tekin www.teamtekin.com
B-Fast R/C Performance www.bfastrc.com
JConcepts www.jconcepts.net
Ace Hobby Distributors www.acehobbyaustralia.com
fatbear is offline   Reply With Quote
Old 01-13-2009, 01:46 PM   #2065
Krio's Avatar
Trader Rating: 150 (99%+)
The only real benefit of boost is for 10.5, 13.5 and 17.5 motors. Dual mode has rather soft brakes, but if they are enough for you then there go for it as it is a touch more efficient. I have my B4 w/17.5 on software 1.89 and B44 on 1.80 in dual mode because it has a smoother power band for my loose track.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 01-13-2009, 02:37 PM   #2066
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
With the proper use of boost and gearing you can get a motor that is very fast on the strait and very fast in the infield. It took me around 10 runs to get my Duo 13.5 to where I want it. Once I found the sweet spot with the boost I was getting .2 better lap times vs 1.80 and endbell timing.
Oddly enough, another 1.89 + Duo user at the track came to the same numbers as me for his motor. Think we should have shared data, would have been quicker.
ChristopherKee is offline   Reply With Quote
Old 01-13-2009, 03:53 PM   #2067
CREWMAN's Avatar
Trader Rating: 19 (100%+)
Ok i am thinking about getting this esc for my 1/12 scale. Other then the motor limits what is the difference between the pro and the standard rs. I am only running stock. Will i be loosing anything?
i like the pro but i think that the standard rs being lower mybe better.
D&K HOBBIES!!!!
Losi 8ight-T 2.0 Race Roller/Losi 350/JR 9100 Servos/Spektrum DX3R
BMI Copperhead 12/Thunder Power Lipo/Futaba Servo/Express 17.5/Spektrum DX3R
CREWMAN is offline   Reply With Quote
Old 01-13-2009, 04:10 PM   #2068
TRF415boy's Avatar
same speedo but less fets (only one board worth of fets, which is still 24 FETs btw like a LRP), if you run stock no need for the pro.
TRF415boy is offline   Reply With Quote
Old 01-13-2009, 05:25 PM   #2069
Krio's Avatar
Aside from the motor limit and height there is absolutely no difference.
www.kriostasis.com
Old 01-13-2009, 05:34 PM   #2070
CREWMAN's Avatar
cool thanks
also will novak motors work with this esc? reason i ask is that i already have them
D&K HOBBIES!!!!
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
