Old 06-14-2011, 02:59 AM   #20671
Originally Posted by bvoltz View Post
Had an interesting thing happen this weekend with my RS. When I would apply changes to it, then plug everything back in, I would have to recalibrate with the radio. Now to make it even more interesting this only happened early in the day. Not after say 2 hours. It did not loose the setting only wanted to be re calibrated.
Any ideas what would cause this?
I'm picking it was a poltergeist invoked by a Novak driver by using an RS shaped Voodoo doll soaked in the sweat of starving goats.
I could be wrong though.
Agama A8 Evo | GRP .21 | Spektrum | Savox
My car just hit 88mph. I hope it comes back soon....
JR007 is offline   Reply With Quote
Old 06-14-2011, 09:16 PM   #20672
Trader Rating: 65 (100%+)
Send a message via ICQ to Barneys Racing Send a message via AIM to Barneys Racing
I've recently had a problem with my RS. I put in a new D3 and the speedo started up with 1,2, 6&7 LEDS lit. I tried 3 motors, 3 sensor cables, 2 sets of wires, and 3 receivers. All with the same result. Software was checked and double-checked.
I got a replacement and the same thing happened. It actually happened to a total of 3 RSs.
Is it possible for a motor to trash the speedo? Wouldn't it just not work if the motor was bad?
Any suggestions? They take programming just fine, but won't run.
Barneys Racing is offline   Reply With Quote
Old 06-14-2011, 09:27 PM   #20673
cannon's Avatar
Trader Rating: 35 (100%+)
3 ESC's? It screams of another issue. Did you at any stage before killing the esc's try a different motor?
What was your soldering like? Clean with absolutely no solder crossing the wire posts? You would be surprised how many people cant solder well and get the solder in all the wrong places
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 06-14-2011, 09:36 PM   #20674
i thought the same thing, but the soldering was clean. I'm pretty good at soldering cleanly. One of the speedos was out of a friend's car that was working perfectly.
that's why i tried 3 different motors, sensor cables and wiring. Don't know what other things I could change.
the first motor tried on all was a known to be working motor that was used in my last race.
Old 06-15-2011, 01:29 AM   #20675
Give a look at this:
http://www.rctech.net/forum/electric...esc-issue.html
Maybe the speedo it's not the problem, it could be both a radio or a servo problem.
sirio76 is offline   Reply With Quote
Old 06-15-2011, 10:52 AM   #20676
hello all,
I will receive a trinity duo 3 10.5 and i would like to know the performance/feeling compare to an x12 or speed passion
My lrp x12 10.5 setups was :
- TP 2 / Current limit 75
- Boost 40 ( more than 40 make the motor too much kick up, hard to handle )
5600 to 20016
- Turbo 10 Ramp 1 Delay 0.3 ( i don't like when the turbo kick up the car, i prefer to have a linear power)
Motor timing 4 dot and FDR 5.9
X12 motors have a lot of torque and a crazy power with timing.
I ve checked the setup sheet on tekin website, all before 212 hotwire version are deleted
I m remember there were a lot of setup sheet with d3 motor on it, too bad...
Can someone give me a feedback to the trinity duo 3 motors handling ? and maybe a setup point
thanks
Manson is offline   Reply With Quote
Old 06-15-2011, 10:56 AM   #20677
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Is this a 1s application?
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 06-15-2011, 11:36 AM   #20678
mutley001's Avatar
Originally Posted by Manson View Post
hello all,
5600 to 20016
thanks
With the d3 I am running:
Boost 40
Turbo 10
Rpm start 5000 end 22000
Ramp 2
Delay 0.02
And one notch on motor timing (8*)
This is on a medium indoor track on carpet in a tc.
Geared around 8.0 fdr.
Hope it helps
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 06-15-2011, 02:12 PM   #20679
Suspended
Trader Rating: 86 (100%+)
at the end of the track day i see my tekin flashing nw and vc, can anyone tell me what that means?
littlealex is offline   Reply With Quote
Old 06-15-2011, 03:44 PM   #20680
Trader Rating: 217 (100%+)
According to the troubleshooting sheet I have, 1&2, 6&7 indicate "wrong motor type selected". That would be the first thing to look at.
Andy Koback is offline   Reply With Quote
Old 06-15-2011, 05:12 PM   #20681
Has anyone had an issue where you lose drag brake when you use the NO-TIMING profile. When I use the non-timing boost (blinky) profile, my drag brake is all but gone. I turn it up using the hotwire connection but it's still almost non existent. I'm at 30 now and still don't feel it. Anyone else have this issue?
DOTMAN is offline   Reply With Quote
Old 06-15-2011, 06:09 PM   #20682
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Running a lot of boost, gives a natural drag brake feel.
I would suggest recalibrating radio to esc, and getting used a higher number drag brake for blinky mode, to get the fell you were used to in boosted.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 06-15-2011, 07:07 PM   #20683
smilekt's Avatar
try make factory reset ..
Kuala Terengganu Rc Club Facebook
http://www.facebook.com/group.php?v=wall&gid=357083332025
smilekt is offline   Reply With Quote
Old 06-15-2011, 10:09 PM   #20684
thanks, very helpful. i will go through all the components.
Old 06-16-2011, 11:43 AM   #20685
Thanks, Dave. I recalibrated the radio a few times already. I'll try cranking it up to 50 and see it I can feel it.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
