Tekin RS ESC sensored >
Old 05-23-2011, 02:38 PM
  #20551
M-Technic's Avatar
Trader Rating: 15 (100%+)
Originally Posted by InspGadgt View Post
Ok well it has been awhile since I have ran my TC in the 17.5 boost class so I haven't posted here in awhile. I finally got to run it this past weekend with a new radio (New Spektrum Pro) and I am still having a bit of what seems to be a turbo fade issue...basically about half way through the race my car seems noticeably slower on the straight than other cars running the RS. Initially I start out the same speed as everyone else but just seem to have more drop off than everyone else. My motor temps in the low 150s and so far I have changed out the RS, the radio, and the motor. So I'm wondering if my battery could be falling off that much or if I should look at something else. Also I am not running fan on the motor and most if not all of the RS's I am racing against are running a fan. I don't remember my settings off hand but have tried many different things and typically run the same settings as others at my track. Any other suggestions of things for me to look at?
Same settings don't always work from driver to driver, motor to motor, car to car, etc. Your batteries could be dropping that much though. Voltage always drops throughout a run and on a bad battery it will be more pronounced.
M-Technic is offline
Old 05-23-2011, 10:52 PM
  #20552
waOscar's Avatar
Default Start RPM Settings
A lot of people recommend start RPMs for 10.5 or lower turn motors of 5 or 6k.
This seems low to me. I've used Novak data logger with 10.5 on the 3 tracks in my state. On the tight twisty carpet track the minimum RPM during a lap (ignoring starting or pulling away from hitting kerbs) was roughly 8000. On our large outdoor asphalt track the slowest corner had a motor rpm around 10500.
Correct me if I'm wrong, but is it best to have little timing on the motor when initally starting and then adding the timing as the motor winds up.
It seems to me that if your start RPM is less than the rpm on the slowest corner then you are adding timing right from initial throttle pull.
Be good if someone could clarify whats happening and whats the correct setup approach to take.
Cheers.
waOscar is offline
Old 05-24-2011, 03:36 AM
  #20553
tc3team's Avatar
Originally Posted by 2wdrive View Post
http://www.teamtekin.com/hotwire/ESC...n-TC-BD6-5.pdf
Try those setting.
You have too much timing comming in to soon. Your settings are for roughly 10.5t or higher turn motors.
+1.
In general, the higher the motor wind (13.5/17.5 etc etc) the more timing is used, 50 total timing appears to be "optimal", but the more heat the motor gives out, the quicker it is going to loose its peak power.
The reverse is said for lower turn motors as they already have the power without the need for timing as well.
tc3team is offline
Old 05-24-2011, 04:45 AM
  #20554
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Cheers.
your right,not everyone has a data logger to see this and going with a little lower start just smooths the the transition when the timing is added.some motor timing is good but to much will create heat
20 SMOKE is offline
Old 05-24-2011, 06:55 AM
  #20555
Krio's Avatar
Trader Rating: 152 (99%+)
Cheers.
Less timing does not equal more torque. The "perfect" timing at any given rpm equals more torque. People recommend 5-6k start rpm's because these motors produce more power when the timing starts to kick in there. It doesn't 'smooth' the power out, it makes the power 'always there' so you don't have a drop in power and then the kick later on once the esc ramps back up to the appropriate timing.
Krio is offline
Old 05-24-2011, 07:07 AM
  #20556
Mr. MR4's Avatar
What start rpm for 13.5 boosted would you recommend for a track with 4 hairpins?
Mr. MR4 is offline
Old 05-24-2011, 08:12 AM
  #20557
Team Tekin
Randy_Pike's Avatar
We need a LOT more info than just "hairpins."
Track dimensions, layout, motor used, average lap times,etc.
Randy_Pike is offline
Old 05-24-2011, 08:52 AM
  #20558
tc3team's Avatar
Is there a link / picture of the track online that you could show us?
tc3team is offline
Old 05-24-2011, 09:38 AM
  #20559
Mr. MR4's Avatar
Here is a video of the track
http://www.youtube.com/user/rangerover25?blend=7&ob=5
Staright is around 90 feet long. Average lap time 16 sec.
Motors being used are GM 13.5 and Speed Pasion 13.5 (12.3mm purple ring rotor)
Mr. MR4 is offline
Old 05-24-2011, 09:44 AM
  #20560
Team Tekin
Randy_Pike's Avatar
Ok, that's longer than 90ft. I'd wager more like 140f at least.
That being said I'd try Hara's 17.5 setup:
http://www.teamtekin.com/hotwire/ESC...C-IIC-2010.pdf
Old 05-24-2011, 09:49 AM
  #20561
Mr. MR4's Avatar
Thanks Randy
What gearing shall I start off with since im using 13.5?
Mr. MR4 is offline
Old 05-24-2011, 12:01 PM
  #20562
wingman2's Avatar
Hi guys, sorry if this has already been asked, but is there any advantage to run more than one cap with the RS Pro? I noticed 'other' companies do use more than one cap, so would there be any benefit with the Tekin?? Cheers, Chris.
wingman2 is offline
Old 05-24-2011, 12:23 PM
  #20563
Krio's Avatar
The main benefit is a cooler running esc. If you aren't running hotter mod motors there is no need with the RS pro.
Krio is offline
Old 05-24-2011, 12:24 PM
  #20564
hairy's Avatar
Well folks it has happened AGAIN!
For the seventh time since November of 2010 a Tekin ESC has FAILED on me!This time is shows that I have the wrong motor selected.After a conversation with Tekin it has been determined that the ESC has failed and will neeed to be replaced!!!!!!!!!!!!!!!!!!!!!!!!!!!
Before you jump on me and tell me I must be doing something wrong The first Six failed because a problem with the process in which it was made.This time it just decided in between runs that it didn't want to work anymore and couldn't tell what motor I have in it.
Alas another race day sitting at home because of Tekin equipment failure.
hairy is offline
Old 05-24-2011, 12:51 PM
  #20565
PitNamedGordie's Avatar
Not trying to fan the flames, but has this one failed 7 times or have you bought seven Tekin ESCs and they have all failed?
PitNamedGordie is offline
