Old 01-10-2009, 11:53 PM   #2041
Trader Rating: 50 (100%+)
Send a message via MSN to Jaz406
Default New Speedo
I'm looking at buying a new speedo for the sedan. I run 13.5 and 17.5 so the cooling issues are not there for me. I want absolute punch and top end. What have you RS owners been playing with to get the best of both worlds?
Also what were your initial thought on the speedo?
Jaz406 is offline   Reply With Quote
Old 01-11-2009, 12:18 PM   #2042
jkirkwood's Avatar
Is it considered better with the 180 firmware to run the high wind motors (13.5 and 17.5) in sensor only or hybrid mode?
jkirkwood is offline   Reply With Quote
Old 01-11-2009, 12:32 PM   #2043
miller tyme's Avatar
Sensored only will yield better performance with those winds
Ken Miller
RCTarget - Capricorn - Pro Level RC - MAX Power - Maxima Fuel - EA Motorsorts - TQ Wire
LONG LIVE OPEN MODIFIED
miller tyme is offline   Reply With Quote
Old 01-11-2009, 01:10 PM   #2044
Victory Side's Avatar
Send a message via Skype™ to Victory Side
I feel a little confused. I just bought an RS and RS pro. Should be here this week. All the terminology and info involved in these esc's. Do I need to be an electric genius to get these to work right? Who can I talk to to get help. I am at zip code 17086.
WWW.RICHFIELDRACEWAY.COM
"There are only two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle." ~Albert Einstein
"Do you want to know who you are? Don't ask. Act! Action will delineate and define you.'
Victory Side is offline   Reply With Quote
Old 01-11-2009, 01:50 PM   #2045
jkirkwood's Avatar
Victory,
No need to be an electrical genius. The basics are still the same. Gear a motor correctly and it will be fast. With the exception of stock motors motors have always had the ability of adjustable timing. With sensored technology that adjustment is not only on the motor but in the ESC.
Most of the talk you've read about of late is in regards of the new beta firmware version 189 (some have access to it, some don't). Since we don't have brush cuts and springs to play with anymore many of the tinkerers have moved over to the esc programming side of things to find an edge. Unlike some other ESCs on the market the Tekin has the ability to be fine tuned by the Hotwire software. This makes nice for those that like to try to squeeze every joule of energy out of the power plant we can get out of it.
miller tyme, thanks for the response.
Old 01-11-2009, 02:51 PM   #2046
Thanks, that is helpful. I dont mind tinkering, but dont want to work all day to get it right. Thanks
Old 01-11-2009, 03:01 PM   #2047
yodace's Avatar
R/C Tech Charter Subscriber
What are some good setting for a 13.5? Anyone else having problems with a delay on power? noticed it on the straight away.
yodace is offline   Reply With Quote
Old 01-11-2009, 08:37 PM   #2048
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Randy, thanks for hooking me up with the 1.89 software. I still don't think that I found the right gearing but was getting closer and closer by the end of the Novak race. I ended up finishing 5th in 17.5. 13.5 wasn't as favorable but the racing in that class was really close. Oh well, next time.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-12-2009, 02:42 AM   #2049
Can i plz get some support to my problem from this post:
http://www.rctech.net/forum/5274316-post2027.html
I borrowed another speedo though, but still i dont hope the speedo is dead... If it was dead i wouldnt be able to turn it on?
Foodie is offline   Reply With Quote
Old 01-12-2009, 05:12 AM   #2050
TRF415boy's Avatar
Have you tried disconnecting the sensor wire? I've had similar problems before when my sensor board went wrong. I know you tried another motor but maybe if the sensor cable is damaged it could do the same.
TRF415boy is offline   Reply With Quote
Old 01-12-2009, 05:15 AM   #2051
TRF415boy's Avatar
Tekin TQs the 4th round of the British Indoors Winter Series.
I used a Tekin RS pro, Redline 10.5 and Tekin Power Cell 3400 to take the TQ spot on sunday.
Just want to thank Tekin for their support throughout those years and the renewal of their confidence for 2009.
Old 01-12-2009, 05:31 AM   #2052
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
What chassis are you running it in? The only time I ever had a delay problem is with iether too much timing or bad sensor cable.
-Wayne
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 01-12-2009, 05:38 AM   #2053
I used the exact same cable with a Nosram speedo the rest of the heats... so the sensor cable works...
Old 01-12-2009, 06:29 AM   #2054
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
Kraig,
Curious to hear what gearing / boost setup you ended up with. Down at The Track, I was gearing 2 teeth lower and had the boost at 8. Wasnt giving anything up on the straight, and out of a corner I could pull most cars due to my FDR advantage.
Jimmy
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 01-12-2009, 08:54 AM   #2055
yodace's Avatar
-Wayne
i have a 13.5 in it now forgot to mention that in my earlier post..
i have it a xxxcr. I had a 9.5 in it i didnt notice any problems. timing is set to 100 for the 13.5<<<neutral width is set to 10...
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
