Tekin RS ESC sensored >
Old 05-19-2011, 05:29 PM
  #20521
nerdling's Avatar
Default Voltage Booster
Hi Guys,
I'm taking delivery of a 12th scale this weekend, I'm planning to use my Teking RS Pro. Will I need to use a voltage booster to en sure that the Radio gear gets sufficent voltage?
Mark
nerdling is offline
Old 05-19-2011, 05:41 PM
  #20522
20 SMOKE's Avatar
Trader Rating: 102 (100%+)
Originally Posted by nerdling View Post
Hi Guys,
Mark
yes buy the tq one
20 SMOKE is offline
Old 05-19-2011, 09:51 PM
  #20523
nerdling's Avatar
Originally Posted by 20 SMOKE View Post
yes buy the tq one
thanks. any details on the tq booster? part no, where I can get one?
nerdling is offline
Old 05-20-2011, 12:02 AM
  #20524
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
http://www.tqcells.com/TQBOOSTER.htm
RedBullFiXX is offline
Old 05-20-2011, 01:54 AM
  #20525
Would one of the Tekin Team kindly give me some advice on settings for the following UK track. Track is approx 40-45 metre straight (approx 130-140 ft) and is very grippy
Will be running a Trinity Epic D3 (13.5) in a HB TCX
My thoughts are (correct me if wrong)
End point 18000 (approx)
Start 3500 (approx)
Ramp 3
Boost 50
Turbo 16
Timing 50
Profile 3
Delay 0.5
No timing on motor and approx gearing 7.12
thanks for your help
john
Jo90uk is offline
Old 05-20-2011, 02:19 AM
  #20526
that is a picture of the old adur track not the one you will be racing on for the stcc
Smartypants is offline
Old 05-20-2011, 05:49 AM
  #20527
nerdling's Avatar
Originally Posted by RedBullFiXX View Post
thanks
nerdling is offline
Old 05-20-2011, 07:24 AM
  #20528
daverobbo5's Avatar
Trader Rating: 45 (100%+)
Originally Posted by Monkeys punk View Post
I use a receiver extension cable and that takes the strain off the RS plug.
daverobbo5 is offline
Old 05-20-2011, 07:25 AM
  #20529
daverobbo5's Avatar
Originally Posted by hairy View Post
Try putting a section of shrink wrap on the plug and wire where they come together. That will relieve some of the strain.
good idea. thanks!!
Old 05-20-2011, 07:26 AM
  #20530
daverobbo5's Avatar
use a 2-3 in servo extension
will do.
Old 05-20-2011, 07:42 AM
  #20531
M-Technic's Avatar
Trader Rating: 15 (100%+)
Start 3500 (approx)
Ramp 3
Boost 50
Turbo 16
Timing 50
Profile 3
Delay 0.5
john
I haven't run 13.5 in a while but here is my input:
Your start RPM doesn't need to be so low for such a large track. 5,000 or even 8-9,000 RPM for a 13.5 on a large flowing track will be fine. Go to like a 22,000-25,000 end. Decrease your turbo delay to about .3 or so. You might want to start with less turbo than 16. Not sure on the gearing.
M-Technic is offline
Old 05-20-2011, 08:50 AM
  #20532
GBOGH's Avatar
Originally Posted by Randy_Pike View Post
Try these settings with your orange motor set to N.
http://www.teamtekin.com/hotwire/ESC...dBuggy_212.pdf
I'll give that a shot, it's a duo 3 and a tekin 17.5 that I have. I'll set these both to 0. I'll try those settings with turbo and adjust motor timing from there, looks like James and I for trans ratio and gearing are setup the same so I'll be giving this a shot tonight when I go race, thanks for the help Randy.
One question aren't we "supposed" to not go over 60* timing with boost and endbell timing combined? What about when you add the turbo? Or does that just actually ramp up the rate of boost it's giving until max boost / rpm?
Thanks for the help even though this was in the on-road section.
GBOGH is offline
Old 05-20-2011, 09:21 AM
  #20533
Team Tekin
Randy_Pike's Avatar
60 is a relative figure,yes. However in some cases it can work. You're flirting with a line of failure...sounds like racing
Randy_Pike is offline
Old 05-20-2011, 09:23 AM
  #20534
tc3team's Avatar
Jo90uk, the new track Adur has now is much bigger, and can be viewed here:
http://www.teamwilliams.co.uk/Adur%20Track.jpg
tc3team is offline
Old 05-20-2011, 09:44 AM
  #20535
cwoods34's Avatar
Even though my question wasn't answered directly the info on gearing and drag brake helped. I'm running around 6.0 on the 10.5 and all ESC boost, 0 timing on the motor, so it is super torquey. I'll see if I can find a setup nearly as fast with timing on the motor and see if it smooths out the drag brake any.
cwoods34 is offline
