Old 05-19-2011, 01:23 PM   #20506
Monkeys punk's Avatar
Originally Posted by daverobbo5 View Post
Hello, all Tekin users.
has anyone found that the receiver wire on their Tekin gets a bit 'tired' after pulling it out to use the hot wire?
the hot wire and software is a top idea but through the receiver? just seems a little fragile.
happy to hear any suggestions
I use a receiver extension cable and that takes the strain off the RS plug.
Monkeys punk is offline   Reply With Quote
Old 05-19-2011, 01:26 PM   #20507
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Originally Posted by GBOGH View Post
The tracks are both OCRC and Westcoast RC located in Southern California. I can't post links to the tracks from liverc.com, their cameras are both live right now, but the straights aren't that large, I'd say 80FT at most? for both tracks.
Try these settings with your orange motor set to N.
http://www.teamtekin.com/hotwire/ESC...dBuggy_212.pdf
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 05-19-2011, 01:27 PM   #20508
Team Tekin
Randy_Pike's Avatar
Originally Posted by slashdriver View Post
I am running almost the same settings as posted on Atsushi Hara's setup sheet on the tekin website, which is almost identical to the recommendations from murfdogg.
17.5 touring car.
when you let off the throttle at all, even the slightest, it feels like you've thrown out the anchor and have 50% drag brake, or maybe like ALLL of the timing is going away as soon as I drop off 100% throttle.. very difficult to modulate the throttle just a little bit to negotiate a corner or something... any idea how to smooth this out?? The car rolls very freely otherwise, it's not the car mechanically.
212
boost = 48
start rpm = 5500
end rpm = 20000
turbo = 12
turbo ramp = 2.0
turbo delay = .14
drag brake = 0
6.6 FDR
profile 4
motor timing turned all the way down (duo 2)
big asphalt track, 170' straight.
Say fore xample a corner I need to let off just a tiny bit of power to get the car to roll through the corner, when I let off a tiny bit, it is like i hit the brakes even though i'm still holding 90% throttle!
What you've got to understand is that this motor was not meant/designed to spin the rpm's we're spinning it at! lol
Try adding some push control to your setup. This will prevent the car from diving into the corner off throttle.
Old 05-19-2011, 02:04 PM   #20509
Originally Posted by 20 SMOKE View Post
current limiter is punch control
Oh hehe
What about the second cap why will it lower esc temp and will one cap 16V 660uF do the same as 2x 330uF?
dark_luna is offline   Reply With Quote
Old 05-19-2011, 02:14 PM   #20510
hairy's Avatar
Try putting a section of shrink wrap on the plug and wire where they come together. That will relieve some of the strain.
MERLIN RACING
"He once ran a marathon because it was on his way"
Logic is a lost art!
You are defined in life by how you respond to defeat!
hairy is offline   Reply With Quote
Old 05-19-2011, 02:21 PM   #20511
cwoods34's Avatar
I have a question on drag brake. I like a high value but it engages quite hard on a boosted 10.5 (carpet track) and I don't want to destroy the spur gear or drivetrain.
I've been trying to use the hand brake with about 30-40 expo on the radio (DX3R) and it is very smooth. It stills stops very quickly but doesn't "dive" or kick the back end around. I was wondering if there was a way to do this with the drag brake?
Also, does the "minimum brake" setting affect BOTH hand and drag brake?
Thanks! The 10.5 boosted sounds like a chainsaw going down the backstretch
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 05-19-2011, 02:46 PM   #20512
Trader Rating: 18 (100%+)
Sorry if this has been asked before but, what exactly does push control do? How does it affect drag brake and how does it affect the massive brake reaction once you come off of full throttle?
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 05-19-2011, 03:02 PM   #20513
I use push all the time but couldnt manage without it in my 12th scale. I find it lets the motor coast for a bit after you let off the throttle dependant on how you set it. Just allows you to roll into the corner better. Push is the one thing I missed when using other speedos.
Old 05-19-2011, 03:07 PM   #20514
M-Technic's Avatar
Trader Rating: 15 (100%+)
17.5 touring car.
212
boost = 48
start rpm = 5500
end rpm = 20000
turbo = 12
turbo ramp = 2.0
turbo delay = .14
drag brake = 0
6.6 FDR
profile 4
The drag brake feel is from all the torque being exerted on the drivetrain when you lift. Go back to 0 motor timing (or even slightly advanced timing) and increase your FDR closer to the low 6's, maybe even high 5's with a track that large. With a 6.6 FDR and fully negative motor timing I don't know how you would even make it down a 170' straightaway.
Making those changes will greatly reduce the "checking up" feeling when you lift.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 05-19-2011, 03:57 PM   #20515
Trader Rating: 77 (100%+)
Will that help only off throttle? THe problem I'm having is when I let off the throttle even only a little bit (for example, going from 100% to 90% on the trigger to get a bit more steering through a chicane) it feels like brakes!
slashdriver is offline   Reply With Quote
Old 05-19-2011, 04:05 PM   #20516
Team Tekin
Randy_Pike's Avatar
Don't lift! kidding.
Again if you're zooming on a 17.5 this can be the case. Push control won't help this issue. It shouldn't feel like brakes though.
Which motor? Is one worse than the other?
Rp,
Old 05-19-2011, 04:16 PM   #20517
warnos's Avatar
17.5 touring car.
212
boost = 48
start rpm = 5500
end rpm = 20000
turbo = 12
turbo ramp = 2.0
turbo delay = .14
drag brake = 0
6.6 FDR
profile 4
My car feels like that as soon as my gearing gets any higher then 6.2 the car is very unsettled when coming off the throttle..to change it I use a little push control and it did help a bit.. With my Duo 3 I had to get the gearing back down under 6.1 if u can.. stop the twitchy feeling..
Cheers
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
Old 05-19-2011, 04:17 PM   #20518
This was helpful - thanks. I thought I "remembered" that the fully retarded timing position on the motor was 0, but I did a quick search and it looks like that's actually the -20 position. I set it back to "0" which is the middle of the range - will try again.
Old 05-19-2011, 04:27 PM   #20519
Suspended
Trader Rating: 86 (100%+)
have anyone experience the vegas not working on their laptop?
mine had a window show up saying my computer do not support the software
littlealex is offline   Reply With Quote
Old 05-19-2011, 05:01 PM   #20520
locked's Avatar
A high FDR does seem to increase the drag brake feeling as well as overall amount of brakes. I also found that a very low FDR (like in the blinky classes) results in nearly no brakes at all. Fortunately you don't really need brakes in those classes.
For 17.5 boosted, an FDR of 5.8-6.0 seems to be where my duo3 likes to be. Good punch, good top end and enough braking power, but can be coasted around a sweeper fairly easily.
I use a nearly identical setup to the one you posted slashdriver, but I have a little more can timing (2 notches on the plus side of center) and a slightly lower end rpm (around 17K)
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
