Old 05-18-2011, 08:10 AM   #20476
M-Technic's Avatar
Trader Rating: 15 (100%+)
Originally Posted by 20 SMOKE View Post
i think i seen randy say turbo will,it was talked about in a oval setting but its been a while
Originally Posted by Randy_Pike View Post
This is true. Some boost must be set to use turbo.
He didn't specify how much is needed, however.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 05-18-2011, 08:16 AM   #20477
CFR
CFR's Avatar
TOTF (Timing On The Fly)
is there a well written article that covers this not just for the Tekin esc but in general?
CFR is offline   Reply With Quote
Old 05-18-2011, 08:53 AM   #20478
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
ah,i knew it was somewhere i thought i was on tekins forum
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 05-18-2011, 08:54 AM   #20479
20 SMOKE's Avatar
none that i have seen,each esc is different in there own ways
Jamie W
Old 05-18-2011, 10:14 AM   #20480
GBOGH's Avatar
timing and boost question:
I did a search through the thread but it's huge so I don't know if it's been already answered or not;
I am running a 17.5 setup offroad and when using the hotwire w/ the rs I noticed there's a spot for timing which is set to 80 and a spot for boost which I have set for 45, it runs well would like more low end, sitting at 3000-13000 with 8* timing on the motor ( trinity duo 3 ) and trying to understand what the timing portion should be set at, is 80 too high? Does it even work if in Sensored Only mode? I don't know what the timing portion does aside from the boost setting. Running 2.12 FWD Only , Sensored Only Mode still looking for more bottom end, my FDR as it sits without boost is almost 9.50:1
TIA
GBOGH is offline   Reply With Quote
Old 05-18-2011, 10:37 AM   #20481
GBOGH's Avatar
Originally Posted by entitymugenmtx View Post
I'm running a Ko Propo Eurus radio with a Tekin RS pro I calibrated at 100% H-point does it make a big difference if I go to 150% H-point
I'd like to know this as well, I'm running a m11x and I calibrated at 100%
Old 05-18-2011, 10:40 AM   #20482
M-Technic's Avatar
TIA
I don't know anything about offroad setups but timing advance is only used in dual mode. For sensored mode you will be focusing on timing boost and turbo. The RPM range dictates the range which the timing boost is applied.
Old 05-18-2011, 10:41 AM   #20483
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Originally Posted by dark_luna View Post
I have some problem with my electric touring car.
After aprox 3 min the ESC overheat, motor heat ok.
I have now change positions plus added a fan and I will also add another cap.
This should do it but I need some help with ESC setup.
Car: Kyosho TF-5 Shin
Tire: Rubber Slick
Gear ratio: 7.46:1 106T/26T 64P This wil likely drop to say 8.0 to 8.4ish
Battery: 2S 45C Lipo
Motor: Tekin Redline 4.5T (Stock timing)
ESC: Tekin RS Pro
Current Version: 212
Brushless Forward Only with Brake
Voltage Cutoff: 2S
Drive Mode: Sensored Only
Motor Direction: Normal
Throttle Profile: 3
Current Limit: 9570
Throttle Min: 0
Drag Break: Off
Brake Strength: 60
Reverse Speed: Off
Neutral Width: 3
Push Control: Off
Brake Min: 0
Timing Advance: Min
Boost: 020
Start/End RPM: 5443/200165-6k start, 30k end
Turbo: 5off until proper gearing is found.
Turbo Ramp: 1
Turbo Delay: 1.00
Im running on a large outdoor track and the straight is really long,
I could use a "second gear" to get some top speed but I can't feel any turbo kickin?
I have not tested the current setup but I used a similar last time but with Turbo 15 and Ramp 3.
Tested Turbo Delay from 0.5 - 2.0 with no difference.
I'd like to see the setup changes above in red. Adding a 2n TT3520 power cap will also help with heat. I'd like to see the physical layout in the car also.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 05-18-2011, 10:43 AM   #20484
Team Tekin
Randy_Pike's Avatar
Originally Posted by jlfx car audio View Post
I been running my rs pro for over a year without any issue . But this past weekend it seemed as if my current limiter was turned on but after checkin several times it shows off. Swapped motors,batt, settings. Tried several diff tunes. But could never get the bottom end to equal anyone else's . Anyone ever experienced this?
What software? What setup? What car? Motor? etc.
Old 05-18-2011, 10:44 AM   #20485
Team Tekin
Randy_Pike's Avatar
Radio "over" calibrating isn't really necessary anymore. However if you do experience erratic turbo operation,etc this can be the issue. If you feel this is the case simply calibrate your esc/radio at 100/100. Then bump your "hi" or "throttle" side to 105 or 110 MAX! Calibrating at 100 then bumping to 150 can and will cause other issues.
Old 05-18-2011, 10:46 AM   #20486
Team Tekin
Randy_Pike's Avatar
TIA
The "timing advance" is a dual mode or sensorless motor timing amount. If you're running sensored only setups this will not apply unless you have a sensor system failure.
Where are you geared in this offroad setup? How big is the track? Where is your "min throttle" set?
Old 05-18-2011, 03:15 PM   #20487
Great I will try that setup!
Actually current gear ratio are 8.08:1 106T/28T 64P but I was about to change to 26T but I will leave it then
I having problem finding a good layout in the Shin, when it overheated the esc was mounted behind the motor.
If this dont work Im planing to move RX on-top of the servo and add 2x 25mm high-rpm fans blowing directly on the esc.
I still havent add a second cap but I will before next testing
dark_luna is offline   Reply With Quote
Old 05-18-2011, 04:59 PM   #20488
Team Tekin
Randy_Pike's Avatar
That layout is much better. However you're still getting minimal air across the posts...
The 2nd cap will help.
Old 05-18-2011, 05:20 PM   #20489
Send a message via AIM to lightz2050
Default RS Pro Question
Hello all,
I just pick up an RS Pro and love it. If I run a 3S lipo, do I have to run an external RX battery or I could just plug and play without doing anything.
Please advice!
Thank You!
Phil
lightz2050 is offline   Reply With Quote
Old 05-18-2011, 05:40 PM   #20490
20 SMOKE's Avatar
Originally Posted by lightz2050 View Post
Hello all,
Please advice!
Thank You!
Phil
No it will run a 3s
Jamie W
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
