Old 05-11-2011, 01:50 PM   #20461
Mr. MR4's Avatar
Originally Posted by Mr. MR4
Did a couple of runs with my Tekin RS Pro in 1/10 TC (2S Lipo) GM 13.5 motor.
The problem I am having is that the time the turbo seems to be kicking in is varying, and some times it doesnt at all!
I have resoldered the wires, changed the sensor cable, put a new capacitor, done a factory reset and changed the motor and put up the epa on the transmitter (KO Propo) and problem is still there.
Any other suggestions?
Originally Posted by Randy_Pike View Post
This is either a setup that is off, or a radio system issue. So since you're using a KO are you calibrating the esc at 100/100 and bumping up the "hi" point to 105?
What is your esc setup? How big is the track? What is the layout like?
Hi Randy,
I tried out the same setup (Hara's IIC Setup with boost 18 instead of 14) with a speed passion 13.5 motor (motor timing 10 deg) and the speedo worked fine and was quick all day. Could it be that I have to use different settings for the GM (97294)13.5 motor? (No motor timing and 12.3mm purple ring rotor)
Track is technical with 2 hairpins and 80 foot straight .
Karl
Xray T4'16 HobbyWing Xerun 120A V3.1
Xray X1'16 HobbyWing Justock
Yokomo R12C3 HobbyWing Xerun V3.1
Mr. MR4 is offline   Reply With Quote
Old 05-11-2011, 01:55 PM   #20462
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
that straight is border line for turbo if you lift at any point it is useless,i dont use turbo under 100ft just to show that you dont need it,and yes you need to find what work for each motor no two are alike
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 05-11-2011, 02:12 PM   #20463
Mr. MR4's Avatar
20 smoke - Thanks
What gearing and esc settings do you suggest I use for the SP 13.5?
Old 05-11-2011, 03:17 PM   #20464
20 SMOKE's Avatar
most 13.5 are in the 6's so i would turn off turbo and use timing boost and gear it from there
Jamie W
Old 05-15-2011, 12:27 PM   #20465
Big Features's Avatar
Hey does anyone have a good FDR and ESC set up for SCT 13.5??
Thanks!
Mike
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix FDJ Sauce
Big Features is offline   Reply With Quote
Old 05-15-2011, 02:09 PM   #20466
Monkeys punk's Avatar
Got my RS back from Tekin repair Yesterday. Great service as ever and back on my doorstep within 3 weeks from the UK.
Cheers Randy
Monkeys punk is offline   Reply With Quote
Old 05-17-2011, 10:23 AM   #20467
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Thanks!
Mike
Mike FDR will vary from track to track, layout to layout.
Setup sheets are here:
http://www.teamtekin.com/hotwire/ESCsetups/index.html
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 05-17-2011, 12:23 PM   #20468
entitymugenmtx's Avatar
Trader Rating: 81 (100%+)
Send a message via AIM to entitymugenmtx
I'm running a Ko Propo Eurus radio with a Tekin RS pro I calibrated at 100% H-point does it make a big difference if I go to 150% H-point
SPONSORS.....MY CHECKBOOK....
entitymugenmtx is offline   Reply With Quote
Old 05-17-2011, 12:36 PM   #20469
Default Tekin RS Pro
I have some problem with my electric touring car.
After aprox 3 min the ESC overheat, motor heat ok.
I have now change positions plus added a fan and I will also add another cap.
This should do it but I need some help with ESC setup.
Car: Kyosho TF-5 Shin
Tire: Rubber Slick
Gear ratio: 7.46:1 106T/26T 64P (Pro driver says round 7 for this track)
Battery: 2S 45C Lipo
Motor: Tekin Redline 4.5T (Stock timing)
ESC: Tekin RS Pro
Current Version: 212
Brushless Forward Only with Brake
Voltage Cutoff: 2S
Drive Mode: Sensored Only
Motor Direction: Normal
Throttle Profile: 3
Current Limit: 95
Throttle Min: 0
Drag Break: Off
Brake Strength: 60
Reverse Speed: Off
Neutral Width: 3
Push Control: Off
Brake Min: 0
Timing Advance: Min
Boost: 0
Start/End RPM: 5443/20016
Turbo: 5
Turbo Ramp: 1
Turbo Delay: 1.00
Im running on a large outdoor track and the straight is really long,
I could use a "second gear" to get some top speed but I can't feel any turbo kickin?
I have not tested the current setup but I used a similar last time but with Turbo 15 and Ramp 3.
Tested Turbo Delay from 0.5 - 2.0 with no difference.
Is the Turbo function somehow dependent on Timing Advance or Boost?
When running 17.5T indoor the turbo worked great, though I had more timing and boost then now.
I would appreciate some tips
Heres a clip of the track in question.
Same car but then with Novak GTB and Velociti 4.5T
+ YouTube Video
dark_luna is offline   Reply With Quote
Old 05-17-2011, 12:51 PM   #20470
20 SMOKE's Avatar
you can add a second cap and i would run in dual mode to start off with,you only have 12* motor and 5 turbo you shouldnt be thermalling
Jamie W
Old 05-17-2011, 01:27 PM   #20471
Sorry I didnt mention this setup with turbo 5 is basically just to see that the esc dont overheat.
Thx I will test dual mode
Old 05-17-2011, 02:41 PM   #20472
M-Technic's Avatar
Trader Rating: 15 (100%+)
Turbo won't function without timing boost. I think you should be running dual mode though.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 05-17-2011, 03:36 PM   #20473
20 SMOKE's Avatar
i think i seen randy say turbo will,it was talked about in a oval setting but its been a while
Jamie W
Old 05-17-2011, 11:17 PM   #20474
I talked a about a minimum boost requierd for turbo lunch.
You need to have 25 boost minimum to activate turbo.
I was testing an lrp 4.5 octa wind on the sensored only mod, and i wasnt happy. Realy to much power and not smooth with throttle profile 1 and a lot of current limit.
I think you should try in dual mode.
Next week end i will try a speedpassion 6.5 ( smoother than lrp ) and boost it
Manson is offline   Reply With Quote
Old 05-18-2011, 07:37 AM   #20475
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
I been running my rs pro for over a year without any issue . But this past weekend it seemed as if my current limiter was turned on but after checkin several times it shows off. Swapped motors,batt, settings. Tried several diff tunes. But could never get the bottom end to equal anyone else's . Anyone ever experienced this?
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
