Old 05-04-2011, 08:17 AM   #20416
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
you dont need it but if the esc temp goes up then add a second cap
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 05-04-2011, 08:41 AM   #20417
JCarr's Avatar
Gorilla Size Racing
R10 USGT, TRF416 USGT, DB10R, TA05R VTA, R40, RS4 3SS, RS4 super, Savage, Hellfire.
Youthful enthusiasm only rules until old age and common sense exert themselves
JCarr is offline   Reply With Quote
Old 05-04-2011, 10:23 AM   #20418
M-Technic's Avatar
Trader Rating: 15 (100%+)
I didn't run 2 caps, I was using a 7.5 with 50 boost and 15 turbo on a large track in hot conditions. The ESC never got above 3 or 4 lights for temperature.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 05-04-2011, 10:27 AM   #20419
20 SMOKE's Avatar
thats good,and alot of timing
Jamie W
Old 05-04-2011, 11:12 AM   #20420
M-Technic's Avatar
Well, the motor was hot, but the ESC took it like a champ
Old 05-06-2011, 08:16 AM   #20421
Mundy1's Avatar
Trader Rating: 50 (100%+)
I am concerned with the light sequence I get from my new to me used RS with a 13.5 turn Redline motor.
The unit arms up proper and then I get the following sequence of lights:
Center led steady the blinks out to a temp indicater ussually 1 for a moment then all leds flash repeditive a few times then back to center steady then all flash repeditive back to center then 1 temp, all blink several times and back to center over and over.
I have rebound my tx/rx several times. It never seems to have a lost the signal because the esc and servo seem always reponsive. The radio sytem is 2.4 that hopps if that matters.
This is my first Tekin so I don't know if this is normal and part of the freq hopping or is somthing else going on?
I ran it last night and it seems to function just like it should. it is very responsive and takes program from Hotwire Vegas 212 just fine.
Mundy1 is offline   Reply With Quote
Old 05-06-2011, 08:21 AM   #20422
TrevCoult's Avatar
I have repaired my tx/rx several times. It never seems to have a lost the signal because the esc and servo seem always reponsive. The radio sytem is 2.4 that hopps if that matters.
To me it sounds like it is losing neutral. Try increasing your neutral width on the RS and see if it still does it.
Trev
Schumacher Atom GT12
Schumacher Eclipse 12th
www.carsrcracing.co.uk
CARSrcracing.co.uk Webmaster
Schumacher Racing
TrevCoult is offline   Reply With Quote
Old 05-06-2011, 08:34 AM   #20423
Mundy1's Avatar
Good point,
I did notice that neutral was set on this when I got it for 15 and I did not change that.
What would you recomend widening it too? 20, 25?
Old 05-06-2011, 08:39 AM   #20424
20 SMOKE's Avatar
trouble codes
Jamie W
Old 05-06-2011, 08:54 AM   #20425
Mundy1's Avatar
Thank you,
Looked at the trouble codes and what I have is:
The "Neutral" (normal) lights along with the no signal thrown in there.
But the esc reacts without any delay and shows all the ramp up and down during operation like it should as shown in "Throtle and Brake".
Once returned to neutral this odd blink starts again. during throttle or brake all is correct.
Maybe I should borrow a transmitter and reciever and see if it is correct with other equipment.
Old 05-06-2011, 09:22 AM   #20426
20 SMOKE's Avatar
re bind the rx/tx and do a factory reset
Jamie W
Old 05-06-2011, 09:40 AM   #20427
Mundy1's Avatar
A Factory reset with Hotwire or the buttons on the esc?
Old 05-06-2011, 09:44 AM   #20428
Mundy1's Avatar
Never mind just looked at the manual again. Push both buttons and hold 3 seconds.
Sorry for my lazyness.
I will try it after work and see what happens.
The help is wonderful. Thank you!
Old 05-06-2011, 09:50 AM   #20429
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
This can be a few things. What radio system are you using? Some Dsm systems "channel hop" while no input is being given.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 05-06-2011, 09:56 AM   #20430
Mundy1's Avatar
I am using FlySky FS-GT3B with AFHDS (automatic frequency hopping digital system)
Is this an issue for the esc?
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
