Old 04-30-2011, 01:36 PM   #20401
Originally Posted by JR007 View Post
What would you want it to do?
+1
races65 is offline   Reply With Quote
Old 04-30-2011, 04:51 PM   #20402
avs
avs's Avatar
Originally Posted by olegeezer View Post
done with tekin great controller when it worked reminds me too much like a victor iq charger great features but just not reliable.good luck with them.
pm your info, i can get you a great salvage price. (0.5* street price)
Tony Shimko
avs is offline   Reply With Quote
Old 05-01-2011, 03:48 PM   #20403
heh
bad thing to ask!
id like to be able to plug in a coffee pot into the tekin and it to make a flat white while im marshalling, and to finish brewing when i get back to the container
ed
Edwin Pibal is offline   Reply With Quote
Old 05-01-2011, 04:52 PM   #20404
warnos's Avatar
with the new 312 software due out next year its going to be able to mix Jack & Coke.. plus sms the misses telling her u will be home soon as there is an emergency at the track..
very upset with my tekin rs as stated in previous posts with the 12 67 leds flashing.sensor cable motor soldering poor ect.just got new sensor cable and a new speed controller.tried new sensor cable first still 12 67.installed new speed controller old sensor wire and motor and everything works fine.i'd say its probably like 90 percent of time it's the speed control.who can i talk to to see if tekin will cover a 3hr. of use tekin rs.had over 90 days but didn't know they have a self life.
Send ur RS back to tekin they will look after u.. the best after sales service in the RC industry when it comes to Speedies. Go to their website get an RA number and your good to go.. http://www.teamtekin.com/service.html
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
Old 05-02-2011, 01:14 PM   #20405
I ran 17.5 boosted this weekend and had a problem with my boost not coming in on the straightway the two first laps it came in but after that it was flat any suggestion?
gofasteddy is offline   Reply With Quote
Old 05-02-2011, 01:20 PM   #20406
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
add 10 to your th epa and try again if not post your setup
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 05-02-2011, 07:19 PM   #20407
M-Technic's Avatar
Trader Rating: 15 (100%+)
Originally Posted by gubbs3 View Post
I am assuming these custom throttle profiles are similar to throttle profile 1-5 but with certain customizable features. This has given me an idea. There could be a use for adjustable Timing profiles. I made a quick graph to demonstrate what I'm talking about. The first horizontal line is the fixed amount of motor timing and where the line takes a slope upwards is where boost kicks in over the specified RPM range. I purposefully did not include the turbo timing because it is based on full throttle and time delay and not related to RPM.
In the three graphs the first is what we have now. The second could be if boost profiles were added. This could be linear (middle), soft (lower), and aggressive (upper). It would change how fast timing was added once the motor enters the rpm range of the boost. The third graph would be manipulated timing over the entire RPM range starting at zero. Assuming zero motor timing the esc would start the motor out at a certain level of timing and add timing slowly over the lower rpm range. This could benefit on a tight infield keeping the esc from adding too much timing too quickly. The line then steepens as rpm increases in faster sections and levels out at the top range.
I'm not saying this is the way it should be, just another way it could (possibly) maximize performance and efficiency.
What you illustrated is basically the function of the RPM range for the boost. Closer RPM range = the timing is added faster. Spread out the RPM range = the timing is added slower.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 05-02-2011, 09:24 PM   #20408
rdlkgliders's Avatar
Trader Rating: 21 (96%+)
Default Tekin
nothing but love for my esc motor and hotwire, can't wait to be able to save profiles for different tracks though.
Tekin Sensored is the best i have used, if there is better i want.....NOW!
rdlkgliders is offline   Reply With Quote
Old 05-03-2011, 04:14 AM   #20409
jrxs-r's Avatar
What fixed it for me was to do a factory reset on the ESC and re-calibrate and program the timing settings again. Check the capacitor legs that they haven't broken off.
Cheers,
Zack
___________________________________________________________________________
Proudly Sponsored by Stanbridges Hobbies
Serpent S411
jrxs-r is offline   Reply With Quote
Old 05-03-2011, 07:45 AM   #20410
thanks guys.
Old 05-03-2011, 07:44 PM   #20411
Jsaves's Avatar
I am assuming the answer, but I thought I would ask. When using the new 550 sc motors should it be paired with a RS Pro?
Thanks and God Bless
Proud member of Magic City RC Racers
Magic City R/C (Facebook)
CRC GT-R
CRC WTF-1
Jsaves is offline   Reply With Quote
Old 05-03-2011, 08:45 PM   #20412
20 SMOKE's Avatar
not for 4wd SC you would be better off with the rx8
Jamie W
Old 05-04-2011, 06:42 AM   #20413
JCarr's Avatar
I have started runniing mod at our track this year, but I only have an RS. What is the lowest turn motor I can run in TC with the RS? I know this was answered a long time ago, but I can't find it now, thinking it was like 7.5. Thanks
Gorilla Size Racing
R10 USGT, TRF416 USGT, DB10R, TA05R VTA, R40, RS4 3SS, RS4 super, Savage, Hellfire.
Youthful enthusiasm only rules until old age and common sense exert themselves
JCarr is offline   Reply With Quote
Old 05-04-2011, 07:03 AM   #20414
M-Technic's Avatar
A 6.5 and 7.5 is pretty safe based on my experience. Some people run lower than that but it's not recommended.
Old 05-04-2011, 07:50 AM   #20415
JCarr's Avatar
Thanks for the reply. Would a second cap be needed running those? I'm using a 10.5 right now, but I have a feeling a will want to go lower later.
Gorilla Size Racing
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
