Old 04-25-2011, 06:21 AM   #20371
Brokin Racing's Avatar
Trader Rating: 68 (100%+)
Trevor, I'm sure any of the Hill mob would be glad to help out
Xray - LRP - PF - Futaba -
"Retired from Racing"
Brokin Racing is offline   Reply With Quote
Old 04-25-2011, 11:07 AM   #20372
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
If you keep having 12 67 faults with a 1s car I'd like to know what steering servo you're using? Booster or Rx pack? And which one?
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 04-25-2011, 12:55 PM   #20373
303slowdown's Avatar
Trader Rating: 24 (100%+)
ive had it happen with a jr 3650 with life receiver pack (protek 200mah)
and another with a futaba 9650 with a booster
and another with a jr 3650 with a 200mah lipo receiver pack wired in through the switch , and before anyone says anything about soldering it was soldiered very well and tried with different and new motors with new sensor wires.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 04-25-2011, 10:36 PM   #20374
hi-tech-redneck's Avatar
Default 212 setup
ok i haven't updated my speedo since v203,went to nor-cal raceway 2 weeks ago and found out i'm quite off the pace for 17.5 ramped tc,currently i have an lrp x12 17.5 in my photon with the stock timing piece (out of the box timing setting)but i have all of the timing inserts for the motor and i also have a new d3 in the box,anyone have a good setup starting point for such a track with eather of these motors.thanks guys!
tularecountyrc.com/the chicken ranch/exeter hobbies/nor-cal hobbies,ripon raceway/hara tcx/losi 22/top photon vta/tekin/reedy/hpi racing/3racing/AT&T/much more/upgrade rc
hi-tech-redneck is offline   Reply With Quote
Old 04-26-2011, 07:49 AM   #20375
M-Technic's Avatar
Trader Rating: 15 (100%+)
203 and 212 (and 208) are pretty much the same as far as power/speed goes.
Switch to your Duo3 and start with one of the setups from Tekin's site:
http://www.teamtekin.com/hotwire/ESCsetups/index.html
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 04-26-2011, 08:14 AM   #20376
yea already went the the ones on the site seems like there all setups for carpet atleast the 212 setups are!
Old 04-26-2011, 08:51 AM   #20377
wingracer's Avatar
For the LRP, go to the -10 insert, 40-45 boost, 10-15 turbo, 17k end, around 3-4k start, 5.7-6.0 FDR, ramp 2.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 04-26-2011, 09:18 AM   #20378
Team Tekin
Randy_Pike's Avatar
Did both fail after a board tap incident?
Old 04-26-2011, 02:13 PM   #20379
Only one was after a board tap , one was working fine did my hot laps before race ,stopped for start of race then wouldn't go , and the other worked fine then i turned off charged battery and wouldn't work after that, i tried reseting and then putting older software then new software still got the 12 67.
Ryan Borgheiinck
Old 04-26-2011, 03:43 PM   #20380
Team Tekin
Randy_Pike's Avatar
Charge up your rx packs and watch their peak voltage. I'm curious to know if it's over 7 volts...
Old 04-26-2011, 11:02 PM   #20381
Hey guys have a quick question, i was racing last weekend and took a hit and the car lost power. All the solder joints were together still and nothing was broke figured the switch just turned off. Well when i turned it back on it has steering and powers the transponder but there are no led's on the speedo. I tried to reset it with no luck? Any ideas, thanks in advance Ryan
WEEZY is offline   Reply With Quote
Old 04-27-2011, 08:28 AM   #20382
smilekt's Avatar
for custom throttle profile C1 & C2 .. can use it on 212 ? how to setup ?
Kuala Terengganu Rc Club Facebook
http://www.facebook.com/group.php?v=wall&gid=357083332025
smilekt is offline   Reply With Quote
Old 04-27-2011, 09:19 AM   #20383
Team Tekin
Randy_Pike's Avatar
http://www.teamtekin.com/hotwirehelp.html
Old 04-27-2011, 06:53 PM   #20384
smilekt's Avatar
Thanks Randy ..
from setup guide mention.. throttle profile for C1 & C2 cannot use yet
From User Guide
"Throttle Profile C1 and C2 are not in use as of yet, but they will be used for user programmable profiles in future software versions"
Old 04-27-2011, 07:24 PM   #20385
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
led 1 is blinky
led 2 is preset* timing 5k-20k rpm
led 3 is preset* ll ll ll ll
led 4 ll ll ll ll ll ll
led 5
each preset is more timing
led 6 and 7 are you custom profile you pick timing and rpm range
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
