Old 03-30-2011, 06:57 AM   #20116
M-Technic's Avatar
Trader Rating: 15 (100%+)
Originally Posted by campaign000 View Post
hey guys, I'm using RS Pro and a Muchmore 30x30mm cooling fan.
But I'm not sure whether it's okay to solder the fan directly to the batteries or not, because Muchmore doesn't indicate the working voltage and I don't prefer to connect the fan to receiver. So I'm worrying it's over-voltage and will damage the fan soon.
Any advice?
It might overvoltage but fans are only a couple bucks, and they run extra-strong when connected straight to the battery.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 03-30-2011, 07:17 AM   #20117
Thanks Adam and M
campaign000 is offline   Reply With Quote
Old 03-30-2011, 11:01 AM   #20118
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Originally Posted by LARRY F SR View Post
i am having a sensor problem in 1s 12 scale
i replaced sensor wires and replaced motors still motor studders
can you lose 1 or 2 sensors in a rs ???
any answers
This can be a few things. Booster or Rx pack?
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 03-30-2011, 11:06 AM   #20119
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
any answers
I've also seen this happen with a bad connection at the capacitor.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 03-30-2011, 02:22 PM   #20120
Old 03-30-2011, 08:10 PM   #20121
LARRY F SR's Avatar
thanks for the help
T.o.p. USA - Photon - EX - S4 - Rebel 12
The Beaver raceway - Horsham raceway - Jackson rc racing - Austintown Hobby
LARRY F SR is offline   Reply With Quote
Old 03-31-2011, 02:18 AM   #20122
darrenoakley's Avatar
I would first check you solder tabs on the speedo and motor as a small joint between 2 phases could be hidden. Also I once had a bit of solder between 2 of the posts on the sensor board on the motor. Try all these sugestions and in not Randy will be sure to work it out with you online.
Good luck mate.
Xray x11
Xray T3 011
darrenoakley is offline   Reply With Quote
Old 03-31-2011, 05:47 PM   #20123
hairy's Avatar
O.K I know this has been answered on a previous page but for the life of me I can't find it.
I am putting my rs in my 12th scale, I am using an LVBoost for the reciever. when I plug in the battery there is no sound and I have the first ,second ,sixth and seventh light flashing. I do have the motor set to brushless no reverse and the cut off a 1s and board is set to sensored. What is it I am supposed to do to fix this?
MERLIN RACING
"He once ran a marathon because it was on his way"
Logic is a lost art!
You are defined in life by how you respond to defeat!
hairy is offline   Reply With Quote
Old 03-31-2011, 05:55 PM   #20124
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
try it with a rx pack,good known motor,sensor wire 2s if it still is it has to go back.
http://go.redirectingat.com/?id=42X1...ored-1337.html
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 03-31-2011, 06:07 PM   #20125
hairy's Avatar
Thanks for the answer..I just pulled this ESC out of the box and already it has to go back
MERLIN RACING
Old 04-01-2011, 03:54 AM   #20126
Monkeys punk's Avatar
You have tried it with 2s pack or reciver pack ? If the RS isn't getting the correct voltage for some reason it wont make a sound and motor won't move. I scratched my head with this issue when I first run 1s but the booster was the problem. In the end I started using a 6.6v reciver pack to be sure.
Monkeys punk is offline   Reply With Quote
Old 04-01-2011, 07:26 AM   #20127
Not totally. I'd advise following the advice others have posted on setting it up in a 2s lipo, motor etc and negate the voltage booster to rule it out.
When I got my RSPro I upgraded it to 203 straight away. When I tried to use it it wouldnt work. I then took it back to (factory), tuend it all on, setup the throttle etc. then I upgraded it again and all was ok. If you find it isnt working still try this, update the firmware, then back it off to the original factory firmware, then once more upgrade it. Make sure once back to factory you turn it all on etc. This may just be a glitch in the program so try that also.
Since then I have had no issue whatsoever with my Tekin RS Pro, been going strong for over a year now with no problems. Just bought a second hand RS as well as I love these speedo's.
Jo90uk is offline   Reply With Quote
Old 04-01-2011, 07:28 AM   #20128
20 SMOKE's Avatar
180 is factory,212 is current
Jamie W
Old 04-01-2011, 09:00 AM   #20129
Team Tekin
Randy_Pike's Avatar
Harry, you're assuming your booster is putting out enough power, which from the sounds of it, it is not.
Grab a 2s pack and power up the esc. If it works, then your booster is shot.
THIS MUST BE DONE FIRST!
Old 04-01-2011, 12:55 PM   #20130
Some time back in this thread, a wiring diagram was posted showing how to wire the receiver pack into the speedo, and not through the receiver. This means that the speedo voltage regulator (rated at 3S input, 6v output) is doing all the work, and the speedo is seeing a continuous voltage with (almost) no current restriction.
I and friends have adopted this and we have had the best stability in set-up ever, and no worries about the receivers or servos. You can equally put the booster into the same circuit, but all the boosters seem to have issues, especially when you are using digital servos.
Not unsuprisingly, I followed advice Randy gave me on this, and it has worked so well I would recommend everyone adopt it. Two tips - make absolutely sure you wire the receiver pack the right way round as per the diagram, otherwise nothing happens when you switch it on, and always unplug the receiver pack during storage so that there is no chance it can discharge.
I hope that helps some of you who are trying to make your electronics work when using 1S packs.
SlowerOne is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
