Old 03-28-2011, 12:46 PM   #20086
SlideMasteR's Avatar
Default 1s question
Hi Guys
hope someone can help, I have just setup my 12th scale that i have not run in ages,set it up with a 10.5 motor and tekin rs pro esc, and first time running it on 1s, my problem is this:
the esc powers up and the receiver and servo work fine but there is no audible beeps from the esc/motor, and the motor is dead,
i have hooked up a second car close by (Touring car on 2s ) to use the output of that esc as a receiver pack power (for testing purposes only) as my receiver pack is on order but don't have one yet.
I then proceed as suggested a few pages back and disconnect the red wire from the Tekin's esc plug that goes into the receiver, then power everything up and it stays the same, receiver and servo work fine but motor is still dead !
however if i plug the red wire back into the receiver and then power everything back up again, i get the audio beeps and motor works fine.
surely the receiver pack should not have to power the esc aswell ??? or is this normal? if so how long will a 200mah receiver pack last ?
your help will be very much appreciated
Xray T4 15' - Hobbywing V3.1 ESC - Reedy Modified Motors - Thunder Power Batteries - Protoform - Much More
SlideMasteR is offline   Reply With Quote
Old 03-28-2011, 12:48 PM   #20087
wingracer's Avatar
Trader Rating: 24 (100%+)
Leave the red wire in and you will have to use a pack or booster. I am using about 80mah per 8 minute run.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 03-28-2011, 12:52 PM   #20088
hehehe ok, short and to the point cool
ok but any idea on the receiver packs 'runtime' or is a booster the better way to go
sorry missed the 80mah part, will have to recharge during the day
Last edited by SlideMasteR; 03-28-2011 at 12:54 PM. Reason: kinda did not red the entire post ;D
Old 03-28-2011, 01:03 PM   #20089
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
if you get a 200mah rx pack you will have to charge it every run,i use a booster in 12th and a rx pack in wgt
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 03-28-2011, 01:06 PM   #20090
i think i agree with you as 80mah per run will not kill the runtime with 10.5 even on a 1s
Old 03-28-2011, 01:14 PM   #20091
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Originally Posted by Airwave View Post
The fact is that I can't take the gaz at 100% at the enter of the parabole, so i release a little bit the throttle to engage the car. The problem is that when I release a few throttle, there is some "motor-brake" effect, really braking the car!
This is what push control is for. Anytime you're running this fast down a long straight away even lifting on the throttle causes a huge deceleration. This is what push control helps. This will hold a small amount of throttle on so the car doesn't get upset chassis wise.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 03-28-2011, 01:17 PM   #20092
can push control be used in 0 timing mode ???
would this help keep some corner speed ???
sidecarphil1 is offline   Reply With Quote
Old 03-28-2011, 01:30 PM   #20093
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Yes & Yes, especially in 17.5 as the motor will not have as much work to do when you want to accelerate again, the revs will stay up more with push control.
The slower the motor, the more push control I use, as much as 45 even.
I don't use it for mod though.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 03-28-2011, 03:08 PM   #20094
Hi guys,
Last saturday, I ran my TCX on a outdoor track for the first time of the season.
I have a Orion Vortex 10.5 and a RS Pro with LV 212.
I had a strange sensation at the end of the line. Our track is made with a 50 meters line then a parabole, closing...
I've made some tests and it seems that it is coming from the Turbo, If the turbo does not engage, I don't get this effect...
Have anybody heard of that?
(Sorry for my english)
You can either use push control (as others mention) or you can try to use a taller gearing. In my experience, a short gearing will have a lot of natural drag brake.
Personally I don't like using push control (though it can be useful on some tracks). I'd rather use a taller gearing, but I do know that some people will have temp issues using the same settings and gearing as me.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 03-28-2011, 03:22 PM   #20095
Well I finally replaced my old 3PJS radio running a Spektrum module with a new Spektrum DX3R Pro and already I can feel a difference in how much smoother the throttle is on my 1/12th scale. I haven't had a chance to test yet to see if it also fixes the turbo fade issue I've been having on my TC but I have high hopes given how much better the 1/12th felt
Old 03-28-2011, 03:26 PM   #20096
Team Tekin
Tekin Prez's Avatar
Push control can help. Also consider turbo ramp rate. As soon as you move from full throttle the turbo starts reducing at the same ramp rate it was added. With a lot of turbo and a fast ramp rate of 1 the fast reduction in turbo can almost feel like brakes.
Tekin Prez
[email protected]
Smarter, Smaller, Faster....
www.teamtekin.com
Tekin Prez is offline   Reply With Quote
Old 03-28-2011, 03:42 PM   #20097
mike ivy's Avatar
Trader Rating: 50 (100%+)
How much push control would you recommend in 13.5 1c 1/12th boosted?
Tekin Prez
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 03-28-2011, 06:04 PM   #20098
nicorozog's Avatar
Send a message via MSN to nicorozog Send a message via Skype™ to nicorozog
Hey guys, perhaps itīs a very rookie question, but i want to know which is the best Motor for this ESC.. i want to race 10.5.... which motors do you use.??
nicorozog is offline   Reply With Quote
Old 03-28-2011, 06:28 PM   #20099
Still Bill's Avatar
Duo 1 or 3 for on-road.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 03-28-2011, 06:36 PM   #20100
Team Tekin
Randy_Pike's Avatar
Tekin Redline 10.5 of course!
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
