Old 03-14-2011, 03:06 PM   #19951
Grenade10's Avatar
Trader Rating: 37 (100%+)
Originally Posted by Jo90uk View Post
Hiya
Does anyone know where I can purchase a Tekin RS case to replace a broken one ? I thought I saw a couple on ebay recently, but cannot find a stockist that has them.
Cheers
Tekin sells them I believe for less than $10, give them a call.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 03-14-2011, 05:30 PM   #19952
Team Pink's Avatar
Trader Rating: 20 (100%+)
Yes they do and I believe they are about 8 to 10 dollars as Grenade 10 stated.
Team Losi Racing/ Spektrum/ Horizon Hobby/ JConcepts/ Hobby Star/ Schelle Racing
Team Pink is offline   Reply With Quote
Old 03-15-2011, 12:00 AM   #19953
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I tried running Mod 12th for the first time a couple days ago. I was running a 4.5 with an RS pro. I only had one of the std caps installed. I was geared 88/28 with 42 mm rears. After 6 minutes the motor was only about 110, but the esc was 175+. I was running the esc in blinky sensored mode. What can I do to reduce the esc temps? I looked on the Tekin website for settings, but the only Mod 12th set up I found showed a 4.5 with mild boost and turbo, which I would think would drive the esc temps even higher.
Old 03-15-2011, 12:09 AM   #19954
CHRIS CHAVEZ's Avatar
Tekin's website states that the lowest wind brushless motor for the RS (non- pro version) is 5.0, Does that also apply to a 1/12 scale pan car running a 1s battery pack? Or can I use a lower wind for this application? If so, how low can I go without problems?
Thank you.
"Dirt is for growing Potatoes"
TQ RC Racing
CHRIS CHAVEZ is offline   Reply With Quote
Old 03-15-2011, 01:24 AM   #19955
Thank you.
If you need to run modified motors, you will need RS Pro.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 03-15-2011, 01:34 AM   #19956
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Might be overgeared ?
That's about a 42 roll
Hohwarts' setup sheet from iic shows about a 36 roll with 4t
From what i've seen.
Over-Gear = higher temp in esc
Under-Gear = higher temp in motor
Been playing with a 1s 6.5 RS Dual-Mode, with temps around 110 for both speedo and motor, even after 10 mins in an f1 car.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 03-15-2011, 02:05 AM   #19957
thanks mate !
Jo90uk is offline   Reply With Quote
Old 03-15-2011, 07:12 AM   #19958
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Thank you.
voltage doesn't mater it is rated to a 5t
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 03-15-2011, 09:24 AM   #19959
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Voltage does matter actually. If you cut voltage in half you increase current in a similar fashion.
For mod 1s 1/12 we recommend the RS Pro. You can try it as some have been successful.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 03-15-2011, 10:07 AM   #19960
20 SMOKE's Avatar
i didn't mean it like,i guess i did give a blunt answer
Jamie W
Old 03-15-2011, 12:26 PM   #19961
Trader Rating: 70 (100%+)
Hello guys,
I have a quick quiestion. I recently bought a used team associated truck and it came with an tekin rs esc. Its missinf the negative battery post. The cable its just welded the cap. It works fine but i will like get the post. Where can I get one and is it reallt necessary?
lnc0321 is offline   Reply With Quote
Old 03-15-2011, 12:30 PM   #19962
Team Tekin
Randy_Pike's Avatar
You will not be able to get a post. We do not sell them. Ideally the unit should be sent in for repair. We do not recommend running it without the posts.
Old 03-15-2011, 12:37 PM   #19963
Thanks Randy.
Old 03-15-2011, 01:08 PM   #19964
Care to share?
Old 03-15-2011, 01:14 PM   #19965
Smile RSpro
I picked up an RSpro some time ago and haven't had a chance to use it yet, I plan on using for 1/12 scale CRCXL,10.5 motor, 1Slipo, with a Futaba 2.4 radio sustem. Does it require a booster, if so what is a good dependable choice.
THEBIGBULL is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
