Old 01-07-2009, 01:28 PM   #1981
Trader Rating: 76 (100%+)
Originally Posted by Trips View Post
Mudvayne,
Racing at 360 Speedway, I get my butt kicked by Donny Lia on a weekly basis. I think he was the first around here to run 1.89. He told me this past Sunday that he's running his Duo 17.5 at 0 on the endbell, max boost in the RS, and geared shorter. I couldn't pin him down on the exact rollout he's running, but I'm going to try it starting around 72mm and see how it looks.
I did run as high as 90mm rollout with 10 degree at the endbell and little or no boost, so I'm cutting way back on the gearing to avoid cooking the motor. I'll probably wind up a few teeth taller, but I'd rather sneak up on it and keep things cool...
This is 1/12 4 cell by the way.
I ran 189 last weekend in the same class. I was geared at 1.28 inches rollout (Not sure what that converts over into mm). Motor came off at about 140 degrees. I had 10 degrees in the can, and 12 in the boost, 17.5 trinity duo as well. So, if I take the can to 0, then that means more rpms, correct? Thus gearing down would make sense.
MUDVAYNE is offline   Reply With Quote
Old 01-07-2009, 02:07 PM   #1982
Zken's Avatar
Originally Posted by or8ital View Post
Tekin, if there any thought to (or does this exist and i haven't found it) of being able to save your settings in a file via HotWire? That way you can go back and forth easily between motors. I would also suggest adding a notes field to that so you can list what motor it was for and the gearing you used. Just think it might be helpful.
That ability is highest on the "additions" list for the hotwire functionality aswell as allowing for a simple text field.
Zken is offline   Reply With Quote
Old 01-07-2009, 02:09 PM   #1983
Trader Rating: 38 (100%+)
Great news! Thanks!
or8ital is offline   Reply With Quote
Old 01-07-2009, 02:25 PM   #1984
Trips's Avatar
Trader Rating: 16 (100%+)
If you take the can to 0 AND crank the boost up you'll get more RPM and want to gear down. From ten degrees in the can plus 12 boost, you're at 22, if you go to zero on the endbell, 22 boost should put you at or close to at where you were, higher than that, and you'll want to drop some teeth.
I think that 1.28" rollout has to be a typo, or a miscalculation... 1.28" is 32.5mm.
MARSHAL!!
Trips is offline   Reply With Quote
Old 01-07-2009, 03:24 PM   #1985
miller tyme's Avatar
Ken, Lower timing overall means LESS rpm. That said total timing is motor + ESC and it does seem that the motors prefer low or mid motor timing and the rest made up in the ESC.
Also knowing the track and the typical roll out, you were probably at 3.28 inches which sounds about right.
Ken Miller
RCTarget - Capricorn - Pro Level RC - MAX Power - Maxima Fuel - EA Motorsorts - TQ Wire
LONG LIVE OPEN MODIFIED
miller tyme is offline   Reply With Quote
Old 01-07-2009, 03:27 PM   #1986
Victory Side's Avatar
Send a message via Skype™ to Victory Side
Thanks for the recommendations. I bought an Rs and Rs pro today. Hope to get them next week. Also hot the hotwire. Where you I get updates etc.
WWW.RICHFIELDRACEWAY.COM
"There are only two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle." ~Albert Einstein
"Do you want to know who you are? Don't ask. Act! Action will delineate and define you.'
Victory Side is offline   Reply With Quote
Old 01-07-2009, 04:18 PM   #1987
Trader Rating: 59 (100%+)
Send a message via AIM to todb
i just installed a RS in my 009 and I am looking to get the 189 software for it. I don't know if there are team drivers around nashville, TN to get the software from. Thanks for the help
todb is offline   Reply With Quote
Old 01-07-2009, 05:54 PM   #1988
shadow102's Avatar
Trader Rating: 21 (96%+)
Chris Cooper is in that area and can hook you up
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 01-07-2009, 06:56 PM   #1989
I dont think that I know him. can you pm me contact info? Thanks
Old 01-07-2009, 08:03 PM   #1990
Trader Rating: 44 (100%+)
Hi,
Does anyone have a ballpark figure for v189 settings for offroad 2wd with 17.5?
cheers.
YOKObori MOkei
wyl03 is offline   Reply With Quote
Old 01-07-2009, 08:17 PM   #1991
Krio's Avatar
Trader Rating: 150 (99%+)
Originally Posted by wyl03 View Post
Hi,
cheers.
5.2 fdr, 12 deg motor timing plus 15 boost
www.kriostasis.com
Krio is offline   Reply With Quote
Old 01-07-2009, 08:35 PM   #1992
So now how does this boost work? Is it a constant degree increase or does it only apply under acceleration?
Old 01-07-2009, 08:51 PM   #1993
Krio's Avatar
Boost is a constant add on to whatever timing is in the motor. Its sole purpose is to allow you to get 35 to 55 degrees of timing that high wind motors need to make max power.
www.kriostasis.com
Old 01-07-2009, 09:54 PM   #1994
Trader Rating: 26 (100%+)
so instead of adding timing why not just gear up. whats the difference?
eddie10 is offline   Reply With Quote
Old 01-08-2009, 12:13 AM   #1995
hi todb, care to post a pic of your electronics on the 009?
i'm waiting for my 009 as well... and i'm thorn between the rs pro and sc gt esc....
thanks!
g
gortan is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
